2.7 limited slip or posi-lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtragweed, Oct 25, 2008.
  1. Oct 25, 2008 at 2:40 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    does anyone know if the 08 2.7 has a LSD or posi-lock, i was going through my field the other day and i stopped and when i started back my tire slipped and it felt like it grabbed, cause i saw 2 bare spots where both spinned
  2. Oct 25, 2008 at 4:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Look at the rear diff. You should see a sticker that says " LSD oil only" or something to that affect. FWIW, not many 4 bangers come with the LS diff, and in a field its easy to spin both tires with an open diff. ALso, with an open diff on the Tacomas, when you turn to the left while spinning, both tires will more easilly spin. When you turn to the right, only one tire will spin. :)
  3. Oct 25, 2008 at 4:44 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    is there anyway to make it so it does catch both tires without spending a grand
  4. Oct 25, 2008 at 4:59 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Not really, unless you want to do your own custom fab work, and put a posi from some other vehicle on there.
  5. Oct 25, 2008 at 5:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Drop the Third member, clean really good with some brake cleaner, let dry, weld all the spider gears, clean all the welding splatter out, clean with some brake cleaner, put everything back together, add oil.
    Now you are Locked! :D
    Cost: about $100.00 if you have a welder. Slightly higher if you have to go buy one.
  6. Oct 25, 2008 at 6:35 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    does that mean the rear would be locked all the time
  7. Oct 25, 2008 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep! :D
  8. Oct 25, 2008 at 6:49 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    you have any other ideas
  9. Oct 25, 2008 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Detroit Tru Track
  10. Oct 25, 2008 at 7:15 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    you got a ball park of how much they are
  11. Oct 25, 2008 at 7:20 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
  12. Oct 25, 2008 at 9:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  13. Oct 28, 2008 at 10:50 AM
    zuter
    zuter Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
  14. Nov 1, 2008 at 9:56 AM
    marvin02
    marvin02 Well-Known Member
    '07 Access Cab SR5 - Black
    Top Dawg Folding Tonneau Cover, DIY Bed Light, Aux. Input for MP3 Player, OEM Bed Mat
