2.7 ignition coilpacks....aftermarket any good ????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck 2.7, Aug 8, 2021.
  1. Aug 8, 2021 at 5:18 AM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    09 2.7 acces base 2wd auto 207k : Mechanic said sparkplugs and coilpacks are needed. Anyone with a 2.7 Taco using aftermarket ignition coilpacks that work fine no issue if, so what make/brand are they & how many miles using them ? Or are they a timebomb for my rig & go oem BIG$$$$ ?
  2. Aug 8, 2021 at 5:36 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    BorgWarner EFR 6258
    I replaced mine with Denso 6731308. If you want aftermarket, RIPP makes some but I don’t have any personal experience running them, I just know they’re out there. However there are a few SC’d v6 guys running them, and the OE coils are the same between the i4 and the v6.
    For a naturally aspirated setup, I’d just run the Densos so you know 100% what you’re getting
  3. Aug 8, 2021 at 5:39 AM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2014 DCSB SR5 V6
    CSF T4R/FJ radiator
    This. Im fairly sure denso makes the OE coils for our trucks anyway. Id highly recommend denso as well
  4. Aug 8, 2021 at 5:59 AM
    tacotruck 2.7
    Katy TX
    How long/ many miles APRX... have you had them on your truck + did you notice any difference in performance ?
  5. Aug 8, 2021 at 6:02 AM
    tacotruck 2.7
    Katy TX
    Shopping...there is a major leauge difference in price among vendors..Autozone 91$ Walmart & Famazon 32$ all same part # bassakwards posted....very weird.
  6. Aug 8, 2021 at 6:05 AM
    BassAckwards
    BorgWarner EFR 6258
    I ran the stock Denso’s for 272k miles and then put some new ones in and I’ve run those 13k so far. No issues with the new or old ones ever, but I saw one fail on an FJC at about 285k so I did mine as preventative maintenance. I didn’t notice any difference in performance, ran just like it did before after replacing them.
  7. Aug 8, 2021 at 6:07 AM
    BassAckwards
    BorgWarner EFR 6258
    davidstacoma likes this.
  8. Aug 8, 2021 at 6:09 AM
    tacotruck 2.7
    Katy TX
    WOW THATS INSANE I THOUGHT 200K miles WAS PUSHING IT. The truck you used the Densos was a 2.7 Taco ?
  9. Aug 8, 2021 at 6:10 AM
    BassAckwards
    BorgWarner EFR 6258
    Yes sir 2.7L just like yours. 2009 as well
    tacotruck 2.7[OP] likes this.
  10. Aug 8, 2021 at 6:10 AM
    tacotruck 2.7
    Katy TX
    Neat, thanks for the link. Very cool.
  11. Aug 8, 2021 at 6:11 AM
    tacotruck 2.7
    Katy TX
    IM SOLD..... ORDERING TODAY THANKS BASSAKWARDS...
  12. Aug 8, 2021 at 6:12 AM
    BassAckwards
    BorgWarner EFR 6258
    When you have them replaced, I’d be asking for the old ones back. They’d be good to keep as spares. Was the truck having a misfire when you took it in, or why is the mechanic suggesting they need to be replaced?
    blu92in99 and Heyyo_Friday like this.
  13. Aug 8, 2021 at 6:20 AM
    tacotruck 2.7
    Katy TX
    ITS been hesitant rite after a cold start for a minute or so then idles normal...then today I got a check engine code: missfire cyl 1& 2 random missfire. The young man at Oreily pulled the code and said plugs and coils most likely. I dont really trust auto part guys expertise i just wanted a code pulled. Anyhow i called my mechanic and he said the exact same thing. My oem sparkys have 70k so i may change them out also.
    BassAckwards likes this.
  14. Aug 8, 2021 at 6:27 AM
    BassAckwards
    BorgWarner EFR 6258
    You might try swapping coil packs between cylinders 1 & 2 and 3 & 4 and then pull the codes and agin and see if the codes follow to those cylinders. That would tell you for sure it’s coil pack related
  15. Aug 8, 2021 at 6:29 AM
    BassAckwards
    BorgWarner EFR 6258
  16. Aug 8, 2021 at 7:16 AM
    tacotruck 2.7
    Katy TX
    Rite on.
