2.7 mpg and shift points
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtragweed, Jan 18, 2009.
  1. Jan 18, 2009 at 3:58 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    my 08' 2.7 4x4 is getting somewhere around 400 miles per tank. during the summer i was getting somewhere around 450-475 per tank. im not sure if its my shift points or what it is, anyone else notice this. what rpm range are yall shifting at and finding the best mpg and what speed is giving you the best mpg, i find on the interstate going 70 my tank seems to drain a little faster, i figure it would be better but im not so sure!
  2. Jan 18, 2009 at 4:00 PM
    Krp2nite
    Krp2nite Well-Known Member
    winter blended gas will change your mileage for a negative effect. At least it seems to in the NE.
  3. Jan 18, 2009 at 4:06 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    well. i have the 2.7 Automatic regular cab. I just try to keep it under 2k RPMs and im good to go. But KRP2nite does have a point about the winter gas blends being treated to help with Cold weather Starts. I range from 390- to around 400 MPG. of course the PRO dry S filter does help out some.
  4. Jan 18, 2009 at 4:11 PM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    I usually shift at 2k and yes to the above statements about winter fuel.
  5. Jan 18, 2009 at 4:21 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    what speed on the hwy are you gettin the best mpg
  6. Jan 18, 2009 at 4:25 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    For shift points, I usually take it to around 2500-3k depending on what gear I am in.
    I usually only get around 340 miles to a tank considering I have the PreRunner & drive in the city alot, although a recent trip to austin and back + some city driving yeilded about 390 miles on 17 gallons.
    Drove about 70 all the way to Austin, RPM was at around 2700 rpm.
  7. Jan 18, 2009 at 4:36 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    not bad man
  8. Jan 18, 2009 at 4:42 PM
    Wren
    Wren Well-Known Member
    Josh
    Williamsburg, Ky
    11 White Reg. Cab 4x4
    i've also noticed quicker fuel draining, even in my moms 08 Infiniti G35 so the winter gas is probably the cause
  9. Jan 18, 2009 at 4:48 PM
    SC4333
    Grant
    San Antonio, TX
    Nope, it was the best one to date. Oddly enough, the ecu had just been reset due to some electrical work I was doing. Maybe it was running a little lean?? This tank went down the crapper, I've been doing alot of short drives and lots of stop and go city driving.
    All in all I average around 18.5 to 19.5 mpg 50/50 city/highway mix
  10. Jan 18, 2009 at 4:55 PM
    mikeyramone
    mikeyramone 220 - 221 Whatever it takes
    Westfield,Ma
    2005 4X4 TRD Sport Speedway Blue
    Sylvania Silverstar headlights, vent visors, Advantage Tri-fold tonneau cover, pop n lock, Sirius radio, auto dimming mirror, AFE Pro-Dry air filter, secondary air filter removed, Magnaflow muffler, Hood scoop decals, Painted grill, Devil Horns!!!
    not sure about newer Toyotas but the older ones will not shift into overdrive until the coolant temp. gets to a certain temp causing you to run in third or fourth gear longer depending on your tranny.
  11. Jan 18, 2009 at 6:45 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    I usually shift from first to second in the 2500 rpm range, after that I try to shift around 2000. My last fill-up I went about 376 miles (city), and still had 2.6 gallons in the tank when I filled up.
    When I first got the truck I would top up the tank as much as I could. The past couple fill-ups I've stopped when the pump stops, and I've noticed 2-3 mpg increase. Don't know why that would make a difference, but it seems to for mine.
    I've noticed that I get better mileage in the summer in every vehicle I've owned.
  12. Jan 20, 2009 at 2:34 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    i shift around 2K, but i have a 5 lug...different gearing...
