2.7 cylinder misfire problem
Discussion in '4 Cylinder' started by PTD4x2, Apr 8, 2023.
  1. Apr 8, 2023 at 5:16 AM
    PTD4x2
    PTD4x2 [OP] Member
    2016 SR
    Hi - Wondering if anyone else has had this problem... The first few seconds of a cold start the engine runs on 3 cylinders. After running a few seconds the problem goes away, and then it runs fine. Sometimes 'check engine' light comes on, scanning the codes says 'cylinder 1 misfire'. I've replaced spark plugs, cylinder 1 coil, cylinder 1 coil connector, but the problem persists. Whenever I move or touch the wiring harness, the problem disappears - for about a day, then it's back.
    The truck is old - 2006 with 262,000 miles.
  2. Apr 9, 2023 at 10:36 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Find someone with a diagnostic scanner that can read and trace electrical circuit function, Start by looking at the electrical feed to the spark plugs.
