2.7 Liter Access 4x2 Base: Looking for a more rugged/stalky looking tire!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TightTacos, Sep 6, 2010.
  1. Sep 6, 2010 at 4:30 PM
    TightTacos
    TightTacos [OP] Member
    Jesse
    Kaneohe, Hawaii
    2007 Access Cab 4cyl. 4x2 Manual Trans.
    Want to start many
    Hello TW! I just recently bought my 2007 Tacoma and i was wondering if you folks had any suggestions on a small, yet rugged looking tire. I have the stock 15 inch wheels on now but im picking up a set of 16x7s tomorrow because i got a really good deal! Lemme know if you folks have any suggestions for something that would make my little truck look a little more aggressive...:cool: Thanks!!!
    BTW- this is my first post on TW:D
  2. Sep 6, 2010 at 4:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
  3. Sep 6, 2010 at 4:41 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    The bfg all terrains are great!
  4. Sep 6, 2010 at 5:30 PM
    TightTacos
    Jesse
    Kaneohe, Hawaii
    Want to start many
    could i find a bf goodrich a/t to fit a 16x7 that wouldn't rub on a smaller taco?
  5. Sep 6, 2010 at 7:14 PM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '10 Access SR5 4x4 4cyl
    Just curious, are the 15" wheels 6-lug? Are the 16" wheels you found OEM Tacoma wheels?
  6. Sep 7, 2010 at 3:42 AM
    TightTacos
    Jesse
    Kaneohe, Hawaii
    Want to start many
    No, the 15" wheels are 5 luggers. The 16s are aftermarket "boss" rims with a universal lug pattern.
  7. Sep 7, 2010 at 4:37 AM
    Pbucks
    Pbucks Well-Known Member
    Montgomery County, Md
    09 SR5 Access (sold)
    None yet
    personally I would stay with a 15' rim, just prefer more tire less rim. I'm planning on using BFG A/T on my stock rims when it comes time to get tires. I want a little more tire than stock but don't want to mess with the drive-ability of the 4-banger. I will probably go with 215/75/15.
    For you with the 16X7 rim the 235/70/16 would work better with your wider rim. The A/T come in different load ranges, I would use the C rating as the E would be very stiff they are meant for trucks that handle much bigger payloads.
  8. Sep 7, 2010 at 12:43 PM
    TightTacos
    Jesse
    Kaneohe, Hawaii
    Want to start many
    Thanks for the help everyone! Much Mahalos;)
    One more thing, anyone find or have any pictures of 5 Lugger tacomas like mine with A/Ts? My Tacoma doesn't have the factory fender flares BTW. I wonder what it would look like sitting in the fender without the flares?
  9. Sep 7, 2010 at 12:51 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
  10. Sep 7, 2010 at 5:03 PM
    trd09
    trd09 Well-Known Member
    Chuck
    MA
    09 TRD Sport AC 4x4
    4-leaf TSB, 5100s @ 1.75, Flowmaster 40, Undercover Tonneau, K&N drop-in, Nittos, NGK Iridiums, OME N182s
    Nitto Terra Grapplers are a great tire, comparable to the BFGs but cheaper.
  11. Sep 7, 2010 at 5:51 PM
    TightTacos
    Jesse
    Kaneohe, Hawaii
    Want to start many
    excellent post epa4wd! :cheers:
    Thanks all!!!
  12. Sep 7, 2010 at 6:12 PM
    TightTacos
    Jesse
    Kaneohe, Hawaii
    Want to start many
    Has anyone ever used General Grabber UHP or AT/2s? These tires look appealing, especially for the price! My Truck would fit a 235/70/16 tire correct?
  13. May 9, 2012 at 6:44 PM
    Steveolo
    Steveolo Member
    Steven
    NJ
    2011 SR5 speedway blue
    none yet
    hey guys i've been wanting to get new tires for my 2011 access cab 4x2. my stock set is equipped with 15 inch rims. i want mud/all terrain tires that'll fit on my rim and be bigger than my original tires. I tried searching on tirerack.com but it's not much help to me, if anybody's got any suggestions of can tell me tires i can get without getting a lift of any sort please let me know
  14. May 9, 2012 at 6:49 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    30x9.5x15 tires are the largest you can fit without lifting, however you will need to remove the black box in the front fenderwells so they don't rub.
