2.7 Oil Overfull
Discussion in '4 Cylinder' started by 2TRunner, Nov 4, 2010.
  1. Apr 9, 2011 at 2:37 PM
    #41
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    The reality is the stick is wrong, or the spec is wrong, or both are wrong. Since Toyota has never clarified it they probably think it doesn’t matter. But if the spec says 6.1 and the factory fill is 6.1 but the stick is 5.5 (or whatever since it can’t be read easily) then 2 points out of 3 say 6.1.
  2. Apr 10, 2011 at 6:12 AM
    #42
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I don't get it. Why does the owners manual, alldata etc call for 6.1 qts and mine really takes 5.5 or less. If I were to put in 6.1 it would be way over filled. Toyota doesn't know how much oil their 2.7 takes :eek:? Don't make no sense.:(
  3. Apr 10, 2011 at 7:12 AM
    #43
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    IMVHO the 6.1 figure is for a dry fill. Most DOHC engines retain large amounts of oil in the heads around the valvetrain. If your 2.7L does not use or leak oil just put in 5.5 quarts and save some natural resources for the next generation.
    Even 5.5 qts will register above the full line on my stick. In the end do what you want, it is a free country for a bit longer.
  4. Apr 10, 2011 at 7:46 AM
    #44
    george3
    New Jersey
    Thanks for the reply "retain large amounts of oil in the heads around the valvetrain" is the answer. I got to make a note to myself - 5.5 - I'm using synthetic and don't remember 6 months down the road - look it up in the owners manual (6.1) and get it wrong again - Dah :(
  5. Apr 10, 2011 at 7:58 AM
    #45
    rydaniels
    rydaniels Well-Known Member
    South Jersey
    4x4 4cyl manual
    bone stock except tool box in bed
    I had trouble with the same thing ..the manual said 6.1 qts but I compared that to what came out of the engine and it was a little above 5 qts then what ever the oil filter gave...I threw in 5 qts (the jug) and the dipstick reads a tad below the full line...just need to use some reasoning
  6. Apr 11, 2011 at 11:45 AM
    #46
    Tacoma of Souls
    Tacoma of Souls Member
    Nova Scotia, Canda
    exhaust gas recirculation..... bleh!
  7. Apr 11, 2011 at 12:08 PM
    #47
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    not sure why alot of people are filling the filter but w/e. What the manual say is for a dry engine no oil at all in it. Like some people have said oil hides in alot of places in engines. Be careful of overfilling, as there is a small chance that you can hydro lock your engine although unlikely. Me personally when I change the oil I run the truck for a few mins, drain, change the filter, fill until it's at the full mark of the dipstick, run check for leaks and shut it down. then before I go anywhere I take a second to check the oil after it has settled back into the pan. It usually reads just a hair below full as the filter does hold a little bit of oil.
  8. Apr 11, 2011 at 1:16 PM
    #48
    george3
    New Jersey
    5.5-3=2.5:eek::eek::eek:
  9. Apr 12, 2011 at 4:16 AM
    #49
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Until someone clarifies whether the stick is too long or not, then this shit will just keep going on and on with nothing but opinion. Half a quart low, if the stick is indeed too long making 6.1 fill way above full mark, is not gonna hurt anything so until there is more than conjecture and supposition about this I will be going with oem filter and 5.5 quart fills.
  10. Apr 12, 2011 at 7:58 AM
    #50
    borderbrat
    Jeremy
    Victoria BC, Canada
    8000Kms 5000miles. Thats what my manual says anyway.
  11. Apr 12, 2011 at 1:56 PM
    #51
    george3
    New Jersey
    Thanks for the reply. Curious - What do you base all this on ? Does Bob the Oil Guy or somebody else agree with this ?:confused:
  12. Apr 12, 2011 at 6:28 PM
    #52
    Drogers
    Drogers Well-Known Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Leer 100XR Topper, Re-wired interior dome light, Shaved front mud flaps, Rebadged flat black, Avid offroad light/bull bar, Yellow OEM Fog Light Mod, 265/75R16 Nitto Terra Grapplers, stock 16 steelies painted flat black, K&N air filter
    I use 5.5 quarts
  13. Apr 13, 2011 at 4:09 PM
    #53
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    5.5 with filter for me as well with Mobil 1 syn 0w 20 with Mobil 1 or stock filter
  14. Apr 21, 2011 at 4:18 PM
    #54
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Anywhere between the marks or even a little over full mark is fine -- the "safe" range leaves a lot of cushion on either end. Like the last few entries, my personal experience is 5.5qt with a new filter is just about perfect. If it's a high-end filter I'll leave it on for one extra cycle and then I add 5qt even. (I have some cheap but strong rare earth magnets on the filter canister to help catch some stuff before the filter media.)
