2.7 L Secondary Air System Gives Engine Light after Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eal1997, Sep 1, 2020.
  1. Mar 23, 2023 at 5:49 PM
    #41
    Duhunkachunk
    Duhunkachunk Active Member
    2009 Tacoma Access base 2.7 2wd
    Hmm, I checked this diagram and thought there’s no way it’s just going to the backside of the map sensor. Also me being an idiot didn’t check if there was a fitting on it. Thanks for clarifying, just need to get the line and toss it on. Nothing but headaches with the p2441 and p2445 codes, threw an ASV at it and tore down the SAI pump and thoroughly cleaned, checked all electrical and countless hours searching every forum to try and take care of these codes.. and I'm 98% sure this stupid hose is the culprit. Thanks dood
  2. Mar 27, 2023 at 9:13 PM
    #42
    Codeka
    Codeka Well-Known Member
    Pasadena, CA
    2012 TRD Sport
    Maybe try an intake valve cleaners? Assuming that'd be best for blasting carbon or dissolving it. I'm going to give this a try on my 1GR as I just had mine fully inspected by the dealership, and valves/pump replaced with my bank 2 still being stuck. Got a picture by chance? Just so my dumb ass doesn't spray the wrong area
  3. Mar 28, 2023 at 6:06 AM
    #43
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Not sure Id go spraying stuff willy nilly into the SAIS system. You might end up fouling the CATs :notsure:
  4. Mar 28, 2023 at 9:17 AM
    #44
    spazjensen
    spazjensen Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    I don't have a picture, but it's where you pull the large rubber hose off the valve housing. My CAT and O2 sensors were already messed up by the time I tried this. And like I said I only used a small amount and let it sit a night or two before cranking it again. Small enough amount that would easily and quickly burn off. The little thin reed valve on mine had some corrosion on it and it was not opening. The WD-40 was used hoping to break through the that little bit of surface rust and that it would solve the opening the not opening problem before I started troubleshooting other things.
    If you have all new stuff, might want to check into any electrical connection points would be my next starting point.
    SR-71A likes this.
  5. Mar 28, 2023 at 7:36 PM
    #45
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    How is the Vapor Purge Sensor ? $45 part at Advanced Auto Parts . Try if nothing else works maybe ?
  6. Mar 28, 2023 at 8:01 PM
    #46
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Some idiot had the air intake off and when he reinstalled the air box to the valve cover he ran the map vacuum line under the bracket (squishing the line closed) instead of running it over the bracket. What a moron :anonymous:
