2.7 fuel filter not avalible??
Discussion in '4 Cylinder' started by blackwatertaco, Apr 20, 2010.
  1. Apr 20, 2010 at 4:16 PM
    blackwatertaco
    blackwatertaco [OP] If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    I went to Advanced, Vatozone, Pepboys looking for a fuel filter for my truck...No body has them. Quote "Requires disasimbily"---However you spell it.
    Also where the heck is it?
  2. Apr 20, 2010 at 5:43 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    It's in the gas tank and supposed to last the life of the truck. Doesn't make sense to me but there you have it. BTW the fuel pump is also in the gas tank and needs gas to keep it cool so it's a good idea not to let the tank run dry like some people on here do chasing miles per tank full.
  3. Apr 20, 2010 at 6:14 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    You can get a kit from URD to mod it with a replaceable external fuel filter.
  4. Apr 21, 2010 at 1:07 AM
    george3
    New Jersey
    Yes you can. Seems like a lot of work to me, unless you are having a problem. On an 08 you should be good for a long time, I would think.
  5. Apr 21, 2010 at 5:30 AM
    afd23a
    The Dynamo of Dixie
    Agreed. Might be a good idea to change it once you get to a higher mileage.
  6. Apr 21, 2010 at 5:56 AM
    george3
    New Jersey
    They use to be on the rail, nothing to it. Now it's a project. I don't know why they make an easy jobs so difficult. The only thing I can think of is they want to tell you how little maintenance you have to do and then sell you a new truck when you have a problem. 100,000 on spark plugs seems as wrong as never needing a gas filter IMHO.
  7. Apr 21, 2010 at 2:42 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I, for one, like the no maintenance design of the Tacoma. My wife's Murano needs extensive service ($6-800) every 30,000 miles including plugs and filters and special additives for the CVT transmission.
    On the Tacoma you change the oil, lubricate the prop shaft, change the filter for the air conditioner and drive on.
    Way to go, Toyota. I won't like paying for the expensive plugs at 100,000 miles but it sure is nice until then.
  8. Apr 21, 2010 at 4:01 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    The filter is part of the pump. There's also a "trap" below the intake so it doesn't suck up the crap on the bottom. But yeah, at 150k, think about pulling it out and cleaning.
    I would have preferred an inline filter as well.
  9. Apr 21, 2010 at 4:32 PM
    george3
    New Jersey
    "There's also a "trap" below the intake so it doesn't suck up the crap on the bottom"
    Thanks for the info..didn't know that.
  10. Apr 25, 2010 at 2:03 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    I have a 1998 Tacoma 2.7L and have replaced it. It is located below the intake manifold and is a pain to change because of its location and fittings.
  11. Apr 25, 2010 at 2:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes, but the second gen trucks have the filter in the tank.
