2.7 complete engine and drivetrain
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by n2weldn, Jul 7, 2011.
Thread Status:
Not open for further replies.
  1. Jul 7, 2011 at 7:18 AM
    n2weldn
    n2weldn [OP] Member
    Winfield, TN
    2001 TRD Doublecab
    2.7 Engine from a 2002 Toyota Tacoma 4x4 with 120,000 miles. Engine has complete front end accessories, wiring harness, sensors, and computer. $500 firm. Also have 5 speed transmission and transfer case still attached to engine and rear axle assembly (minus springs) and rear drive shaft. Transmission-$175, Transfer Case-$125, Rear axle assembly-$125. Will take $800 for all items listed above...otherwise prices are all firm. All items were taken from a great running truck that was involved in a front corner/wheel impact. If the rack and pinion wasn't busted from the wheel impact the truck could have been drove after the wreck. I bought the truck from a friend to use for a tube chassis project but do not have the time to follow through. 423-569-1171, 423-539-1111
  2. Jul 7, 2011 at 7:21 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    must have pictures just fyi
  3. Jul 7, 2011 at 7:22 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    ^This. OP, you better fix that before a mod notices. :spy:
  4. Jul 7, 2011 at 8:12 AM
    mjp2
    NJ
    Almost an hour and still no pics, as are required per B/S/T rules here on TW.
    Thread closed.
Thread Status:
