2.7 cuts out for a second while driving
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaguy80, Apr 18, 2008.
  1. Apr 18, 2008 at 10:49 PM
    tacomaguy80
    tacomaguy80 [OP] New Member
    97 tacoma 2.7 4x4
    When I'm on the highway or interstate my motor will cut out for a second. Its like its not getting fire to the plugs or its not getting fuel. It doesn't do it all the time just every now and then. What could be the problem? I have 136,000 miles on my 97 Tacoma.
  2. Apr 19, 2008 at 3:43 AM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Indicate at what speed and related conditions etc. Provide as much info as possible.
  3. Apr 19, 2008 at 10:48 AM
    tacomaguy80
    97 tacoma 2.7 4x4
    It does it when I'm doing 45 to 65. The truck is in good shape but the spark plug wires are 3 years old and the plugs need to be changed too. That project is for next weekend. It doesn't matter if its hot or cold it still does it.
  4. Apr 19, 2008 at 1:09 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    MAF sensor?
  5. Apr 19, 2008 at 1:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds to me like maybe a spark plug wire(s) is breaking down or distributor cap/rotor button may be the culprit.
    let us know what happens when you change your plugs/wires.
  6. May 11, 2008 at 6:48 AM
    sstewart777
    sstewart777 Member
    Maine
    00 SR5 2.7
    This might sounds nuts, but......
    I had a Mercury Lynx RS as my first car. It was used when I bought it and worked great for the first couple of years. Then is started doing what yours does. We went round and round with it. It turned out to be a BAD BATTERY! Apparently, there was a bad connection inside the battery that would either short out or open up, not sure which. The battery would hold enough charge to start the little 4 banger while it was cold, but it was the alternator that would make the vehicle go once it started. I think the heat of the motor would cause the problem in the battery to appear. I put a new battery in it and the problem went away.
    I doubt that is your trouble, but thought it might be interesting anyway.
  7. May 12, 2008 at 7:03 AM
    97YoterS
    97YoterS Well-Known Member
    North Carolina
    Chevrolet 2500HD Duramax 4x4
    None of your business
    mine had the same problem, its your throttle position sensor, I had mine replaced and it hasnt done it since then
  8. May 12, 2008 at 3:36 PM
    hicksy712
    hicksy712 Member
    Aaron
    TN
    98+ frontend swap with clear headlights, tint, 6" fabtech, 15x12 powdercoated alloys, 35x15.50 SX's, 5.29 yukon gears, 1.5" wheel spacers, k&n filter. paint and line-x to come.
    Definately sounds like your Throttle Psitioning sensor. My 97 did the same around that mileage. Did a tune up, still didn't fix it. Took it to a buddy of mines shop. its a resistance thing on the sensor, that's why you're prob not getting a check engine code. good luck.
  9. Apr 26, 2009 at 5:22 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    i had a similar problem with my 89 toy ., it turned out to be a faulty injector wire hope it will help
  10. Apr 26, 2009 at 9:57 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    yeh check your spark plugs to see if they are loose or if the wires are loose around there. or just check the spark plugs themselves. i just checked mine and changed them to some E3's because my old spark plugs were rustly loose and worn :[
