2.7 Taco at altitude
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rav4Runner, Dec 20, 2020.
  1. Dec 21, 2020 at 8:42 AM
    #81
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yeah... i remember that thread.
    BillsSR5[QUOTED] likes this.
  2. Dec 21, 2020 at 10:08 AM
    #82
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    My '97 2.7 MT 4WD (sig pic) was adequate in CO and UT. Minimum altitude in all of its travels in those states was 5300ft. 5th gear was useless on I-70 between Glenwood Springs and St George UT, just didn't have the power to maintain speed. Hummed along pretty good in 4th though, did fine in 3rd climbing Vail and Ike. Would grind along pretty good in 4lo offroad hillclimbing at 10k+ft.
    When I bought the 2012 in Englewood at 5300ft I originally bought a 2.7l 4WD AC MT, noticed the extra weight immediately on the test drive. Bought it anyway (great price), kept it two days and 83 miles.
    I really wanted to like the 2.7 but we were planning on a shell and a 3200lb travel trailer and realized the 2.7l wouldn't make the grades. Took it back to the dealer for a 4.0l 4WD AC MT. Since then I moved on to the 4.7l's and auto trans for towing at altitude. Any NA engine will lose power at altitude so I just kept upgrading displacement.
    davidstacoma and Junkhead like this.
  3. Dec 21, 2020 at 12:17 PM
    #83
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I told the truth there and got the
    (you have insufficient privileges to post here) memorandum :santa2:
    Junkhead[QUOTED] likes this.
  4. Dec 21, 2020 at 4:47 PM
    #84
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    Probably has already been said, but if you ask the question then you already have your answer: get the V6. Those that know enough to ask it are likely to have their expectations disappointed by the 2.7; those that don't know to ask it will likely be happy to have whatever truck they have.
  5. Dec 21, 2020 at 4:52 PM
    #85
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    4 banger's fine if you're okay with a Softopper instead of a fiberglass truck cap.
    4×4×4 and Junkhead like this.
  6. Dec 21, 2020 at 5:06 PM
    #86
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    I’m actually ok with my fiberglass cap and RTT, but the one time I tried towing a 5x8 moving trailer up into the mountains (loaded with stuff for my wedding) it dogged way down, not going to make a habit of that.
    Junkhead and e6400ultra[QUOTED] like this.
  7. Dec 21, 2020 at 5:59 PM
    #87
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Oh I’m quite certain the 3.5 will beat the HP & torque of the 2.7 at those rpm’s, my point was you have to compare apples to apples. Can’t just take the HP & Torque at different rpms for comparison was my point. Having said that what’s up with the wimpy torque and HP of the 3.5 stock tune at 2500 rpm in the dyno chart in the link you posted? Something doesn’t seem right there, the 2.7 second gen torque at 2500 rpm exceeds that handily from the dyno chart I’ve seen for it. I don’t believe that chart for the stock tune in the low end. No way a “tune” would fix that like the chart shows.
    bbahunter and Junkhead like this.
  8. Dec 21, 2020 at 9:34 PM
    #88
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    I'm sure the v6 will last just as long haahaa im just being a hater:rofl:
  9. Dec 22, 2020 at 2:16 AM
    #89
    bbahunter
    bbahunter Well-Known Member
    Ma.
    2020 Black Bearded Taco
    IMO, i think the 2.7 engine has enough power, the problem is the shift points in the transmission in drive. You can get better response by shifting in S mode, and you can also use ECT (tow mode) for better response.
    davidstacoma likes this.
  10. Dec 22, 2020 at 6:38 AM
    #90
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
  11. Dec 22, 2020 at 6:49 AM
    #91
    Tripod1404
    Tripod1404 Annihilator tripod
    2GR-FKS switches to Atkinson cycle under low load. The strange part of the dyno recording is probably the end of Atkinson cycle (around 3250 RPM). So anything before that is low due to Atkinson cycle. If I am remembering correctly, there are ways to prevent the engine from switching to AC, as I have seen dynos for it that look normal. But I cant find them now and finding a decent dyno curve for 3.5 is so difficult for some reason. There is one given in link below, in that case HP looks okay, but torque curve is a mess (it might be because they used an auto truck for dyno).
    https://www.offroadxtreme.com/features/car-features/2016-toyota-tacoma-trd-off-road-review/
    Note that this dyno starts reading from ~3k RPM. So the dyno probably has higher resistance and puts more load on the engine (so tires can only start spinning the dyno after 3k RPM). This would prevent the ECU from switching to Atkinson cycle.
  12. Dec 22, 2020 at 7:18 AM
    #92
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    That is why i really enjoy my premium SFOB tune. Its full otto cycle, it drives like a completely different animal and mpgs are the same. Go figure. Thank you Mr. OV tune!
    Overall it drives better and actually the engine starts quicker, which i found very interesting.
    IMHO this simulated atkinson cycle is garbge. Does not save you any fuel, yet you loose torque at low rpms. The constant switching between otto and atkinson puts extra stress on the engine IMO.
    The simulated atminson works better with a hybrid, since it gets help from electric motor at low rpm, but not on a regular ICE vehicle.
  13. Dec 22, 2020 at 9:09 AM
    #93
    LilTexan22
    2017 Tacoma
    That or i just really don't care to look them up to prove a point i don't really care much about. I just don't take a car engine personal lol
    bbahunter and davidstacoma like this.
  14. Dec 25, 2020 at 10:09 AM
    #94
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    essentially a Govt mandate
    over time models must show an improvement in the EPA shed
    8-10 auto trans arent for performance
    they are representaive of the quest to get better if NOT reasonable MPG
    small wonder Volkswagen cheated
  15. Dec 29, 2020 at 2:43 PM
    #95
    he that drives like 15
    he that drives like 15 Member
    fred
    2020 BLACK TRD SPORT
  16. Dec 29, 2020 at 2:45 PM
    #96
    fred
    the 6 is just funner, plain and simple,the 4 is probably the "smart" choice if you're more of an ant than a grasshopper, but life's too short to be responsible about torque.
    Junkhead likes this.
  17. Dec 29, 2020 at 3:11 PM
    #97
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    V6 with the tune is a beast, a lot of fun.
  18. Dec 29, 2020 at 6:13 PM
    #98
    Fleischwagen
    Fleischwagen 2.7 > 3.5
    North Jersey
    2017 SR 5MT 4X4
    5.29's, ARB locker, 6112/5100, Deaver AAL, LCE Header, aFe dry-flo filter, Hurst/Core shifter, CBI T3 Front, Warn Winch, CB/UHF Radio equipment, Backrack, KC fogs and spots
    2.7 5MT but with 5.29's :thumbsup:
  19. Dec 30, 2020 at 2:48 PM
    #99
    NewMexiMan
    2016 SR 5 Speed
    What's your top speed with 5.29's? What size tire do you have?
    Junkhead and Chew like this.
  20. Dec 30, 2020 at 3:04 PM
    #100
    Fleischwagen
    North Jersey
    2017 SR 5MT 4X4
    Running 265/75/16 Patagonia MT's which run a tad larger. They're just shy of 32'', I've only had up to 80ish around 3400rpm or so. (I think, ive only done that once passing someone being an ass in the passing lane and im still breaking them in) and mines a 5 speed though, so take all that with a grain of salt
