2.7 severely under powered... Anyone have this problem?
Discussion in '4 Cylinder' started by mntbiker2008, Dec 25, 2014.
  1. Dec 25, 2014 at 3:11 AM
    mntbiker2008
    mntbiker2008 [OP] First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    I'm trying to help my dad out with his 03 tacoma 2.7. He recently had the egr line blow off so he fixed that but now the truck seems like it's only running on 2 cylinders. With your pedal to the floorboards it can barely get passed 30mph. Im going to check spark this weekend but is there anything else you guys recommend looking at? Not getting any cels either. Im puzzled.
    Thanks in advance
  2. Dec 25, 2014 at 5:59 AM
    bobbyhill
    bobbyhill Active Member
    mark
    Riverside CA
    08 2.7 5 speed
    Magnaflow muffler, push bar, 3 inch lift kit, 31 inch tires,icon rims15x8, black mess grill,32inch light bar
    Does the truck have a rough idel or fluctuate rpms when ur ideling. If it does you can not be getting the right mixture. Air fuel wise.
  3. Dec 25, 2014 at 6:00 AM
    bobbyhill
    mark
    Riverside CA
    08 2.7 5 speed
    That can be a cause loss of power.
  4. Dec 25, 2014 at 10:57 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    High mileage? Venturing a guess here.
    Did the EGR blow off the exhaust manifold? If so it could be a clogged catalytic converter. Backpressure would've caused the EGR line to blow off. It was able to evacuate exhaust with the egr line off. Now that it's fixed it can't push out exhaust gases.
    Although I think a clogged cat might have thrown a code before completely clogging up.
  5. Dec 25, 2014 at 11:00 AM
    PatrukZ
    PatrukZ New Member
    Patrick
    Norfolk, Va
    2000 Tacoma 4WD 2.7l
    (almost none) bedliner aftermarket radio
    Hey.... I was also thinking that it could be a clogged Catalytic converter.
  6. Dec 25, 2014 at 11:11 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Disconnect the cat. It will be loud but then you can road test it.
  7. Dec 25, 2014 at 11:19 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  8. Dec 25, 2014 at 11:33 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Vacuum gauge will tell you all you need to know.
  9. Dec 26, 2014 at 9:21 AM
    mntbiker2008
    Aaron
    Cincinnati, OH
    It idles just fine
    It has about 110k on it. I was also thinking a clogged cat. It did blow off the manifold. Would it hurt to disco the egr line again and run it for a bit to see if that was the cause? He said it started acting like this after he fixed the hose. It also smells like gas after you get done driving it which also makes me think its the cat. You are right though... I would think it would throw a code as well.
  10. Dec 26, 2014 at 9:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    Agreed, but for clarity, disconnect at the front side, not the back.
    IE create the exhaust leak before the cat.
    If you can tap the cat with a hammer or such, and you hear rattling, that's another indicator of failure.
  11. Dec 26, 2014 at 9:45 AM
    mntbiker2008
    Aaron
    Cincinnati, OH
    thanks. I will give this a try.
  12. Dec 31, 2014 at 2:32 PM
    mntbiker2008
    Aaron
    Cincinnati, OH
    welp... checked everything out... it was all good but on my way back from the garage... the truck didn't want to shift (auto).... then after a small hill, the transmission completely went out... I think I know what the issue was... lol and it makes sense because while I was looking at it, the engine revved fine and idled perfect... it just wasnt transferring the power to the wheels.
  13. Dec 31, 2014 at 2:34 PM
    LegitGreenTaco
    LegitGreenTaco Photosynthesis.
    2002 Regular cab base A/C fixed now.
    Westin lights, Westin Light bar holder, New front bumper, Custom floor matts, Steering wheel cover, board in bed to keep groceries from rolling around, new radio, New flat bed cover.
    I dont have that problem I have a 2.4L I feel like I should be getting better gas mileage that I am Anyone have this issue?
  14. Dec 31, 2014 at 6:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    What you 'feel like' doesn't matter. What's actually happening does.
    How does what you actually get match up to EPA estimates at www.fueleconomy.gov? They are pretty accurate for an unmodified, normally driven vehicle.
    What is the condition of the truck and what modifications? Where do you live? All things that can affect MPG.
    If you are close to the EPA numbers, maybe you have the wrong vehicle if you are MPG concerned.
  15. Dec 31, 2014 at 7:05 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Try starting your own thread. With at least some information.
  16. Dec 31, 2014 at 7:33 PM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    On the original topic. Did you check the fluid? Is it black? It's unusual for a A340 to die that early a death.
  17. Jan 8, 2015 at 2:20 PM
    mntbiker2008
    Aaron
    Cincinnati, OH
    Yeah I checked the fluid. It was 2.5 qrts low (took that much to get it back up to the line on the dipstick. It wasn't dirty or anything. I know it had a service done that included drain and refill the transmission before my dad bought the truck.
  18. Jan 8, 2015 at 2:53 PM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Does it run and drive now? Or did running it low on fluid toast the trans? Usually the autos in Toyotas are pretty resilient. I know I had a bad leak on a A43D and ran it so low on fluid that it quit pulling. Put 2 quarts in it and drove it home. Fixed the leak and it was still shifting good when I sold it a year later.
  19. Jan 9, 2015 at 9:09 AM
    Indy
    Indy Master of all I survey.
    Better idea, read on one of the other 10k mpg threads instead of starting a 10k01.
  20. Jan 12, 2015 at 5:37 PM
    mntbiker2008
    Aaron
    Cincinnati, OH
    I just talked to him today and he said he got it back up and running again. he had to add a little bit more to the transmission and also said his catalytic converter was completely plugged up. I am pretty impressed it didn't completely damage it!
