2.7 no oil pressure
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4x41980, Feb 19, 2020.
  1. Feb 19, 2020 at 7:56 PM
    4x41980
    4x41980 [OP] New Member
    1995 toyota Tacoma
    Lift,dif,intake,exhaust,ac.removal
    What's up fellas.
    Having some issues with no oil getting to the top end. Just put a new timing chain in and oil pump.
    Not sure what going on. I did take out the oil pressure sensor unit and installed a oil pressure gauge. Not showing anything on the gauge. I'm all ears!
  2. Feb 19, 2020 at 8:05 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Is the gauge bad or did you confirm there is no oil getting to the top end.
  3. Feb 19, 2020 at 8:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Any older Toyota, remove the pan, clean the oil sump pick up screen. They get clogged with time.
    Anytime I see low pressure I head right for the screen.
