2.7 Sluggishness
Discussion in '1st Gen. Tacomas (1995-2004)' started by bgarner1542, Nov 10, 2019.
  1. Nov 13, 2019 at 9:03 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Sounds about on par with my truck. What size tires are you running?
  2. Nov 13, 2019 at 9:05 PM
    bgarner1542
    bgarner1542 [OP] Member
    Brayden
    1999 Burgundy Prerunner SR5
    265/70/17 31.5s with the 4.88s
  3. Nov 14, 2019 at 10:41 AM
    Indy
    Indy Master of all I survey.
    Yep, slow and underpowered. Sounds about right.
  4. Nov 14, 2019 at 1:26 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    If your front cat is original, go with a MagnaFlow unit. Watch the quality though and use Toyota gaskets... I did this and it helped. While it's out, clean up the o2 sensor and re-install.
    Also, I recommend cleaning the MAF and running some injector cleaner through a tank of fuel.
    Lastly, look at LC's big bore throttle body up-grade. I did this years ago and it helped with throttle response and pick up... no hp gains though.
    Good luck.
  5. Nov 14, 2019 at 7:50 PM
    UnderFire
    UnderFire Well-Known Member
    With 4.88s your truck should be just fine. I have a worn out 270k mile 3RZ in a heavier 4Runner coupled to an automatic. It has factory 4.56 gears and I'm running 33's. It's fine, perfect amount of power for around town driving or highway cruising.
    It wouldn't be my first choice for freeway driving, but certainly bearable. If you're looking to get more out of it, don't. It can certainly be done but it's not for the faint of heart. Time, money and heartache will be given and it does cost reliability if you're hard on your truck. I know from personal experience. For the record my 3.4 double cab is no faster than the 4runner.
