2.7 stumbles and bucks under load (solved)
Discussion in '1st Gen. Tacomas (1995-2004)' started by SOMDTACO, Sep 8, 2016.
  1. Aug 8, 2019 at 12:12 PM
    #61
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Great to hear this and thanks for reporting back that it fixed your issue. Good real world data point.
    #61
    wilcam47 likes this.
  2. Aug 8, 2019 at 9:06 PM
    #62
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    Still having some issues, going to reset the ECU and go from there. I'll bring my new coil and spare dizzy with me, the used offbrand one is in it now.
  3. Feb 1, 2020 at 3:37 PM
    #63
    Zak h
    Zak h Member
    Zak
    1996 3rz Tacoma
    I have the same problem that killed my engine at 242k got a new engine installed and same problem with the stutter. Changed the distributor fixed MOST of my problems. Only stumbled randomly now 10-15 times in 300 miles on new engine. Changed with new distributor cap and rotor plugs wires new injections just tried the igniter and same problem.
  4. Feb 1, 2020 at 3:56 PM
    #64
    SOMDTACO
    SOMDTACO [OP] Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    My guess would be fuel lines or fuel tank considering you swapped out the engine and have same issue.
  5. Feb 1, 2020 at 4:31 PM
    #65
    Zak h
    Zak h Member
    Zak
    1996 3rz Tacoma
    Yeah that’s what I’m trying next is fuel pump could be intermittent issue but idk cause only inbetween 2500-3200 rpm
  6. Feb 2, 2020 at 4:41 PM
    #66
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Mine does it between 1750 and 2100. I have replaced everything under the sun with the exception of the fuel pressure regulator. The only other explanation I can come up with (in my case) is my catalyst has been punched from my converter. I may have a exhaust scavenge issue at that rpm and or the exhaust is going past the O2 too fast to correctly monitor on account of it . Please keep us posted
  7. Feb 2, 2020 at 10:23 PM
    #67
    Zak h
    Zak h Member
    Zak
    1996 3rz Tacoma
    The distributor fixed the stutter that was always there now I’m hoping it’s just lack of fuel under pressure for the random stutter
  8. Feb 2, 2020 at 10:43 PM
    #68
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Did you replace the distributor with a Denso/Toyota unit? Aftermarket electrical parts can cause problems like this. Work well most of the time, but not work 100% like they're supposed to.
  9. Feb 3, 2020 at 11:22 AM
    #69
    Zak h
    Zak h Member
    Zak
    1996 3rz Tacoma
    spectera premium denso Toyota wanted 700
  10. Feb 3, 2020 at 12:06 PM
    #70
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    Spectra and Denso are different. Does it say Denso on it with a Denso part number?
    You could try to find a used Denso distributor for cheaper or a used original Denso coil. The same coil was used on different models. I don't what to push you in this direction unless you are at a dead end trying to figure it out. Check the fuel related stuff, fuel pump and pressure regulator first.
  11. Feb 5, 2020 at 8:19 AM
    #71
    Zak h
    Zak h Member
    Zak
    1996 3rz Tacoma
    It is a spectra distributor and I just did the fuel pump and relized I have a bad rear axle seal leak I’ll post if the pump helped any other idea besides the distributor and pump
  12. Feb 5, 2020 at 8:26 AM
    #72
    Rachelsdaddy
    Southern NH
    It depends what your trims look like. If they are high it’s either a fuel delivery issue or unmetered air. As far as the axle seal goes, replace the bearing or you will be changing the seal again in a month. Did mine last week, both sides. You can get a kit from Marlin Crawler for 70 bucks per side; everything you need. Plus free stickahs!!!
  13. Feb 6, 2020 at 8:24 AM
    #73
    Zak h
    Zak h Member
    Zak
    1996 3rz Tacoma
    Getting the axle bearing taken care of but what do you mean the trim
  14. Feb 6, 2020 at 8:36 AM
    #74
    Rachelsdaddy
    Southern NH
    Search fuel trims on this forum. I’m sure you will learn a lot.
    SOMDTACO[OP] likes this.
  15. Mar 6, 2020 at 7:30 PM
    #75
    Ramrod83
    Ramrod83 New Member
    Rodney
    1995 2.7 taco
    Having same problem just wonder if this is a coil problem or distributor problem just replaced plugs wires cap rotor and coil. before replacing would hardly run now getting misfire between 2000 and 3000rpms and occasionally above 3000 no cel before changing parts i was getting p0300 p0302 and p0304
  16. Mar 6, 2020 at 7:42 PM
    #76
    SOMDTACO
    Sean
    Southern Maryland
    So I'm not 100% sure on this. It's been a while and I'm spitting off the top of my head. But I believe in the 95 and 96s there is a sensor integrated into the distributor. Cam position sensor maybe? So for some maybe when they are replacing their distributors they are really replacing the sensor and that's what's actually providing more of the fix.
  17. Mar 6, 2020 at 7:55 PM
    #77
    Ramrod83
    Ramrod83 New Member
    Rodney
    1995 2.7 taco
    Thanks for the quick response I’m going check around for one. What brand am I looking for?
  18. Mar 6, 2020 at 7:57 PM
    #78
    SOMDTACO
    Sean
    Southern Maryland
    Do some research to check me in the cam position sensor thing but I always remember that being the case on my 96 at least. But if you are looking for a used OEM distributor made by DENSO. the coil should be a yellowish clear color with the words DENSO or TOYOTA written across it.
    Ramrod83[QUOTED] and cruiserguy like this.
  19. Mar 7, 2020 at 1:33 AM
    #79
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    96 4-cylinder definitely had the cam sensor in the distributor. When they switched to coil packs they put the cam sensor on the intake side of the head between 2 & 3 cylinders. I don't think there was ever a version with a distributor with a separate cam sensor mounted on the head.
    Denso coil was used in many models, but the whole distributor was specific to the Tacoma.
    You might be able to check the air gap for the pickup coil for the cam position sensor inside the distributor. I'm not sure what the spec is or if it's adjustable.
    Ramrod83 likes this.
  20. Mar 7, 2020 at 6:43 PM
    #80
    Zak h
    Zak h Member
    Zak
    1996 3rz Tacoma
    I went through it all with this problem. I got an oriellys distributor (spectra premium) and it fixed all problems for a day and it all started happening again $300 for that one and tried other things and finally took it to Toyota and they said I need a distributor from them even though I just changed the whole unit. When through with it because they guaranteed that if it wasn’t it that would not charge me and keep searching. $800 to have them do it and it fixed all of my problems. You need to buy a denso distributor that’s what they installed and works great !!!!! 2000k in on the second distributor and it’s ripping healthy. That year doesn’t like aftermarket parts just ran faulty with the oriellys junk
