2.7 Tacoma engine vibration
Discussion in '4 Cylinder' started by Cdn98TacomaSR5, Mar 30, 2012.
  1. Mar 30, 2012 at 3:49 PM
    Cdn98TacomaSR5
    Cdn98TacomaSR5 [OP] Active Member
    Vancouver, BC
    1998 Tacoma SR5 Special Edition
    Nadda, except mags
    Has anyone figured out what is causing the 4 cyl Tacomas to have such a pronounced engine vibration at idle? It is annoying at a red light. I have read many threads on this forum about engine vibration but no solutions, unless I missed them. The Toyota dealership just told me they can not find anything wrong with my engine when they scanned it with their computer diagnosis and test drove it. I changed the plugs, wires, air filter, fuel filter, seafoamed it and no change. I have a 98 4x4 2.7 Tacoma and there is no way an engine could leave the factory shaking like this. It rattles the passenger seat and dash and the dealership is telling me this is normal??
  2. Mar 31, 2012 at 9:31 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Yes, it is normal for a 4 cylinder to vibrate like this. You have to keep in mind that these are not 8 cylinders. V6 usually are worse. Especially if you get one without balance shafts. The only reason the seat is vibrating, is due to hermonics. It is nothing that I would worry about.
  3. Apr 2, 2012 at 2:05 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    My 4banger does not vibrate this bad but my friends acrua does(normal).
    OP how many miles on your engine ?
  4. Apr 2, 2012 at 7:03 AM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Actually I don't recall any vibration problems with my V6 Tacoma.
    My girlfriend's 4 cyl RAV4, however, would occasionally vibrate like a bitch while in gear at a stop light. So will my current Honda CRV.
  5. Apr 3, 2012 at 8:11 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Exactly... 4-banger... with each 2 engine revolutions there are only 4 bangs, so each bang is more pronounced at low RPMS especially when the thing's in gear with a bit of load. If it bothers you that much, slip it into neutral when you're stopped and it will purr like a quiet kitten. Or if you can find a way to bump the idle RPM that might help but that will likely create it's own set of dangerous problems (potential runaway) and the idle speed is computer-controlled anyway.
  6. Apr 8, 2012 at 1:32 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    IMHO, this is not normal. True, it won't be as smooth as a 6 or an 8,
    but it shouldn't rattle your teeth.
    My 2.7 is smooth at idle, and in gear.
    Possible causes could be one bad motor mount, idle too low, vacuum leak, or maybe a bad torque converter if you have an AT.
  7. Apr 8, 2012 at 1:58 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    No vibrations from my 2.7ltr. Purrs like a kitten
  8. Apr 9, 2012 at 1:29 PM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    No idle issues...smooth as silk...5spd, bone stock.
  9. May 8, 2012 at 12:57 PM
    Gaffer
    Gaffer New Member
    Gaffer
    Coastal Maine
    4x4 work truck
    My 2012 Tacoma 4x4 autop with a 2.7l 4 cyl has a pronounced vibration at 1500-1700 rpm. Have been back to the dealer twice and they tell me that all such engines. This is hard to believe when I read above that many of you do not have the problem.
  10. May 10, 2012 at 4:03 AM
    n0ms
    Angel
    San Diego
    How many miles on that 2012?
    Check the motor mounts? Have your been lubing her up?
  11. May 10, 2012 at 4:07 AM
    YukonLT
    YukonLT Well-Known Member
    Cambridge, NY
    09 AC 4x4 Timberland Mica
    none
    My 2.7l doesn't rattle or vibrate at all, at any RPM.
  12. May 10, 2012 at 7:01 AM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    My '09 access cab vibrates more than my '07 regular cab did for some reason.
  13. May 10, 2012 at 10:07 AM
    ffbartlett
    ffbartlett Well-Known Member
    southern california
    2011 Reg Cab 4x4
    tint, bfg's, 5100's, tunnel cover.
    mine feels and sounds fine to me when idling.
  14. May 11, 2012 at 5:06 AM
    Gaffer
    Gaffer New Member
    Gaffer
    Coastal Maine
    4x4 work truck
    My 2012 has only 5200 miles on it. The vibration is worse at 1500-1700 RPM under load or pulling. Not all that torque though as if you out more into it it would downshift and pick up the rpm's. Yes, that dealer has tried the motor mount shift and retightened it and the exhaust system. They had me try out a similar truck and that was much quieter. I expected some more noise and vibration from a 4 cylinder but not enough that it can be felt on the steering wheel, accelerator and seat. The service manager took it out and confirmed that it was present but felt that their rechecking the motor mounts would make it go away. It is a tad better but still there.
    I can deal with it, if they can assure me that it will not cause the engine to wear out prematurely. I cannot believe that that much vibration will not have some lasting effect on the life of the engine. I have filed a complaint with Toyota and they are having someone call me. I do not have an issue with the dealership. They have been most helpful. But for that money it ought to be perfect!
  15. May 13, 2012 at 8:00 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Mine seems to purr like a kitten...
  16. May 13, 2012 at 5:08 PM
    Panda Cub
    Panda Cub Member
    Chicago
    00 Tacoma 4x4
    Cap
    Sounds like you need a valve adjustment, anything with dohc should have a valve adjustment every 30k or so. IMHO.
    This is also what most mechanics will tell you too.
  17. May 13, 2012 at 5:11 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Having the same issues, thinking I need to clean my throttle body
  18. May 13, 2012 at 5:13 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I have a 2.7L 2010 model with 40,000 miles and I run it pretty hard. I have no vibrations. When I'm at a stop light, I can barely notice my truck is on. I got lucky I guess.
    edit: also, I perform normal maintenance at recommended intervals per Toyota, nothing more.
  19. Feb 2, 2015 at 1:03 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    This morning on the last thirty minutes of my drive to work I started noticing a vibration around the 1500 to 1700 rpm range. It is noticeable when accelerating and engine braking. It is also there, but not as noticeable, when the vehicle is out of gear, not moving and at 1500 to 1700 rpm's.
    Vehicle is a 2.7l 5spd. Has 80k miles on it. I plan on checking the motor mounts after all the snow from the last couple storms melts off of it. Should be able to check them tonight if we have the right tools here in the shop. Never noticed anything like this before on the truck.
    Just wondering if anyone has any other ideas.
    t1m829 likes this.
  20. Feb 2, 2015 at 4:02 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Purrrrrrrrrrrr
