2.7 Oil Filter Removal
Discussion in '4 Cylinder' started by monoman, May 3, 2023.
  1. May 3, 2023 at 12:41 PM
    monoman
    monoman [OP] Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    All you guys with the 2.7 engine, how do you change out the oil filter without getting oil all over your arm? I tried the plastic bag trick where you wrap a bag around the filter while spinning it & oil still gets all over. Is there an easier way, or any special tool you can use to remove the oil filter without the mess? What do you guys do? Thanks.
  2. May 3, 2023 at 12:55 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Good idea. I like the notion of punching the hole. You could also use a cup to spin it loose.
    69 Jim likes this.
  3. May 3, 2023 at 12:59 PM
    monoman
    Dave
    Hmmmm, punching a hole on the bottom. Great idea! ;)
  4. May 4, 2023 at 4:42 PM
    maverick4x2
    maverick4x2 Well-Known Member
    2013 Tacoma 5 lug
    ^ if you're quick you can do it without getting oil anywhere but your glove. No need to do anything special.
    If you do the cup method, do yourself a favor and use one of the clear 20oZ ones, it will actually contain most of the oil unlike a 12oZ solo cup.
  5. May 5, 2023 at 3:22 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I’ve used a gallon size zip-lock bag in the past and it works well enough.
    Now I use a large funnel (8” dia.) and place it under the filter. I have a piece of clear tubing attached to the funnel tip so that it will go into my drain pan. While holding the funnel in place, unscrew the filter and all of the oil drains into it. The filter can drop right into the funnel.
  6. May 5, 2023 at 8:36 AM
    monoman
    Dave
    OK. So you do this from under the truck then or from on top?
    Hardscrabble[QUOTED] likes this.
  7. May 5, 2023 at 4:06 PM
    acgreen01
    acgreen01 Well-Known Member
    Andrew
    2012 silver 4wd regular cab
    I use a large McDonald's cup to do mine. Haha
    e6400ultra, 69 Jim and maverick4x2 like this.
  8. May 6, 2023 at 5:01 AM
    Hardscrabble
    Scott
    McDonough, GA
    I do this from under the truck.
    I always raise the truck and support it with jack stands when I’m changing the oil.
    davidstacoma likes this.
  9. May 6, 2023 at 7:58 AM
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    Oil Udder XL for me. Perfect fit and zero drop. Just slowly twist and remove. Speed is your enemy.
    TacoMike, dawgn86 and monoman[OP] like this.
  10. May 6, 2023 at 10:07 PM
    monoman
    Dave
    I think I might try this one out. Thanks! :thumbsup: Do you use the 3 inch?
  11. May 7, 2023 at 1:06 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Hardscrabble likes this.
  12. May 7, 2023 at 6:04 AM
    MoneyB86
    Reagan Country, CA
    4.5
    monoman[QUOTED][OP] likes this.
  13. May 8, 2023 at 2:44 PM
    maverick4x2
    2013 Tacoma 5 lug
    genius, never see that before
    426563 and monoman[OP] like this.
  14. May 22, 2023 at 4:38 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
  15. Jun 13, 2023 at 2:50 PM
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    All you need is a piece of cardboard. Use a wrench to crack the filter just loose enough to unscrew with your fingers. Then hold the cardboard along the side of the engine and twist the oil filter slowly and then stop and let it drip. Once the majority of the oil has rushed out finish twisting the filter off, while keeping it upright. :thumbsup:
    DGXR likes this.
  16. Jun 19, 2023 at 8:05 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    I bought one, it will not work without replacing the clamp, the included clamp is way too big to fit the filter. And even if the clamp did fit, the tap sits too high on the filter to fully drain it. Sadly, not worth the money at all.
    I have found that spinning the filter off into an empty 32oz yogurt container is the best mess-free option.
  17. Jun 19, 2023 at 8:40 PM
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Thanks for letting me know, i guess i will stick with my ziplock bag method
  18. Jun 23, 2023 at 6:01 PM
    Starman2112
    Starman2112 Well-Known Member
    2018 SR5 AC 4X4 Blazing Blue Pearl
    Cut off about the bottom 1/4 of a 2 liter soda bottle. Works great!
  19. Sep 7, 2023 at 5:08 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "Speed is your enemy" Like this quote !
  20. Sep 14, 2023 at 6:41 PM
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    Form-A-Funnel works great for me. It's rubber with wire inside that you can bend to fit the shape you want.
    https://formafunnel.com/
    JGO likes this.
