2.7 stumbles like its starving for fuel.
Discussion in '4 Cylinder' started by TeddyBear, Sep 1, 2013.
  1. Sep 1, 2013 at 11:32 AM
    TeddyBear
    TeddyBear [OP] Member
    Andrew
    Rosepine, Louisiana
    2010 PreRunner
    MY fiancee and I just bought a 2010 toyota tacoma access cab prerunner, About seven months ago. Not long after we bought it I noticed it would start stumbling in second gear like it wasnt getting enough fuel and I would have to shift up to third to get it to stop. Ive scoured the internet but couldn't find any info. I don't believe its a dirty fuel filter, because it only does it in between 2nd an 3rd gear, Im leaning towards a dirty Maf sensor. I also don't believe it to be my spark plugs, But then again I'm no mechanic. It's my daily driver and i have to have it for the 140 mile round trip to work. Any suggestions? The truck only has 61,000 miles on it.
  2. Sep 1, 2013 at 12:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd run a tank of fuel system cleaner through it for a week (to me it sounds like a fuel injector is sticking open) then drain the oil (let it drain overnight if possible) and replace the spark plugs. Check all the vacuum lines and air intake hoses are tight. Cleaning the maf is good, too. Good luck.
  3. Sep 1, 2013 at 2:20 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    Red Line Oil SI‑1 from O'Reilly Auto Parts has made my vehicles run a lot better.
  4. Sep 1, 2013 at 5:01 PM
    TeddyBear
    Andrew
    Rosepine, Louisiana
    2010 PreRunner
    I'll try this first, I've ran stp fuel system cleaner through it. And the regular old stp gas treatment. Still did it, but wasn't as often.
  5. Sep 1, 2013 at 6:34 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Check or replace the spark plugs, they are due at 60,000 anyway if I'm not mistaken.
  6. Sep 1, 2013 at 6:51 PM
    2007 tacoma
    2007 Access Cab
    For reference:
    I went to BITOG when I was looking into it, and no one ever says anything bad about it. While many others are recommended also what makes me a user of it is the price and availability.
    If that doesn't help I don't think anyone has mentioned maybe having some water in the gas. Dry it up with HEET.
    Those made a huge difference in another vehicle I maintain. The SI-1 is a regular additive now in my Tacoma though.
    If it doesn't then other advice is more relative.
  7. Sep 9, 2013 at 5:32 PM
    TeddyBear
    Andrew
    Rosepine, Louisiana
    2010 PreRunner
    Update:
    I did a complete tune-up this weekend, Switched it over to synthetic oil, brand new oil filter, air filter, And brand new NGK Iridium spark plugs. My old plugs looked pretty damn good, Also no change it still does it. Maybe a dirty MAF? Im running out of ideas, and patience. I couldn't find the SI-1 additive any of the parts stores around here and the mouthbreather's behind the counter couldn't help me either. Ill order it in the next two weeks, and report back. Sorry to keep bothering, But This is an expensive investment and I'm getting aggravated.
  8. Sep 9, 2013 at 9:52 PM
    2007 tacoma
    2007 Access Cab
  9. Sep 9, 2013 at 10:03 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Check all of the vacuum hoses. Sounds to me like there's an air leak.
    Also try this:
    Disconnect the cable on the negative battery terminal for around 5 minutes, and then reconnect it. This allows your ECU to relearn its operating parameters.
  10. Sep 9, 2013 at 10:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Stumbling like it's starving for fuel in 2nd, but runs fine in 3rd, sounds to me like you're bouncing off the rev limiter.
    Just what are your RPMs when it starts "stumbling"?
  11. Sep 10, 2013 at 8:39 AM
    tooter
    Greg
    Los Angeles
    Sometimes the most simple explanation is the right one... ;)
  12. Sep 10, 2013 at 7:15 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Been there a dozen times on the Vulcan. Not so much with the louder pipes, but when I put a set of quieter pipes on it, I was always hitting it getting on the freeway.
  13. Sep 11, 2013 at 1:01 PM
    TeddyBear
    Andrew
    Rosepine, Louisiana
    2010 PreRunner
    My rpm's aren't high at all, I would know if I was bouncing off the rev limiter. It's a problem tht only pops up from time time. Not speed or rpm related, I don't drive my vehicles like that.
  14. Sep 11, 2013 at 2:01 PM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    My truck is a 1st gen but has the 2.7L. I had issues similar but it finally threw a code for the throttle position sensor.
