2.7 highway speed
Discussion in '4 Cylinder' started by Manderthal, Sep 20, 2014.
  1. Nov 11, 2014 at 9:47 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Coming from someone who had a 2.7, I would opt for the V6 if I were you living in hilly areas. The gas mileage of the 4 banger is about 1mpg better than the V6. I have a 2004 double cab now with a 3.4 V6 and it gets the same mileage as my 2011 access cab 2.7 did, given the 3.4 is smaller than the 4.0 V6 used in second gens, but still. The V6 trucks are better for hilly areas/highway driving in my opinion and they get the same mileage pretty much.
    Yotabilly likes this.
  2. Nov 11, 2014 at 9:54 AM
    2004TacomaSR5
    Jon
    Montana
    I basically just repeated myself, didn't realized I'd already responded to this thread! But yeah, go V6, you wont regret it! 4 bangers are great if you only drive in town and on flat areas, but throw hills into the mix and they suck. Great, reliable engines, but they are tremendously underpowered in these large 2nd gen trucks.
  3. Nov 11, 2014 at 4:15 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I think I can chime in here, I drive 273mi each way to and from college pretty regularly. My 2.7 Xtra Cab with 5 speed manual handles the trip fine but can get sort of boggy on large hills. I just downshift and keep going, mind you my trip goes over a large gorge (big descent and rise) and a mountain pass. I have loaded it down and weird enough the 2.7 starts off kinda slow, but no matter how much I load it down or tow with it, it doesn't get any worse than it is when unloaded. Give the 2.7 a chance and it will impress you and get acceptable mileage doing so. I should mention that this highway has a 70MPH speed limit as well.
  4. Nov 11, 2014 at 10:55 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    You just offered an excellent description of torque, Speedy. :)
    My work truck is almost always loaded with tools and materials, but the few times I've emptied it out it drives just the same way as when it was loaded.
    The 2TR engine is not built to rapidly gain rpms... but to maintain a set rpm level while under load.
    In my opinion, the 2.7 engine shines the brightest in the 5 lug 2 wheel drive manual transmission standard cab street Tacos.
    All of the other larger models are designed to be powered best by the 4.0.
    Greg
    Misfit likes this.
  5. Nov 12, 2014 at 10:56 AM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Well, now you tell me.
  6. Dec 7, 2014 at 4:56 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Well, im a 1st gen but my 2.7 has 4.30s with 265/75 and it will do 80mph in 3rd gear at 5500 rpm right at redlining. It does good with the mpg if their is no wind and its alone (no trailers)
  7. Dec 8, 2014 at 6:44 AM
    kenjw
    kenjw Well-Known Member
    Indiana
    2014 Reg Cab 4-cyl., 5-spd
    As a relatively short-term owner (6,500 mi on 2014 reg cab 5 spd 4x4) I think the 2.7 does fine with the 4x4, probably as good as the 4x2 owing to the 4x4's shorter axle ratio. The key is to let it spin. If you shift too early it bogs down.
  8. Dec 27, 2014 at 12:07 AM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I think the 2.7 does fine in a regular cab and even a regular cab 4X4 which is what I have. It's sure no power house but as Kenjw pointed out, if you spin it up it does just fine. You're just not ever going to win any pulling contests with it. It's built to get from pint A to point B. Not win speed contests.
    If I had a double cab or was constantly towing something I could see where a V6 would be necessary.
  9. Jan 22, 2018 at 5:09 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    I’m from Appalachia and travel to there a few times a year. My 2.7 regular cab 4x4 5 speed is gutless on those hills. If I lived there and it was my only ride I would have to have a v6 or v8. I can hit the hills at 80-85mph and top them out in third gear (full throttle all the way)going about 55-60 mph. This is with 265/75r16 (load range c) tires. Where I live now the 2.7 is fine.
  10. Jan 22, 2018 at 5:52 PM
    Nessmuk
    Nessmuk Well-Known Member
    Bob
    Charlottesville, Va
    2.7 5sp AC w/SR & convenience pkg
    I have owned two 2.7L 5sp 4x4 Tacomas, a 98 regular cab and my 2015 Access cab. The 98 had 3.7s (I believe) and the 15 has 4.10s. Maybe it's because I may 64 , but I have never had a problem with them power wise.
    I pull a 2200 lb Cargo trailer over the WV mountains to the highest point in the state about 7 times a year. The trucks have always handled it with no complaints. I do feel though that the 15 handles better when towing. I have never felt underpowered driving around home in Central Virginia.
