2.7 L NEEDS TO BE CHANGED ???
Discussion in '4 Cylinder' started by Hot2na, Jun 5, 2012.
  1. Jun 5, 2012 at 4:22 AM
    Hot2na
    Hot2na [OP] Well-Known Member
    that is 2.7...sorry
    does anyone agree that this engine needs an update?
    they updated the 2.4l in my rav 4 to a 2.5 with tighter specs and it is much improved in power and mpgs
    this engine is the same for how long ???
  2. Jun 5, 2012 at 6:31 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    I do not agree.
    Love this engine and wouldnt change a thing about it.
    If you want more power, buy a V6
  3. Jun 5, 2012 at 6:33 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Why? It seems to be a good small engine option for the Tacoma and, from what I've read, seems to be bulletproof.
  4. Jun 5, 2012 at 6:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    7 years-ish
  5. Jun 5, 2012 at 6:37 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    They used the 20-22R engines for like 30 years if it ain't broke don't fix it. Great engine want more power you need displacement with more displacement you lose economy.
  6. Jun 5, 2012 at 10:32 AM
    Hot2na
    Just saying- the 2.5 is all new ,very tight ,uses different oil than the 2.4 ...a complete redesign based on TODAYS knowledge...
    they might be able to apply some of what they learned to the 2.7 and make it even better (power and MPG)....
  7. Jun 5, 2012 at 2:15 PM
    Hot2na
    well they put it in a rav 4...the 2.4 was a sloth...this has more get up & go...
    but you are right...torque is what counts on a truck.
  8. Jun 5, 2012 at 2:45 PM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    You should specify which 2.7L you are referring to. The 2.7L that was used between 1995 and 2004 was the 3RZ, the 2.7L with VVTi that is from 2005-current is the 2TR-FE. They are not the same engine even though their displacements are the same. I think the 2TR is a very good engine for what it is. There are ways to make the 2TR probably more powerful or lighter or quieter but they normally come at the cost of complexity and reliability. The 2TR is well matched for what the Tacoma expects, albeit a little on the lean power side.
  9. Jun 5, 2012 at 6:25 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    The 2TR-FE 2.7 L 4 cylinder is a damn good engine as is and should remain in production for many years to come. It is a fairly new design.
  10. Jun 5, 2012 at 6:28 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    3rz.. takes the cake. That new stuff is so plastic covering everywhere...
  11. Jun 6, 2012 at 6:50 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    What the hell are you talking about? There is just as much plastic on your rust bucket.:eek:
  12. Jun 6, 2012 at 8:51 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    I'm happy with the engine, but 3.31 gears are ridiculous. Despite that this truck has more get up and go than my 94 Yota that was equipped with the 3.0 V6, 31" tires and 4.56 gears.
  13. Jun 7, 2012 at 3:45 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2. I bought mine because it had a rep - bulletproof -that was it. If it works and you don't have to worry about it for 300,000 - with proper maintenance - why fool with it ?
  14. Jun 7, 2012 at 3:49 PM
    george3
    New Jersey
    I'd like 2 C Higher high gear. The 5 speed is fine but if it had the same with a higher 6 speed gear I'd get better highway MPG.
  15. Jun 7, 2012 at 4:50 PM
    Supra TT
    Eric
    Indiana
    I don't have nearly that much rust as you think. Plastic? There is no plastic covering the engine.
  16. Jun 7, 2012 at 5:52 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i'll just leave this here :)
  17. Jun 7, 2012 at 6:10 PM
    stowayman
    stowayman Well-Known Member
    Gary
    Monterey, CA
    08 DC 4X4 TRD O/R - Debadged
    Kenwood DNX9980HD Nav - BT - Sirius - backup camera, Weathertech digifits, maglite mod, 14" billet antenna
    That's why there's a V6 option... the 4banger yota is a sweet motor coupled with the manual tranny regular cab and swb... makes an excellent wheeler... I loved my 87 4runner w/ 5spd... the 2.7 has alot more power than that...
  18. Jun 7, 2012 at 6:53 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    The 2trfe is a good solid engine with the torque right where it needs to be. My truck has no complaints at 30-35 MPH in 4th which is about 1400 RPM... It has been so long that I can not remember the last time I had it above 3500 RPM.
  19. Jun 20, 2012 at 3:29 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I agree the 2TR-FE is a very good 4-cylinder engine. I just don't understand why Toyota put VVT on one cam only. My dad's Highlander (same year as my Tacoma) has a 2.7 with VVT on both sides, it has a lot more pep and more responsive throttle and definitely spins up faster. Maybe it makes less torque and more HP? I understand there's a different type of engine work being done (and different power delivery needed) for a pickup application vs. SUV application.
  20. Aug 12, 2012 at 2:53 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    I hope the next gen engine gets dual vvt-i and direct injection. and a 6 speed.
