2.7 Tacoma Hard to read oil dip stick
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LilTexan22, Aug 24, 2019.
  1. Aug 24, 2019 at 12:24 PM
    LilTexan22
    LilTexan22 [OP] Well-Known Member
    2017 Tacoma
    I've noticed it's quite difficult to read the oil dipstick on this engine compared to other vehicles I've owned in the past. When I pull out the stick to check the oil, it just looked smeared everywhere. I've tried letting the truck sit and pulling the dipstick out slow to get a accurate reading but I still get the oil smeared along the stick. Does anyone know how to read the dip stick?
  2. Aug 24, 2019 at 12:33 PM
    2019tacosr5
    2019tacosr5 Well-Known Member
    Jacob
    2019 White Tacoma SR5 V6
    You pull it out, then wipe it off, stick it back in, then pull it out to check reading.
    Thuguon2.7 likes this.
  3. Aug 24, 2019 at 1:07 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    GatorAintBoutDat, Paul631 and ajm like this.
  4. Aug 24, 2019 at 1:27 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Just wait until it gets really black and nasty. Then it's easy to see!
    G.
    whatstcp and jetfishn like this.
  5. Aug 24, 2019 at 1:29 PM
    LilTexan22
    2017 Tacoma
    I know that but what I'm trying to say is that this truck doesnt give you a nice flat level reading on the dip stick. When its pulled out the oil is smeared along the whole stick leaving me wondering where the oil level really is at
  6. Aug 24, 2019 at 1:32 PM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    MOC221_[QUOTED] likes this.
  7. Aug 24, 2019 at 1:41 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Pull the dip stick out, wait 5 min and then try again.
    over60 and CusterFan like this.
  8. Aug 24, 2019 at 1:57 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    I haven't looked at the Taco. But my wife's Rav4 doesn't have the knurls between the Hi / Low marks. Makes it hard to read for an old fart like me. I plan on knurling the dipstick myself. Just hadn't decided how I plan on doing it just yet.
  9. Aug 24, 2019 at 2:02 PM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    Tape off the dipstick above and below the oil measurement zone and rough it up with sandpaper, emery cloth, or a dremel. Makes it much easier to read.
  10. Aug 24, 2019 at 2:06 PM
    PhenixFord
    Randy
    Arkansas
    I've though about using a Dremel. But a little bit concerned about weakening the metal. I've seen a "Knurler"? somewhere around the machine shop where I work. May try to borrow that. Or I may just use a sharp blade like the metal engravers use.
  11. Aug 24, 2019 at 2:06 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I have a 2014 and the dipstick is still horrid. Cant read it to save my life. People on here will tell you that your batshit crazy and give you the proper way to use a dipstick, wiping it off, waiting and re-sticking, like thanks I'm not a total idiot I do know how its SUPPOSED to work, I'm here asking because it's not doing what you suggest Captin Obvious. I now just dump the required amount (6 quarts for me) and call it a day.
  12. Aug 24, 2019 at 2:28 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    ajm and MOC221_[QUOTED] like this.
  13. Aug 24, 2019 at 2:38 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Check it first thing in the morning, before start up.
    CusterFan likes this.
  14. Aug 24, 2019 at 2:50 PM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    This. ^
  15. Aug 24, 2019 at 3:20 PM
    FloridaSon
    FloridaSon Well-Known Member
    White SR Gen 3
    @PhenixFord I read on here somewhere that someone drilled a small hole in the dipstick to catch the oil at the full mark after verifying it.
  16. Aug 24, 2019 at 3:57 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Works for me too. Then I check my oil between oil changes and if the dipstick has oil on it all is good in the world. :)
    Paul631 likes this.
  17. Aug 24, 2019 at 3:58 PM
    CusterFan
    This is what I do. :thumbsup:
  18. Aug 24, 2019 at 4:55 PM
    LilTexan22
    2017 Tacoma
    Lol pretty much this. I just put 5.5 quarts and called it a day. The dip stick is pretty worthless
    CusterFan and TheFang[QUOTED] like this.
  19. Aug 24, 2019 at 5:11 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Pull stick....wipe it....wait 5 min.....put stick back in.....pull.....Now you have a proper reading....!! (don't try a second time without the required 5Min.)….:thumbsup::thumbsup::thumbsup::thumbsup:
    OCD TACO likes this.
  20. Aug 24, 2019 at 5:19 PM
    slow TURD I4
    slow TURD I4 Well-Known Member
    SD
    2018 DCSB 2.7
    I’ve tried everything to get a solid read on my 2.7! I’ve even tested the reading while filling my oil to see what “low” (4qrts) would look like and it’s looks exactly like full (6qrts)! All smeared and “overfilled” looking. I just put in the needed 6 quarts and call it a day. I’ll periodically check the dipstick to atlest see if it has oil on it and not bone dry.
