2.7 L - Remove, Clean and Replace Secondary Air Filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gnuenglander, Jul 13, 2016.
  1. Jul 13, 2016 at 9:21 PM
    gnuenglander
    gnuenglander [OP] Member
    4x4 Access Cab 5 speed manual
    I have a 2010 Tacoma, 2.7 L, 5 speed. Mice invaded the truck and built a nest in the plastic box holding the engine air filter. Believe it or not, the little f****rs ate a tennis ball sized hole in the engine air filter element (I have photos) and then built a raunchy nest beneath what was left of it. The secondary air filter protected the engine but it looks real dirty. Has anyone ever removed the secondary air filter, cleaned it, and then reinstalled it securely in the box? If so, can you provide instructions? Also, if there is anyone out there with a spare secondary air filter who would like to sell it let me know. BTW, the mice also built a nest on the cabin air filter - another reeky mess. Mice suck - yeah, I know, I need a cat. Thanks.
  2. Jul 13, 2016 at 9:40 PM
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    Are you talking about that carbon/charcoal filter on "top" of the air filter istelf? If you are, you have to drill out those plastic rivets to remove it. You can't put it back in once you do that. You'd have to order a new airbox assembly in order to get the charcoal filter back.
    Lots of people remove it just because... but I'm with you I like the added protection it gives from things like mice
  3. Jul 14, 2016 at 8:02 AM
    gnuenglander
    Yes, the "top" carbon/charcoal filter is what I'm talking about. All suggestions welcome. Thank you.
  4. Jul 14, 2016 at 8:11 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  5. Jul 14, 2016 at 8:32 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  6. Jul 14, 2016 at 8:36 AM
    Mush Mouse
    mush
    2013 SR5
  7. Jul 14, 2016 at 8:39 AM
    Mush Mouse
    mush
    2013 SR5
  8. Jul 14, 2016 at 2:05 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yes you can reinstall the charcoal (secondary) air filter after drilling out the rivets. Get a small drill and *carefully* drill holes into the base where the rivets used to be. Then find small sheet metal screws (or maybe wood screws) that will fit into these little holes. Then just reattach the charcoal filter. May need to cut the screws shorter so that the screw head can push firmly against the filter.
    https://www.google.com/search?q=tacoma+2.7+charcoal+filter+removal
  9. Jul 22, 2016 at 8:56 AM
    gnuenglander
    Thank you DGXR. My mouse-less quest continues. --Gnuenglander
