2.7 headers worth the buy?
Discussion in '4 Cylinder' started by TBLOCK09, May 9, 2010.
  1. May 9, 2010 at 11:40 PM
    TBLOCK09
    TBLOCK09 [OP] Member
    San Diego
    05 5Lug
    Total chaos lt in front , icon aal in back, Hannemann front fenders ( painted stock white and painted the roof black at same time), window tint thats not to dark (i had to get the last pair taken off they had to find a ticket for something...)Afe cold air intake, Alpine 102 deck, kenwood eXcelon KFC-X1730P componets, alpine s-12 shallow sub behind the seat pushed by a rockford fosgate mono 400 wt amp, Grillcraft black grill (re powdered flat black), and just installed the LCE header.
    does anyone know if there is more to gain then loss in buying headers?
    besides the 400 doller price tag, ive found 2 types the doug thorley's and the lc engineering's which claim to show more hp and torque throughout all rpms.
  2. May 10, 2010 at 12:03 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    check out URD's website. They've probably even got dyno graphs before/after the headers.
  3. May 10, 2010 at 1:19 AM
    forgedgreen
    forgedgreen Member
    Some guy on here said they make a difference, they should.
  4. May 10, 2010 at 1:26 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    i have jba headers and love mine im sure the ones for the 5 lug would be awesome too
  5. May 10, 2010 at 4:15 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I have the DT headers, so I can only speak for them.
    It depends on where you expect to see a difference. If you spend all of your time at low RPM's, then you probably won't see much difference. I think I've heard someone on here say that the DT's actually lower hp below 2.5k RPM's, but there's been no dyno that I've seen to support that claim, so it could be BS:notsure:. The dynos for both the DT and LCE headers start at around 2.5k and go up from there. It's easy to get fooled into thinking that it translates into the lower RPM's too. Yes, they do make a difference at higher RPM's as the dyno shows.
    The question you have to ask yourself is how much time do you spend in that RPM range and is it worth it to you.
    As for me, I'm keeping my DT's on. If I take them off it will be for some LCE's or to part out all of my mods. I'm going to have to see some dyno charts below 2.5k to convince me to even consider buying some LCE's though.
  6. May 10, 2010 at 7:01 AM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    i have the 4 banger DT's as well honestly i dont really feel muck of a difference in the lower RPM's but imo i think it may habe something to do with gearing. If i had the correct gearing to get "more power" to the wheels i bet i would feel a little bit of a diffrence.
    but i think theyw were worth it i can deff feel them in the upper RPM's when i step on it and it does wonders for the sound as well. they are also pretty easy to install your self i did a write up on them if you wana check it out.
    but anyway i think they are worth it if you have the money and the time to install yourself!
  7. May 10, 2010 at 11:54 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    love my dt header!
  8. May 10, 2010 at 11:57 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Do you have any vids of you truck with the DTs and the jardine exhaust?
  9. May 10, 2010 at 12:11 PM
    08pretaco
    az
    there might be one on here somewhere. its really hard to get a good video with my means of video taping but i will try here in the next day or two and post a vid
  10. May 10, 2010 at 1:06 PM
    afd23a
    The Dynamo of Dixie
    who dat popcorn had a video on here of his when he had both the DT's and the jardine.
    EDIT: the video had been removed
  11. May 11, 2010 at 12:09 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I have Doug Thorley Tri-Y Ceramics. They were worth it to me because my crappy cast iron manifold was cracked, and I did notice a significant top end power increase afterwards.
    If your manifold is not cracked and/or is of the "mini header" design, I don't think it's really worth it.
    BUT, it is one of the easiest power mods you can do. Definitely not the cheapest, tho.
  12. May 11, 2010 at 7:51 AM
    08pretaco
    az
    video link doesnt work or i mean it works but no tto the correct place
  13. May 11, 2010 at 9:54 AM
    afd23a
    The Dynamo of Dixie
    The one I was thinking of has been removed. Shows up in the thread bud doesn't play. He has others, but they're of the Jardine exhaust w/o the headers.
  14. May 11, 2010 at 11:57 AM
    Taco505
    Alex
    New Mexico
    well here is my set up to give you an idea of what it all sounds like but i dont have the jardine exhuast.
    the vid is kinda crappy cuz it was well dark and im retarded and cant tape and drive at the same time haha.
    this is what i got: 08 4 banger, 2wd(nonprerunner), auto trans, DT header, KNN intake, and 18" magnaflow single in dule out.
    http://www.youtube.com/watch?v=J-Kc_AOizoI
    hope this helps out a little even though its not exactly what you were all lookin for
  15. May 11, 2010 at 12:00 PM
    numbah57
    kahai
    Maui, Hawaii
    ^^ I like it...sounds good
  16. May 11, 2010 at 12:05 PM
    Taco505
    Alex
    New Mexico
    hey thanks man alot of people tell me they like it alot and they are always like wtf is that a v6?? and i tell them its a 4 banger and they cant believe it haha
  17. May 11, 2010 at 2:00 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    We have Headers for the 2.7L. Made in the USA. They are more affordable then other brands and can be had with thier ARMOR COAT Ceramic finish.
  18. May 11, 2010 at 3:40 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    wrong year for op's truck
  19. May 11, 2010 at 3:46 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    I have a LCE header and jardine cat back exhaust. Big power difference - worth every penny. I would also recommend adding a new intake like a K&N.
  20. May 11, 2010 at 5:08 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    When it comes time to buy a header for my Taco, I will go with a LCE.
