2.7 swap to 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by SP3NC, Jul 13, 2023.
  1. Jul 13, 2023 at 5:18 PM
    SP3NC
    SP3NC [OP] Member
    Spencer
    2003 Toyota Tacoma limited
    Grille and head lights so far
    I have a 04 tacoma double cab has a lot of meaning to me so not gonna buy another. It’s a 2.7 but Wanna swap it to the 3.4. How hard is it and what all would I need to make the swap basically like factory?
  2. Jul 13, 2023 at 5:56 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    So many things.
    You need a motor with all the correct accessories, ECU and harness. You need either r150f or a340f and matching transfer case. You will need to move the motor mounts on the frame about an inch. If going auto to manual transmission you will need to relocate your transmission crossmember and get a clutch and pedal set up.
    That's the basics there is a lot more involved with the details.
    Bivouac and Superdave1.0 like this.
  3. Jul 13, 2023 at 11:13 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Research and read every swap thread you can find .How hard depends on your level of skill and how fast you can learn new skills.
    Have all the electrical schematics for all the vehicles involved. Some people need to source out the electrical work it can be to overwhelming for some
    Your Tacoma in essence becomes what ever year engine you end up with . 3rd generation 3.4 4 Runners make great donor vehicles.
    Every swap that I did I bought the complete Donor vehicle had it sitting a few feet away . saves hours and money chasing forgotten parts.
    Would you plan on installing a new timing belt while the engine is out?
    Replacing belts and hoses??
  4. Jul 14, 2023 at 5:11 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    If you could find one that rusted out or wrecked - get the whole thing that way you have everything you need to just swap it all over. I'd go 3.4 and 5 speed. You can find em like that for quite a deal sometimes.
  5. Jul 15, 2023 at 7:39 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    If power is what you’re after, I’d just put a small turbo on the 2.7. You’ll get more power than you would swapping in a 3.4 and probably be just as cheap if not cheaper. The 2/3rz love a little boost.
