2.7 Oil change
Discussion in '4 Cylinder' started by Teuton, Aug 19, 2016.
  1. Aug 19, 2016 at 5:47 AM
    Teuton
    Teuton [OP] Well-Known Member
    2011 Reg Cab 4x4, 2021 TRD sport, 2024 TRD Sport
    Hello,
    Just got a new to me Tacoma and took it to the dealership for an oil change the other day. yesterday while driving i notice blue smoke coming out of the exhaust. I check the oil and its way overfilled. A Solid 2-3 inches over the fill line on the dipstick.
    I look back at the receipt and notice they charged me for 7 quarts, so I call the dealership to confirm how much oil they put in. They tell me they cant remember but if it says 7 quarts on the receipt, thats what they put in.
    So I drain the oil out and sure enough about 7 quarts drain out of the pan (didn't touch the filter).
    So my question is, how much oil does the standard OEM Tacoma filter usually hold and how much do I add? The dipstick is absolutely worthless and I cannot get a clear reading.
  2. Aug 19, 2016 at 7:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    I wouldn't worry about how much the filter holds if you're refilling it. It's a negligible amount; say maybe a cup and a half at most.
  3. Aug 19, 2016 at 7:15 AM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    In total, my 2.7 (inc filter) takes around 5.5 quarts.
    I dump in a 5-quart just after putting on the new filter, spin the motor a few seconds to circulate the fluid, let it sit 2 minutes, and then top off with a quart container. About half of it or so and we're in good shape. Then I put that aside to use with the next change and its usually get about perfect.
  4. Aug 19, 2016 at 12:37 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    the manual says 6.1 quart with filter, I use 5.5 quarts with filter
    OhioTaco68 likes this.
  5. Aug 19, 2016 at 6:34 PM
    Teuton
  6. Aug 19, 2016 at 6:40 PM
    Xaks
    Xaks
    Oklahoma City area
    Not sure what year yours is, but in my 2006, I use the 5w-30 and it works well. You must live at the ass end of the world to need 0 weight. And this is coming for a native Wisconsinite!
  7. Aug 20, 2016 at 12:10 AM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    My 2004 2.7 takes around 5 quarts but it depends on how level the concrete is where I change it. If it's level it can take 5.5 qts with the oil filter filled. The best thing to do is follow the dip stick. That's what the dealers do from what I have read. I fill the filter until it's full and then add 5 qts. On level ground if I can find it. Then I run it and check it on level ground by the dipstick. Add or subtract as needed. Very rarely can I get it just right. At this point in time the dipstick reads about 1/2 qt. high and there is no problem at all since it usually reads high except when I get it just right. From what I have observed a half a qt high or low doesn't hurt anything.
    Trust the dip stick on level ground.
  8. Aug 20, 2016 at 8:02 AM
    Mush Mouse
    mush
    2013 SR5
    this is what I do, from what I read if you use the recommended 6.1 quarts it will be well over the dipstick FULL line, where 5.5 qts. works with the proper dipstick reading
    Fredness likes this.
  9. Aug 20, 2016 at 7:39 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    That is on the '13 not the 2016 right? I believe I read in the manual the '16 requires 6.2 quarts.
  10. Aug 20, 2016 at 7:41 PM
    Mush Mouse
    mush
    2013 SR5
    most 2.7l 4 bangers are overfilled with 6.1 qts. says the dipstick not quite sure if Toyota remedy this for the 2016
    CusterFan[QUOTED] likes this.
  11. Aug 21, 2016 at 8:11 AM
    CusterFan
    I'll find out in November when I go in for one of my 2 free oil changes. I know the oil level is hard to see on the stick. A guy told me he pulls his out for 10 minutes or so till the oil runs out of the tube, then checks it. I have been going by "Faith" myself, (That it has oil in it)
  12. Aug 21, 2016 at 11:19 AM
    Mush Mouse
    mush
    2013 SR5
    m
    I got the hang of reading the dipstick its a little more harder when the oil is clean, but after a few miles when it gets darker you can see it better when I use 5.5qts. its pretty much dead money full on the dipstick, I am running a 10k OCI on my truck with MOBIL1 EP formula and an OEM YZZD3 filter its too much a pain doing it every 5k miles, I probably have the oil analyzed but maybe not, Im searching online to see if anyone does this extended OCI with their 2.7l.
  13. Aug 22, 2016 at 7:42 AM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    I go by the manual and fill the recommended 6qts. No issues at all.
  14. Aug 22, 2016 at 12:49 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Did the dealership say where they got "7 quarts" as the correct capacity? That's what I would be wondering.
    Agreed, the dipstick is not the best ever designed. Here's what I do. Pull out the stick and keep it out for about 10 minutes while all the oil drains from the dipstick tube down into the pan. This is the real problem: when you pull out the stick, it smears oil on the inside of the dipstick tube. So if you insert a clean stick right away, the stick gets oil all along the bottom length and a good reading is difficult. So if you keep the stick out, and wait for the oil to drain out of the tube, your next reading will be clearer.
    The manual for my 2006 says to add engine oil "if the oil level is below or only slightly above the low level." In my experience, an oil level anywhere between the two marks is fine *for normal driving.* Some people insist that the oil level be at the top mark but it is not necessary. Maybe if I did a lot of towing, hauling, off-roading, etc. I would fill it to the top mark. But I don't. With a new filter, one 5-quart jug fills it to the middle between the marks. Done.
    CusterFan likes this.
  15. Aug 23, 2016 at 2:31 PM
    CusterFan
    The 2016 manual says the same thing about the safe level between the dots on the dipstick. And I'm going to try the way you described checking the oil by leaving the dipstick out for 10 minutes.
