2.7 stick stalls when cold
Discussion in 'Technical Chat' started by Dustrider, Nov 24, 2011.
  1. Nov 24, 2011 at 10:11 PM
    Dustrider
    Dustrider [OP] Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    Out of rope
    anyone have ideas ?
    98 Tacoma 4x4 2.7 stick 201,000
    starts fine but stalls at stops only at stone cold start until temp guage reaches norm operating level
    it will not stall if I keep it revved with my foot
    if I let it stall it turns over a long time , about a minute before it re-starts
    idle only goes up to about 1,000 at cold start and drops to 750 within 5 seconds
    things replaced/ tested so far to try and cure this within the last two weeks
    idles smoother but with no change at cold stalling
    replaced :
    ECT sensor (autozone)
    IAC control (OEM)
    MAF sensor (OEM)
    TPS (OEM)
    inline fuel filter
    air filter
    spark plugs/wires OEM
    valve cover gasket/ plug seals
    thouroghly checked out/cleaned:
    battery cold crank charge/voltage
    cleaned ground to body/motor wire end
    checked fuel pressure with snapon guage at cold start condition holds perfect 44 psi at idle, 39 at stop , no leakdown
    throttle body removed and cleaned, replaced gaskets
    ran down tank to last gallon and ran a can of seafoam though
    checked for vacuum leaks/intake leaks
    EGR compared operation with new unit , working perfect opens with small vac and snaps back tight
    removed and checked operation of EGR VSV valve works perfect
    removed and checked temp opening and cold shut of thermostat
    removed and checked cat for flow , ran Nox probe and it is catalyzing
    wiggled plugs to ECM
    rechecked aftermarket engine control temp sensor for OHMs output cold and hot
    no change after all that to cold stall , just runs better and idles smoother
    bad items found :
    removed valve cover and found some tight valves
    compression weak #1-140, #2-150, #3-180, #4,190
    runs good up the mountain where I live and runs idles good enough for me, never stalls once it is warmed up for the day even after sitting at work all day
    just want to cure cold stall, dont want to rebuild engine as the dealer tech suggests
    I gave up after doing all that and took it to local mechanic and they were stumped said rebuild motor
    took it to dealer for the $100 diagnosis and they suggested replace $300 IAC valve (after I cleaned mine), it resulted in no change waste of $400 , then they suggested engine teardown to replace valves
    both said valve job on old motor is a gamble and dont adjust the tight valves now or they could fail
    after at least three weeks of this ( I drive it 200 miles a day LA stop&go/4000ft climb up mountain ) I finally got a code at cold start while keeping it revved during the cold run in to the first stop sign
    PO104 "excess EGR flow detected"
    EGR shuts at idle and opens at higher RPM , I noticed the EGR opens when cold , manual says EGR should not open when motor cold if I am not mistaken ?
    rechecked EGR and it seems to operate perfect, rechecked EGR Vacuum Switching Valve and Vacuum modulator work perfect
    cleared the code with the OBDII and it has not come back in the last 500 miles
    Idle does not go above 1000 at cold sart manual says it should be 1250 to 1500 until it warms up
    all the diagnostic trees I have chased seem to dead end at the ECM computer ?
    possible related/unrelated recent events :
    about 4 weeks ago the AC compressor clutch melted so I disconnected the belt , IIRC the cold stall started before this but not 100% sure , I know there is an idle-up circuit for the AC but havent investigated it yet
    also 3 weeks ago had a condition where the starter would just click loud and not engage , at random after several attempts it would engage , I bought a reman starter to install and found a loose connection at the starter battery cable lug tightened it and it has not happened since , took the reman starter back
  2. Nov 25, 2011 at 12:55 PM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I simulated the cold stall this morning pulled out the driveway and back in and let it stall . After stall it will sound funny turning over like there is no spark or no compression , weak but easy spin turn over sound like it doesnt even want to try to fire
    after cranking for about a minute with the weak sounding crank it will start
    this time I just let it stall, then cranked it for 5 seconds to confirm it was making the funny weak & easy crank sound and then opened the fuel line to check for fuel it ran out so I tightened the line back and removed #1 plug wire and checked for spark with a spark tester and it had a fat blue spark
    replaced the plug wire and it started right up with no funny crank sound , just started first kick
    now it will run normal for the rest of the day
  3. Nov 25, 2011 at 1:48 PM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    theory 1 ?. because the valve condition is causing weak compression at cold start, the Electronic Control system on this model cannot compensate enough to keep it from stalling , evn though it is operating properly?
