2.7 LUK clutch replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yota13, Sep 6, 2013.
  1. Sep 6, 2013 at 9:22 PM
    yota13
    yota13 [OP] Member
    Pretty sure my 13' base model has the LUK clutch..
    Shifting is notchy, engagement is weak and flaky. The truck has almost 12k miles now and the shifting has gotten a little better but the engagement is still bad, So I'm going to replace it. would this exedy kit work?
    it says 05-07 only but it should work my 13' right? Thank you for any help.
  2. Sep 7, 2013 at 3:31 PM
    yota13
    yota13 [OP] Member
    bump
  3. Sep 7, 2013 at 3:42 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    The site from the link you provided says it is not compatible with '13. What makes you think it would be?
  4. Sep 7, 2013 at 4:25 PM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    Ive got the same one in my 4.0 - For onroad driving its good, but offroad and crawling with 4x4, its a bit weak. Got even worse when I upgraded to bigger tires. Mine is probably near its end. They pressure plate is weaker.
    Ill most likely go URD when I get enough $$ to replace it.
  5. Sep 7, 2013 at 7:57 PM
    yota13
    yota13 [OP] Member
    Toyota has used 2TR-FE w/ R155 trans in all 2nd gen 5 lugs.. So the flywheel and clutch should be the same regardless of the year, no?
