2.7 litre valve clearance issue
Discussion in '4 Cylinder' started by Geezer58, May 27, 2019.
  1. May 27, 2019 at 9:29 PM
    Geezer58
    Geezer58 [OP] Member
    1997 Tacoma 4wd
    Great site!
    I’m replacing a burned exhaust valve on a 97 Tacoma 3RZFE 2.7 litre 4 cylinder.
    The valve had been pounded for some time. I cleaned up the head and checked all the other valves and found them to be in great shape. I was unable to acquire a genuine Toyota valve so replaced it with an aftermarket valve. I’ve been successful adjusting every valve except for the replacement valve. With the thinnest shim available, I can only get .004 thousandths of an inch clearance. I don’t want to put it back together like this.
    Has anyone come across this problem? My first guess is the valve seat may have been damaged and allows the valve to sit lower into the head, resulting in less clearance.
    My other options are grinding a little off the the top of the valve stem. Machining a little off the thinnest shim. (expensive). Unless I hear from anyone out there with the same problem, I’m going to try and locate a genuine Toyota exhaust valve an measure it against the aftermarket one I have. I’m hoping it may be just a few thousandths shorter , which is all I need.
    I’m looking forward to hearing from anyone with the same problem or advice.
    Thanks.
  2. May 28, 2019 at 2:47 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Grinding the stem of the valve is the right way to do this. Do not grind the shim! Almost any true auto shop will have the appropriate tools to accomplish this. Good luck
    Clearwater Bill likes this.
  3. May 28, 2019 at 7:03 PM
    Geezer58
    1997 Tacoma 4wd
    Thanks for the reply John.
    I’ll let you know how I make out.
    To satisfy my own curiosity, I’ve ordered a genuine Toyota valve, and I’ll use it regardless if it needs to be shortened or not.
    I may have to wait a while until it shows up.
  4. Jun 1, 2019 at 6:37 PM
    Geezer58
    1997 Tacoma 4wd
    Just received the genuine Toyota valve today and after measuring it’s total length, knew it was going to work. It’s at least ten thou shorter than the aftermarket valve. Had it installed and adjusted in no time.
    In this case, it payed to stick with original parts....
    sunchip89 and Tacorific like this.