    the weak turnover sound is weak compression and a lean condition that would be sufficient with fresh compression ?
    theory 2 ? . the ECM electronic control module is not sending voltage signals to compensate for cold start conditions ?. Fuel injector pulse, Idle Air Contorl and EGR may not be getting the voltage commands necessary to compensate fuel trim at cold start ?
    the weak turnover sound is weak compression and lean condition caused by the IAC not closing and EGR opening because the ECM is not telling the VSV and/or IAC what to do but the injectors are still dumping extra fuel or not enough ? ?
    as the engine comes back down to idle stone cold with tight valves the added suction at valve overlap through the intake with the EGR open drains the fuel rail as the engine stalls from bad fuel/air ratio , and therefore it takes a while of turning over to get the fuel mixture high enough to let it combust
  4. Nov 25, 2011 at 7:49 PM
    too old
    too old Member
    So Cal
    03 Double cab prerunner 4 wacker
    I'm new here and was searching for another topic and ran across yours.
    There is an idle control valve which on my 2003 2.7 Tacoma is under the throttle body and very hard to see and reach. Sometimes rough idling is caused by the air passage to that valve getting clogged by carbon buildup in the throttle body. I use fuel injector cleaner in a spray can (not to be confused with carb cleaner). I loosen the plastic intake duct at the throttle body, run the motor on high rpms and spray all around the throttle body intake. By doing so, some of the cleaner will get into the idle control valve and clean out that passage. Make sure you're in a well ventilated area as it may smoke a little.
    I noticed that your compression readings are quite far apart. Maybe a fouled plug in contributing to the problem.
    Good luck.
  5. Nov 26, 2011 at 1:15 AM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    removed the throttle body, removed the IAC and cleaned it all
    replaced it with a new toyota IAC after the "expert" toyota diagnosis
    the long post is a list of everything I have tried so far
    I have checkedOK or replaced everything but the ECM and the engine
  6. Nov 26, 2011 at 7:04 AM
    saugus
    saugus Well-Known Member
    Probably won't help but when I changed my plugs, I was experiencing the same thing the first morning after. I thought that I didn't put something back right and wiggled the vacuum hoses and wire cables that were disconnected during the replacement. The issue went away after that. I am guessing the problem may have been anti seize on the plug end or new plugs burning in or similar.
    If not already stated in the OP, try checking for vacuum leaks and loose cables around the ignition system.
  7. Nov 26, 2011 at 8:24 AM
    too old
    too old Member
    So Cal
    Saugus made a good point about the vacuum issue. Maybe a mounting bolt, clamp or hose is just slightly loose or cracked. Maybe a vacuum gauge would be of help. There are websites that show various vacuum readings and what the probable causes are.
    Good luck.
  8. Nov 26, 2011 at 11:28 AM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    all that is on the first post that is too long to read
    Had local mechanic run vaccuum test and backpressure test
    I have checked removed replaced every vacuum line and VSV valve at least once including blocking off the brake booster
    I ran it to make it cold stall and checked for spark , lots of spark when it cold stalls
    runs better after changing plugs and wires but no change to the cold stalling
    when I changed the plugs found the #4 plug cap was soaked in oil so I replaced the plug tube seals and no more oil
    plugs tend to cause misfire
    this is stalling at stops when stone cold after sitting all night
    after warming up for the day it runs fine
  9. Nov 27, 2011 at 9:08 AM
    too old
    too old Member
    So Cal
    If keeping the rpms up helps, it really sounds like a small vacuum leak. Once the motor develops enough heat, the leak is sealed.
    I had a similar problem (on a carb) which was at the base where the throttle linkage opened the the butterflies for the primary bores. There was a kit to replace the bushings that the linkage runs through but it cost just a little less than a new carb! Even spraying carb cleaner at that point didn't show a vacuum leak and the vacuum gauge still showed a good reading at idle. I learned of this potential problem area from others on another hot rod forum.
    Those compression numbers don't look good.
    Good luck.
  10. Nov 27, 2011 at 11:21 AM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    makes sense i had that on a chevy throttle body with 250,000 but it wasnt this extreme
    but this thing starts right up
    if I let it idle up to warm it will be good for the day
    if I drive 100 feet, pull over and let it stall
    it will not restart for 1 minute
    I can set a watch to it 1 minute
    I can just wait one minute and it will start right up
    or I can hit the starter for one minute doesnt matter
    after it restarts it will still want to stall , until the temp is up all the way
    then it is good for the day
  11. Nov 27, 2011 at 12:10 PM
    saugus
    Wonder if the fuel pump is acting up while driving. I remember reading about others with stalling and then delay and then restart like you describe about a month ago here.
