2.7 Rough start, white smoke
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wrightscreek, Dec 16, 2016.
  1. Dec 16, 2016 at 11:30 AM
    Wrightscreek
    Wrightscreek [OP] Member
    '96 2.7 4WD
    Heeey everybody,
    I got in my truck today after it sat for a couple days and cranked it up only to have it cut off as soon as it turned over. After that, it took a couple long tries to get it started. Once it was running, there was a small amount of white smoke from the exhaust which increased when I stomped the gas. After it ran for little bit (maybe a drove it a half mile), the smoke was gone. I checked the oil and it doesn't (appear) to have any coolant in it and the level is good. Any ideas?? It only has 113,000 on the original engine...
  2. Dec 16, 2016 at 11:41 AM
    Markcal
    Markcal Well-Known Member
    Maybe water in the fuel tank??
  3. Dec 16, 2016 at 11:50 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    blueish white smoke is typically oil, white smoke is coolant...might be a head gasket going in your future.
  4. Dec 16, 2016 at 12:29 PM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    Was the outside air cold or humid? Are you sure it wasn't condensation given the outdoor temperature? Also, has it overheated recently? If so, a HG may be a problem (leakdown/compression test is in order). If not, check your coolant in the radiator for oil.
    mechanicjon likes this.
  5. Dec 16, 2016 at 1:17 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Sure it's smoke and not steam?
  6. Dec 16, 2016 at 2:23 PM
    Wrightscreek
    '96 2.7 4WD
    It could have been water vapor, I suppose. I live on the Gulf coast and we have had huge temperature fluctuations in the last couple weeks...and we typically have at least 90% humidity. Currently, its about 73F outside.
    Would that keep it from starting up though?
    Hasn't been overheated since I bought it, but that was a whole 8 months ago..
    If it does it again I will definitely be running a compression test and try to find a leak.
  7. Dec 16, 2016 at 2:30 PM
    Markcal
    Those are fightin words around this here parts!! :mad: :frusty: :infantry:
  8. Dec 16, 2016 at 3:51 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    0 here this morning.
    Agree with the coolant leak hypothesis. If a bad or failing gasket, it's going to continue. Keep a look out.
  9. Dec 16, 2016 at 4:29 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Pull the plugs. They will tell you real quick of what your engine is doing.
    Find a super clean one? Coolant steam cleaned. No good.
    Find nothing but normal plugs........condensation build up in the exhaust. Especially in humid environments.
    Find sooty plugs......burning rich (O2 sensor failure)
  10. Dec 16, 2016 at 6:16 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    You DON'T want to know the temperatures here in Scottsdale Az. But I will tell you the humidity is about 15-20%
  11. Dec 16, 2016 at 6:19 PM
    Markcal
    Yeah, if you tell me your temperature, I might blow my own personal head gasket. :pout:
    mechanicjon[QUOTED] likes this.
  12. Dec 16, 2016 at 6:33 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  13. Dec 16, 2016 at 6:36 PM
    Markcal
    OK, you took me over the edge and have my drone over your house in AZ = :crapstorm::crapstorm:
  14. Dec 17, 2016 at 7:46 AM
    Wrightscreek
    '96 2.7 4WD
    It started right up this morning with no issues. Revved it up for a while and it started pushing out a lot of steam to the point that it was consistently dripping.
    Just for fun I pulled all the plugs and they looked consistent and good.
    Time will tell if it was a false alarm I guess! I may be a tad bit paranoid since I haven't owned it very long..
    Thank y'all for the info!
  15. Dec 17, 2016 at 4:02 PM
    CD20H
    Ben
    North Texas
    Understandable.
  16. Dec 19, 2016 at 5:41 AM
    GA-3RZFE
    Keep an eye on your Power Steering Fluid level. If you notice the smoking continue (especially in the afternoon when the outside temp has warmed up, or humidity drops), you may be seeing PS fluid burning (I have been there). The High Pressure line has a small vacuum valve on it, with two (2) vacuum lines running to the Intake Manifold/Throttle Body, if you pull those lines and find fluid in them (from the valve on the high pressure PS line), it has failed and you are burning PS fluid in your cylinders. It was blowing white smoke on my 2.7L after I rebuilt the motor. That part is ridiculously expensive, but I can post the part number if you need it.
    You will know if you are low on PS fluid. When you turn full lock it will whine like crazy.
