2.7 engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zerofear66, Jun 12, 2017.
  1. Jun 12, 2017 at 1:27 AM
    Zerofear66
    Zerofear66 [OP] Well-Known Member
    2022 TRD Off Road Lunar Rock, 2014 Tundra Crew Max TRD 5.7L
    What have you guys found in terms of reman engines when forced to replace?
    I've got an 02 Tacoma prerunner that is using antifreeze along with regular misfire codes. Am I wrong to assume it's either a cracked head or leaking head gasket?
    I'm in Anaheim California and for what it would cost for a valve job/head gasket replacement I can get a reman'd motor. What do you guys think.
    TIA!!
  2. Jun 12, 2017 at 10:00 AM
    Slickster
    Slickster greentaco
    2002 pre
    i was in the same situation last year and decided to get a low mile engine instead, i did save the old engine to rebuild and have it ready.
    so i would get a reman'd engine.
  3. Jun 13, 2017 at 6:21 AM
    Zerofear66
    Ok cool, thank you! Where did you get your motor from?
  4. Jun 13, 2017 at 7:13 AM
    Glamisman
    Glamisman Well-Known Member
    I have put in JDM motors. These are used motors with relativley low mileage 50k - 60k from Japan. ballpark $1600.
  5. Jun 13, 2017 at 10:18 AM
    Slickster
    Slickster greentaco
    2002 pre
    got lucky when i was shopping for an engine and found one here in JDM san leandro for 1500 low miles .