    The 2.7 will easily get you where you are going, perhaps with a bit more foot on the gas pedal, but it will get you there.
  11. Jan 22, 2018 at 7:07 PM
    TRVLR500
    Wyoming
    The 2.7 in the mountain states is a chore to drive. That is a fact whether it is loaded, pulling a trailer or even empty. The reason so many get 300,000+ miles out of them is that the 2.7 was designed as an industrial power plant. It's made to be revved with a load and run all day long at 4000 rpm. That's what it was engineered for. Using it for what it was designed for every day would result in far less longevity IMHO. We get the high miles out of them because we don't use them for what they were designed for. Start hauling at their max limit every day and I'm sure anyone would find out they are "not" a 500,000 mile vehicle. I'd bet 200,000 miles would be about the most anyone would get out of a 2.7 if they were actually pulling a 3500lb trailer or loading 1500 lb payload every day with a 2.7. Which is still impressive.
    The 2.7 Taco is what it is. If you've got to tow and want to get there fast get a 6 cylinder. If you don't care how fast you get there even empty then get the 2.7 and deal with a LOT of rowing of the shifter if you have to traverse the mountains.
  12. Jan 22, 2018 at 7:17 PM
    Nessmuk
    Bob
    Charlottesville, Va
    I have been driving a stick for 48 years. I wouldn't know how to act driving if I weren't rowing gears and keeping my left foot busy.
    I will say though that if I drove auto transmissions I would have gone with the 4.0.
  13. Jan 22, 2018 at 7:23 PM
    TRVLR500
    Wyoming
    "Living on the Western Slope of the Rockies, driving the 2.7 was much easier than Vermont. Picking a gear and going 20 miles up or down hill is easier than having to shift every couple of minutes."
    Many on the west side of the country don't know about the Appilachians or the Smokie's. Out west the mountains are far bigger and far taller but they aren't as "jagged". The eastern side of the country with the mountain ranges I just named are "far" worse when it comes to steep climbs and descents. That along with the various two lane mountain roads and rock overhangs above the road make the eastern side of the country a little more "entertaining" than the west side to drive.
    Just as you have stated out west you can pick a gear and climb because the climbs are so long. Back east that isn't the case for the most part unless you're climbing Sandstone out of VA into West VA or climbing Black Mountain out of NC on your way to TN.
    The eastern side of the country has some of the nastiest mountain roads there are. We have them out west as well but I'm just trying to point out that the west doesn't rule when it comes to snaky, steep, windy highways. If I lived in the mountains back east I'd be revving my 2.7 far more than I do out west as well as rowing the shifter on my 5 speed far more.
    Nessmuk likes this.
  14. Jan 22, 2018 at 7:30 PM
    Nessmuk
    Bob
    Charlottesville, Va
    250 and 33 between Virginia and West Virginia are perfect examples of the roads you describe. One switchback after another. I grew up in West Virginia and just took them for granted.
  15. Jan 22, 2018 at 7:41 PM
    #35
    TRVLR500
    Wyoming
    Believe me, we have two lane like that out here but I think there is far more of it back east.
  16. Jan 24, 2018 at 10:16 AM
    #36
    uwu
    uwu Well-Known Member
    At least "out east" our trucks can breathe because of the low altitude. Lot less horsepower at 13,000' vs 5,000' :)
  17. Jan 25, 2018 at 12:42 PM
    #37
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The 2.7 4-cylinder (2TR-FE) is built for durability and longevity. It is way overbuilt, with standard compression (9.5:1) and hydraulic tappets. So it is low maintenance, and will also last a very long time even if it's worked hard, assuming it receives normal service. Yes the "power" (term used loosely haha) is relatively high in the RPM , above 3500. Not sure when the VVT kicks in but you can feel it.
    Normal driving around town and highway, it does fine. Barn door aero hurts MPG above 65. Honestly, mine struggles only when at elevation AND with a load. I just manually downshift (4-speed auto) and let the engine rev as long as the power is needed, which it will happily do all day long. It's a great motor as long as you don't expect high performance.
  18. Jan 26, 2018 at 7:03 AM
    #38
    uwu
    I don't think the VVT "kicks in" hence the variable part.
  19. Feb 19, 2018 at 10:42 AM
    #39
    81shark
    81shark Well-Known Member
    It's fine. May need to grab a lower gear going up or down grade a steep grade, but i can keep up with traffic. I use 3rd in the I70 mountains just west of denver. Lot of second on mt evans or pikes peak. Not a biggie
  20. Feb 22, 2018 at 8:35 AM
    #40
    81shark
    not many roads at 13K ft.
