2.7 L 4 Cylinder Engine Rev Problems / Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EatMyTacomaDust, Feb 6, 2013.
  1. Feb 6, 2013 at 11:17 AM
    EatMyTacomaDust
    EatMyTacomaDust [OP] Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    WeatherTechs, Console Vault, OEM Bed Mat, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, Exterior Cargo Net, OEM Toyota Cargo Divider, Cobra CDR 840 Dash Cam, Sliding Rear Window Security Bar, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Full Debadge except TRD OEM Red Tailgate Badge, Undercover SE Tonneau
    Hey Guys,
    I've got a 2011 2.7 Liter 5 speed 4x4 AC. Currently about 27,500 miles. I've been experiencing intermittant problems with the Engine reving in gears 2,3 & 4.
    The engine will rev high while driving [as I'm shifting through the gears], but my speed will not increase. I'm not sure if this is the transmission or computer or a bad sensor. This problem started happening around 22,000 miles.
    Has anyone else experienced this in a 4 Cylinder 5 speed? Going to take it in under warranty and was hoping you guys could help shed some light before I do.
    Thanks.
  2. Feb 6, 2013 at 12:11 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Sounds to be your clutch to me. Sounds like it "slipping"
  3. Feb 6, 2013 at 1:19 PM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    ^^^^ Ditto^^^^
  4. Feb 6, 2013 at 1:40 PM
    EatMyTacomaDust
    That's an interesting thought, one I haven't considered.
    The reving starts after the clutch has been completely released though.
  5. Feb 6, 2013 at 1:50 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Yea that's when it slips is when it out, released.
  6. Feb 6, 2013 at 2:26 PM
    MomsTacoma
    MomsTacoma Member
    Western Slope, Colorado
    AC 2.7 SR5 4WD
    I have noticed this problem on my mother's 2007 Tacoma 2.7 5-speed as well. I'll be cruising in 4th or 5th gear around 60 to 70 mph, depress the clutch to shift, the engine instantly revs up about 200rpm then levels off for 3 to 4 seconds before dropping to allow for a smooth shift... Really doesn't seem normal. I posted on here about it recently but didn't get many responses. I don't think there are too many 4cyl owners out there. At first I also thought it was a clutch issue, but it engages and disengages (albeit at the very top end of the stroke) as it should and doesn't slip. I know what a slipping clutch feels like and this is not it. If your clutch was slipping the engine would rev up in gear with the clutch disengaged. I think I'll be taking her truck in soon to get it looked at and I'll report back when I do. In the mean time I'm hoping some other 2.7 owners might be able to shed some light on this...
  7. Feb 6, 2013 at 2:41 PM
    EatMyTacomaDust
    I think I phrased that wrong. I meant when the clutch is fully engaged - ie when my foot is not on the clutch.
  8. Feb 6, 2013 at 2:44 PM
    EatMyTacomaDust
    Yeah it's definitely not normal. It's actually almost gotten me into a couple of accidents merging onto the Interstate.
    I've searched high and low on the internet and can't find anyone with a 2nd Gen 4 cylinder having this issue - pretty frustrating. I'm seeing alot of people with 2nd Gen V6's having a similar problem and they are saying it's a transmission issue and generally the Dealerships are giving them the run-around.
    Yes I would appreciate hearing back what you find out. I'm going to try to take mine in next week and I will definitely post what I find out
  9. Feb 6, 2013 at 3:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This:
    And This:
    These are not the same thing. Opposites in fact.
    EatMyTacomaDust's problem does indeed seem like the the clutch is slipping.
    MomsTacoma problem sounds like there could be an issue with the (IAC Valve) Idle Air Control Valve. As the engine doesn't idle down when the throttle is released.
  10. Feb 6, 2013 at 3:28 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    yea we on same page. it does sound like your clutch. next time you go to drive get it in about 3rd gear at about 20mph or around 1-1500 RPMS. floor it, if the rpm's go way up and the truck doesn't take off and makes lots of noise(engine reving) than your clutch is slipping. if it just slowly gets speed back up like normal, than clutch may be ok. this is one way to test.
    or from a stop give lots of gas and drop clutch. if tires dont spin, burn out, than clutch may be bad, but i would do the 3rd gear thing.
    good luck
    and moms taco not sure on yours?
  11. Feb 6, 2013 at 3:31 PM
    EatMyTacomaDust
    That seems to be the general consensus here. That didn't even occur to me before I started this thread. Looking back to the problems I was having this morning driving to work, a slipping clutch does make sense though.
    Thanks for all of your help guys. Any other comments are welcomed. You guys ROCK!
  12. Feb 6, 2013 at 5:50 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Search for stories on the Luk clutch they put on the 4 cylinder. There is a TSB to replace with the (superior) Aisin under warranty if it's failing.
  13. Feb 6, 2013 at 7:03 PM
    chriss
    chriss Well-Known Member
    chris
    Search for rev hang or rpm hang. This has been discussed quite a bit.
    The dealer will tell you " they all do it" and "it's for emissions". I saw a post on another board some time ago where they were petitioning Toyota regarding excessive clutch wear due to the ackward shifts.
  14. Feb 7, 2013 at 10:34 AM
    EatMyTacomaDust
    Ok good. Yeah that's exactly what it's doing. It's really bad when I shift at a lower RPM and get on the gas to get up a hill. At higher RPMS it's not as bad but I don't like having to shift past 3K RPM on a regular basis. Seems the optimal shift point in my truck is around or right above 2.5K RPM.
    Thanks - Appreciate your input.
  15. Feb 7, 2013 at 10:39 AM
    EatMyTacomaDust
    Excellent news. I haven't seen this TSB but will try to find it now that I know what to look for.
    A quick search has yielded results regarding the Luk clutches, That TSB apparently is for year models 2005 - 2011. You would think Toyota wouldn't let this crap go for that long.
    I'll try to find the actual TSB and print out to take to the dealer. Thanks for letting me know about the Luk [BAD Luk] clutches and the TSB- Much Appreciated.
  16. Feb 7, 2013 at 11:15 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Virginia
    '06 RC, 4X4, 5 speed
    I have the same issue with the revs increasing when pushing in the clutch, especially when shifting between 4th and 5th gears. The only fix Ive found that works is occasionally disconnecting the battery so the computer has to relearn your driving habits (and thus gives you more control over the throttle valve). And FYI, the 2TR doesnt have an IAC, it's drive-by-wire so theres no need since the computer controls the throttle valve.
  17. Feb 20, 2013 at 6:26 PM
    EatMyTacomaDust
    UPDATE:
    I took my truck into the dealer and told them I had a slipping clutch and that there was a TSB to resolve the issue. They checked it out for about 30 mins and came back and said they would fix it under TSB 0066-11.
    They replaced:
    Clutch Cover Assembly
    Clutch Disk Assembly
    Flywheel Sub-Assembly
    Replacement parts are AISIN, NOT LUK! Truck feels like new, shifts better than it did when new. So far i am a happy camper.
    They also replaced my Fan motor and that dreadful ticking is finally gone!
    On a side note: When I dropped my truck off this morning I told my service guy I wanted to get the Rear Leaf Spring TSB done due to a harsh ride with the bed loaded. I told him that my rear end bounced and felt unsafe. Needless to say they ordered the rear springs no questions asked and they will be installed next week!
    ROCK ON. Love it.
    Thanks to all who posted on my thread telling me what my issue was - MUCH APPRECIATED!
