2.7 liter towing capacity
Discussion in '4 Cylinder' started by dgjones, Mar 13, 2010.
  1. Feb 15, 2011 at 9:54 AM
    #61
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    And to that Im going to say, No. If Toyota felt it safe, then they would have listed the TWR as such. Period. Why wouldnt they? Hell, THey would have the highest TWR of any 4 cyl. out there. But, alas, they dont. End of story.
  2. Feb 15, 2011 at 9:54 AM
    #62
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    theoretically with the same brakes as a tow equiped tacoma and all the same equipment it would be safe. Your truck will not last long with that kind of load on it, you will definatelly have problems getting going and getting up hills. But
  3. Feb 15, 2011 at 9:55 AM
    #63
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Theroreticaly, The Myans are coming back in December.
  4. Feb 15, 2011 at 10:05 AM
    #64
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
  5. Feb 15, 2011 at 10:06 AM
    #65
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That's next year 2x4
  6. Feb 15, 2011 at 10:06 AM
    #66
    borderbrat
    Jeremy
    Victoria BC, Canada
    ^this^ But it could be done. You won't be going very fast and you won't have any fun doing it. Fact is the 4 cyl just doesn't have the grunt to pull 6500 lbs at highway speeds or in any sort of terrain.
  7. Feb 15, 2011 at 10:08 AM
    #67
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    And they want a Hyundai
  8. Feb 15, 2011 at 10:43 AM
    #68
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    It is a John Deere Round Bailer, the truck is only used to move it off road around the farm. 4L is used to save the clutch, I would NEVER attempt to move it any real distance or on a road. I am not going to put that much strain on the truck. I know what strain the boat puts on it during extended tows and it is almost half the weight.
    The boat that is pulled nearly every weekend that has total weight around 2800-3000 lbs (depending on fuel), while it goes no where in a hurry and you can tell it is there the truck pulls it fine. Even on a steep boat ramp it will get it out of the water in 2H but it is struggling.
  9. Feb 15, 2011 at 10:50 AM
    #69
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dam....I gotta change my calander.....
    Figures.
  10. Feb 15, 2011 at 11:00 AM
    #70
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Given their lower frontal area than a box trailer, they are not the worst things to tow. A Typical 18' runabout is going to have less drag (all things being equal) than a car hauler, or 20' box trailer. And if the boat is uncovered, then the air going over, is going to form smal vorticies behind the windshield, much like the open bed of a truck does, and will still be more aerodynamic.
  11. Feb 15, 2011 at 11:16 AM
    #71
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    A boat is about the best thing you can tow WTF? DHK do you have any actual towing experience?
  12. Feb 15, 2011 at 11:31 AM
    #72
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    He may be beginning Engineering School, but Im not buying he's an engineer. No way.
  13. Feb 15, 2011 at 12:04 PM
    #73
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I hope I didn't fuel the fire. It's still a bad idea!
  14. Feb 15, 2011 at 12:15 PM
    #74
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not fueling the fire at all. THe last thing I would want to see, is a new guy stumble upon this site, and see dhk saying its fine to tow something over the TWR, and for them to try it, and get hurt, or someone else hurt.
  15. Feb 15, 2011 at 12:28 PM
    #75
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    my thoughts exactly...
  16. Feb 15, 2011 at 12:44 PM
    #76
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Aerodynamics are irrelevant on a boat ramp.
  17. Feb 15, 2011 at 6:51 PM
    #77
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    I pull my goose hunting rig no problems...guessing about 2200lbs...handles well in 4th gear at 55mph.
  18. Feb 16, 2011 at 6:12 AM
    #78
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Multi-quote (to the right of the quote button) is your friend
  19. Feb 16, 2011 at 6:28 AM
    #79
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    OP, congrats. You've done nothing wrong and youve exposed several hack, armchair, wannabe, 2+1=5.5 engineers."Im only grateful i didnt get quoted here. Some of them made ?Chris :mad: maaaaaddder than ive ever seen. Whenever i see a tacoma tow now, im gonna be scared from some of what i read.
    Once again , fail-tards seem to think genious is ignoring the manufacturers safe decision for towing .... and "proving" it'll do a whole lot more. Theres so many scenarios that it would be foolish to even trust one person who towed more , because he falsely believes an add a leaf a tow hitch or a gear ratio change is all you need to tow more. Those items and more only make towing the standard limit safer , easier, more reliable,or more stable...on n on. No need to overthink it , Toyota done that for us.
  20. Feb 16, 2011 at 7:18 AM
    #80
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not mad at all. :)
