2.7 L crankshaft timing pulley teeth check
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Food forester, Aug 22, 2023.
  1. Aug 22, 2023 at 8:06 PM
    Food forester
    Food forester [OP] Member
    05 Tacoma 2.7 Liter
    Aloha,
    Anyone have any input for how to check the crankshaft timing pulley teeth?
    My OBD 2 sensor reads PO335 indicating something is wrong with the crankshaft position sensor system.
    I have tested for resistance in the sensor, wiring harness and connector, and crankshaft position sensor installation so far. Next on the list is to check the crankshaft timing pulley teeth.
    For anyone working on this issue, here is a file that outlines diagnosis for 2.7 L 2nd Gen Tacoma that I found in the forum.
  2. Aug 22, 2023 at 8:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    About all you could do there is look through the opening where the sensor goes and see if the teeth are all intact and not bent or anything although it would be very unusual for the reluctor to get damaged.
    Food forester[OP] likes this.
