2.7 misfire help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by evansjos, Feb 26, 2012.
  1. Feb 26, 2012 at 9:52 PM
    evansjos
    evansjos [OP] Member
    MS
    04 Tacoma 2.7
    Hello all. Long time listener, first time caller. I have an 04 Tacoma with the 2.7 and about three weeks ago I was backing a four wheeler trailer up an incline and dumped the clutch a little quick and the truck died. It happens, right? Well, later that day the CEL came on and when I scanned it the code was PO303 and another one I don't recall for a vacuum leak. I cleared both and chalked the misfire up to my killing the truck and the vacuum leak to remembering that I filled up with gas a few days earlier while the truck was running.
    However, after driving around for a week, the CEL came back on for PO303. I swapped coils on 2 and 3 and cleared it again. Another week goes by and the CEL is back on for the same thing. So, after swapping coils the misfire stayed in 3, which should eliminate that as a possibility. Today, I pulled the plugs from 2 and 3 and, while normal, the plug in 3 was slightly more fouled than the one in cylinder 2. They're OEM plugs and they have less than 10,000 miles on them.
    Here's the thing: Even though the computer says its a misfire code, I never hear or feel a misfire. I swapped coils and plugs and it stayed in 3. What's my next step? A compression or vacuum test? Or, could it be an injector, and if so, what's the best method for testing one?
    Any help you folks could give would be much appreciated. This is driving me crazy.
  2. Feb 26, 2012 at 9:54 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Replace wires.
  3. Feb 26, 2012 at 9:58 PM
    evansjos
    MS
    04 Tacoma 2.7
    Maybe I should have clarified but I have coil packs or maybe I'm misunderstanding you and are you referring to the wires connecting to the coil packs?
  4. Feb 27, 2012 at 11:55 AM
    evansjos
    MS
    04 Tacoma 2.7
  5. Feb 27, 2012 at 12:52 PM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Hmm, what happens if you swap the plugs between 2 and 3?
    Double check all connections too where you have had things apart to look at it/diagnose.
    Is the vac leak still showing? Does not hurt to double check them and condition.
  6. Feb 27, 2012 at 1:46 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yeah im talking about your plug wires. The wires that go from the coil packs to the spark plugs
  7. Feb 27, 2012 at 2:30 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    Depending on mileage #3 cylinder is usually the first to lose compression due to a tight valve which in the end will require you to get a valve job, if left unchecked for very long.
    Being that your driving an 04 2.7 it shouldnt have wires, its a COP system.
    Change spark plugs and if problem persists do a compression test and go from there.
  8. Feb 27, 2012 at 4:27 PM
    evansjos
    MS
    04 Tacoma 2.7
    Thanks guys. Will do the compression test next.
  9. Feb 27, 2012 at 4:34 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    What spark plugs are you running? If they are platinum, there's your problem.
  10. Feb 27, 2012 at 4:43 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    While under the hood, do a double check for blown vacum lines and caps. When you stalled backing up a hill, your engine was turned backwards for a revolution or two before you applied the brake. This will blow vacum lines.
  11. Feb 27, 2012 at 6:06 PM
    scotrinaf
    scotrinaf Well-Known Member
    Scott
    Blountville, TN
    04 PreRunner TRD SR5 4x2 2.7L
    Leer 100XQ, Yakima Roof Racks
    I have Coil Packs, and you can't just buy the wires (or so I was told at the parts stores) and the Coil Packs are $85/ea +/-...
  12. Feb 27, 2012 at 7:42 PM
    evansjos
    MS
    04 Tacoma 2.7
    The spark plugs are stock Denso's. When you say vacuum caps, what exactly are you referring to? Is there any vacuum line that would only affect the #3 cylinder?
  13. Feb 28, 2012 at 2:31 AM
    wolftree
    Rick
    Ohio
    If you have a vacum stem posts(tree) on the engine, if they do not use all of the ports, they put a cap/plug on it. I doubt any one vacum line affects only #3 cylinder, but it could make the computer think it did.
