2.7 Oil Filter Removal
Discussion in '4 Cylinder' started by monoman, May 3, 2023.
  1. Oct 2, 2023 at 2:28 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I make my own form-a-funnel, using cardboard. I cut mine to approx 6" x 10", loosen the filter slightly then stuff the short edge up between the filter and the engine block, then loosen the filter some more and let it drain onto the cardboard. The width will fit between the two crossmembers just below the filter. Works great.
  2. Nov 26, 2023 at 3:53 PM
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    easiest way is a clear plastic cup, perferably a medium. loosen filter enough so your hand is able to twist it, no oil should be pouring out yet just get it loose. using a sharp but strong enough poker, poke hole in lowest point of the filter while holding the cup under the filter. wait til oil drains into cup, once its a drip hug the filter with the cup and twist it off using the cup. zero mess, not even a drop anywhere. all other ways explained here are obsolete and idiotic. costed me maybe a couple cents for the cup and have used it for multiple oil changes up to 160k miles so far with the same cup. reading some of the posts here is complete cringe, cardboard funnel..really? o_O
  3. Nov 28, 2023 at 2:15 PM
    4Cylinders
    4Cylinders Well-Known Member
    Anthony
    2023 Tacoma 2.7L 4x4 Auto
    How do you poke a hole in the bottom of the filter and still get all of the oil in the cup? Won't the oil start pouring straight down out of the filter once you poke the hole? Sounds messy. Sorry if I'm missing something.
    Steves104x4 likes this.
  4. Nov 28, 2023 at 2:39 PM
    DGXR
    Friend
    Sacramento, CA
    The oil will start pouring out as soon as the nail (or screw, or punch) is removed from the oil filter. This allows time to place a receptacle under the filter to catch the oil before you pull the nail. Well, maybe a screw isn't the best thing to use, but you get my point.
  5. Feb 2, 2024 at 12:11 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  6. Feb 17, 2024 at 9:13 PM
    monoman
    monoman [OP] Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
  7. Feb 18, 2024 at 2:11 PM
    george3
    New Jersey
    Glad to hear it !
    monoman[QUOTED][OP] likes this.
  8. Mar 27, 2024 at 11:29 PM
    Wolfe 21
    Wolfe 21 Member
    Not a toyota, but my chevy has a small drain rail from the area under where the filter screws onto the block along the pan to about 2-3 inches short of the drain plug. Most of the oil from my filter runs down it into the drain pan. It's a 20 plus year old engine (S10, 2.2l non ecotec) I would imagine is available in most scrap yards or pull a parts. I would think this little rail could be adapted to your engine or at least used for a pattern to fab your own.
    I honestly never thought of it as anything because I've always had it.
  9. Apr 20, 2024 at 2:35 PM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I use a plastic cup that fits over it. I crack it loose first and then unscrew by hand with the plastic cup in place.
  10. May 27, 2024 at 9:24 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    This. Hold the cup an inch or two below the filter and reach above it to spin the filter off allowing it to fall into the cup. I have small hands but it’s still not a problem. If you allow plenty of drainage time the filter mount won’t even drip and you’ll get more of the old oil out.
  11. Jun 20, 2024 at 7:13 AM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
