2.7 LCE header...hissing noise.
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMX, Aug 29, 2011.
  1. Aug 29, 2011 at 7:26 PM
    TacoMX
    TacoMX [OP] TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Whats up fellas?
    I recently installed an LCE header on my truck and since finishing it I have noticed a subtle hissing noise coming from the header location while driving.
    It happens under load only, like under acceleration or revving it in neutral. No hissing at idle. Its a lot easier to hear when the door and windows are closed. When your outside the truck its nearly impossible to pinpoint. I tried having a buddy plug the exhaust with a rag to make the possible leak louder to pinpoint it but that doesn't work.
    I replaced the EGR gasket b/c the one that LCE provided seemed a bit cheezy so I replaced it with a felpro gasket. It didn't help....
    Any ideas? Is the hissing normal with an LCE header? I had a cracked manifold before installing the LCE header so I know that a usual exhaust leak the far upstream in the exhaust is more like a tick not a hiss....so I am stumped....
    ideas?
  2. Aug 31, 2011 at 7:47 AM
    TacoMX
    Jonathan
    Deltona, Florida
    bump...anyone?
  3. Aug 31, 2011 at 10:37 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Try torquing your header bolts down in the right pattern.
    then check the flange connection at end to your O2 sensor/cat...tighten it up.
    Might came loose if you didn't torque to proper specs.
  4. Aug 31, 2011 at 11:41 AM
    TacoMX
    Jonathan
    Deltona, Florida
    hmmm...i re-torqued everything already, but didn't know there was a specific pattern to tighten the header nuts. I tightened the down by alternating to the right and left side and alternating top and bottom. Whats the specific pattern?
  5. Sep 7, 2011 at 8:29 PM
    TacoMX
    Jonathan
    Deltona, Florida
    bump....anyone else?
    I think I am going to order a gasket set from LCE just in case I pinched the header gasket...idk where else the leak/noise could be coming from...
  6. Sep 7, 2011 at 9:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I would think that if it was an exhaust leak you would hear it at idle too...
    You descibe the noise as a hiss, can you be more specific or maybe make a recording and post it?
    I am wondering if is simply the normal sound of headers. The sound coming through the header tubing is a lot different that what you hear from a regular, cast iron manifold.
  7. Sep 8, 2011 at 6:56 AM
    TacoMX
    Jonathan
    Deltona, Florida
    I will try to get a sound clip/video of the outside/inside. I just noticed yesterday that at idle there is a slight tick coming from the header side....but I never got to hear the motor w/o a cracked manifold so I dont know if its just the valve train or what....I might also get another can of seafoam and run it through the truck to pinpoint the leak too...
    HondaGM likes this.
  8. Feb 23, 2023 at 12:55 PM
    96 taco supreme
    96 taco supreme New Member
    96 tacoma 4x4 2.7 manual
    Having similar issue with my truck. Ever figure out what was wrong?
  9. Feb 23, 2023 at 12:57 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    :popcorn:
    J Williams likes this.
  10. Feb 23, 2023 at 1:23 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Check the EGR tube gasket as well as the Gasket at the Catalytic converter. I have had multiple issues over the years with both of those joints with my LCE long tube header. I ended up using copper rtv and it helps to make the gaskets last longer.
    HondaGM likes this.
  11. Feb 23, 2023 at 1:25 PM
    J Williams
    J Williams Well-Known Member
    Jeff
    Central MN
    2021 TRD Pro
    11-1/2 years has passed…OP is likely into a different project by now. LOL
    Digiratus likes this.
  12. Feb 23, 2023 at 4:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Looks like the OP hasn't logged in in almost 4 years.
  13. Feb 23, 2023 at 5:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Zombie thread dude.
    But hissing sounds are often vacuum leaks. And old trucks have rotten hoses