  12. Nov 27, 2011 at 6:49 PM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I left it at the local mechanic shop and they checked the fuel pressure with a guage when it cold stalled and the fuel pressure checked out perfect , no leakdown either
    I am ready to just try a $550 reman Toyota ECM
    it is so difficult to test thr ECM without the factory toyota manual and even then it may test OK for continuity with certain functions but malfunction anyway
    the only way to really test if a problem is caused by the ECM is to plug in a new one
  13. Dec 2, 2011 at 8:43 PM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I replaced the ECM with the toyota reman and it ran great after cooling for a few hours
    Ooops !
    wasted $550
    the saga continues
    I went to sleep last night optimistically thinking I had it licked
    but my pragmatic side was nagging at my pessimistic side waiting for that stone cold start in the morning
    sure enough cold stall came back
    went to another toyletoda dealer to get a third opinion
    he let me tell the whole story and concurred with the two others that it is valve condition
    he agreed with my opinion why . I think that although the leaky valves would not make all motors stall, the nature of the toyodor engine control system will not compensate for it when the motor is stone cold . It will only meter out enough for a small amount of compression loss at cold valve condition
    I think someone contributed earlier in the thread that the spongecake buildup on the valves will somehow absorb the fuel or something like that, not sure what the theory is
    it would require more fuel at cold start and the toyoter system will not provide it
    next thing to try will be valve job
    the stupid motor has shim and bucket and is a PITA to adjust
    a valve adjustment might help but i am not sure why the mechanics are saying it cant be done, when I ask the just shrug and say theyve never considered it but the manual tells how
    maybe they know that enough shim cannot be removed to get the valves seated or some such
    seems like a shame to pull the head when it runs fine
    this is my third toyota and all were nothing but one major trouble after another
  14. Dec 3, 2011 at 10:27 AM
    too old
    too old Member
    So Cal
    I have a thread going about a loud tapping noise upon cold start up on my 2.7L but it only happens when I put it into gear. The loud tapping goes away after a few moments. I also considered the valves, but I would have thought that valve clatter would be heard when just starting the engine.
    I think in you situation, the compression readings are a major clue.
    On the other hand, my GF has a 4Runner with the V6 and it never gives her any problems.
    I think this 2.7L motor had many issues that Toyota never figured out. It's a shame as I'm really happy with the rest of the truck.
    Good luck.
  15. Dec 17, 2011 at 4:27 PM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I should have bought a compression tester and checked it myself
    I have seen bad valves before but these look good
    I put the cams back in the head and turned it over on the bench and the valves dont look too bad
    let them close and poured some gas on top and it just sits there in a pool
    looks like I took the head off for no reason
  16. Dec 21, 2011 at 10:39 PM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    [​IMG] hot damn
    GOT IT !
    finally !
    put the new head on and it fired right up
    no cold stall
    no more "EGR type stumble"
    idles higher and idles real smooth
    about 25% more power too
    worked out some bugs and did a 200 mile shakedown
    I just refused to believe bad valves would act like that
    THANKS FOR ALL THE HELP EVERYONE
  17. Feb 12, 2012 at 7:21 AM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I have about 3,000 miles on the new chinese aftermarket head and it runs like new
    the toyota engine control system will not compensate for bad valves and low compression so it stalls when cold The 2.7 runs relatively hi compression
    Instead of sending my head out to get a valve job which was about $500 + and you need to find a toyota specific shop that will adjust the shim and buckets ( most auto machine shops dont) , I got a complete new aftermarket head and gaskets from japanengines.com for $500 total shipped which cured it
    Easiest head I have ever worked on Very easy to work on the 4 cyl Toyo I have done maybe a dozen heads in my life started wrenching on motorcycles at 15, the 2.7 is more like a motorcycle engine than a car
  18. Feb 12, 2012 at 7:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sometimes one head is better than two.
  19. Sep 9, 2016 at 7:49 PM
    bigairjunkie
    bigairjunkie New Member
    1998 Tacoma 2.7L 4WD Manual
    My 98 2.7L just starting doing this EXACT SAME THING. Thanks for the thread guys.
  20. Oct 12, 2021 at 10:08 AM
    ZachG34
    ZachG34 New Member
    1998 Tacoma 2.7L 4x4 SR5
    Hello from 2021!
    My 98 2.7 just started doing this exact same thing....been pulling my hair our trying to figure it out and wasting a ton of money. What exactly ended up being the fix?? The new after market chinese head? Would really appreciate any help!
