2.7 or 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bayoutaco, Jun 1, 2011.
  1. Jun 2, 2011 at 6:29 PM
    #81
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    What about people who own a gun, but dont intend on shooting people?:rolleyes:
  2. Jun 2, 2011 at 8:00 PM
    #82
    bayoutaco
    bayoutaco [OP] Member
    i liked the looks of the off road package, and im not saying ill never need to use it, im glad to have the locker and all the off road equipment should the need ever arise.
  3. Jun 2, 2011 at 8:13 PM
    #83
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Don't see your point. E load tires are designed for hauling a lot of weight...like 3k+ lbs. Something no Tacoma can do.
  4. Jun 2, 2011 at 8:24 PM
    #84
    bayoutaco
    MY point?
  5. Jun 2, 2011 at 8:26 PM
    #85
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Try to find an MT in a 285 that's not E rated
  6. Jun 2, 2011 at 8:27 PM
    #86
    OZ-T
    Peter North
    British Columbia
    He was responding to another poster
  7. Jun 2, 2011 at 8:31 PM
    #87
    bayoutaco
    oh ok my bad lol.
  8. Jun 2, 2011 at 8:43 PM
    #88
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I have the 2.7L 5spd, AC and love it, but no one asked you if the other 09 4.0 AC TRD truck was a sport or offroad model? This makes a big difference and could sway your decision from the 2.7L vs the 4.0.
  9. Jun 2, 2011 at 8:45 PM
    #89
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    air down a p rated tire and see how long the sidewall lasts... yes load e is for hauling alot of weight but this is due to sidewall strength.
    e load is a 10 ply sidewall rating...
  10. Jun 2, 2011 at 8:47 PM
    #90
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^Exactly right, and that's why I put P rated Destination AT's on my poser mobile: I will never air them down.
    I always find these "Why get this or that if you aren't going to do/need X?" discussions fascinating because it boils down to one answer, really: It's my money and I bought what I wanted.
    I still like Nathan's hot dogs the best.
  11. Jun 2, 2011 at 9:24 PM
    #91
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x10
  12. Jun 2, 2011 at 11:19 PM
    #92
    Scott K
    Scott K Well-Known Member
    Scott
    Coquitlam, BC, Canada
    Amsoil Synthetic ASL 5w30 Oil, Amsoil ATL Fuel Efficient ATF, Amsoil Severe Gear 75w90 in front/rear diffs & transfer case.
    I'd get the 2.7 myself, personally.
    And I own a 4.0 Double Cab 4x4 Long Box 5 speed auto.
    I used to own a 1993 3.0 liter V6 3vze (150 HP/180 lb TQ) XtraCab 4x4 Pickup 5 speed manual for nearly 5 years and I have test driven
    a Tacoma Access Cab 4x4 5 speed with the 2.7 and the 2.7 was a bit more powerful (164 HP/183 TQ - at the time - this is apples to apples using the same engine HP ratings for each truck - the way they are rated today is different with 159 HP and 180 TQ), and had much better throttle response at the time and I essentially got to do a back to back comparison at the time.
    While I appreciate the 4.0 liter I have in the power department, and the mileage is about the same as my 3vze equipped truck (they weigh fairly similar to each other), however the 4.0 has more power obviously, I'd still take the 2.7 4 cylinder in your application.
    If you have doubts in the power department, there are some high quality aftermarket mods, such as the LCE headers available as well as several exhausts, that not only will give you a bit more cajones, but also make the engine even more fuel efficient.
    Also, don't be afraid to put the 2.7 to work. With some decent fluids (aka high quality synthetic oils) and regular maintenance, this engine will do you proud if you're not afraid to make it do what engines are supposed to do. I never abused my 3.0 liter V6, in my old xtracab 93 pickup as I maintained religiously with top of the line Amsoil synthetic fluids, but I can tell you it was geared quite a bit lower stock, than the Toyota trucks of today. The stock rear end was 4.56 with the 5 speed manual with 31" tires so at highway speeds I was turning between 2700 and 3200 RPM's. I drove 17 hours home from a fishing trip up north in 2005 and the entire way, about 1000 miles or so, I had that engine pushing 3000 RPM's plus/minus 200 RPM's depending on the stretch of highway. It just happily purred along smoothly getting us home without a hiccup, with over 150,000 miles on the engine at the time. I sold that truck to my Uncle in 2009 with well over 200,000 miles and the engine ran like a top. My uncle, ironically, was using my 93 as a replacement for his 95 Pickup, which was indentical to mine, even in colour, which had well over 250,000 miles on his, and he passed it on to his son, and he couldn't see himself driving any other model of truck.
  13. Jun 3, 2011 at 3:31 AM
    #93
    zxtaco636
    zxtaco636 Well-Known Member
    Southeast, US
    Prerunner SR5 TRD Off Road
    20% Tint all around, Debadged, Grill badge blacked out
    The 2.7l has some power but obviously it is not equal to the 4.0l. The 2.7l has enough power to pull around an access cab with no problem, and you will also have enough power to pull around a light trailer. If you are more worried about fuel economy the 2.7l is definitely the way to go, just my thoughts though.
  14. Jun 15, 2011 at 9:03 AM
    #94
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Tell me that in 30 years.
  15. Oct 10, 2011 at 9:31 AM
    #95
    itsryan
    itsryan Active Member
    Chino Hills
    11 4banger 4x4 SR5- sold
    2.5i 2015 Subaru Outback
    2.7 all the way. i also had the same decision between i4 and v6. I have driven the 4.0 liter a lot, my dad had one for awhile and it does have a lot of power but not as much as my Chevy 2500 with a 450 block which can move a house if a wanted lol :D. But I am happy with the 2.7 however, i get 22 city driving and 24-25 on open highway.
    5 speed all the way, better for off roading, racing (not in 2.7 lol), and fuel efficiency. the only time i would say auto tranny is better is when im stuck in LA traffic, or in a v8
