2.7 Tacoma tires
Discussion in 'Wheels & Tires' started by Nate31, Apr 11, 2019.
  1. Apr 11, 2019 at 3:49 PM
    Nate31
    Nate31 [OP] Member
    2.7 Tacoma
    Can I run 265/70/16 E rated tires on a 2.7 Tacoma with out a lot of power loss?
  2. Apr 11, 2019 at 3:55 PM
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    The truck is slow as dirt no matter what anyways, unless you throw a supercharger/turbo on it. I run 265 75 16 M/Ts. Its fine around town still "peppy". But highway can be hard to hold speed above say 75 when going up a long grades, but it will still do 85 -90 on the flats if I give it about 100 miles to do so.. All joking aside, you will be fine, you may notice a slight difference IMO.. If you go above 31-32" that's when you really start to drag without proper gearing.
    Mine is also a stick shift ..
  3. Apr 11, 2019 at 3:58 PM
    Nate31
    Nate31 [OP] Member
    2.7 Tacoma
    And you run those in a E ?
  4. Apr 11, 2019 at 3:59 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Honestly? Dont. You won’t believe how much fuel you’ll use
    JNG and whatstcp like this.
  5. Apr 11, 2019 at 4:03 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    50lb 265/75 16's here, technically C-range.
    There was definitely a loss of power but totally manageable.
    barch88 and jeffmansion like this.
  6. Apr 11, 2019 at 4:08 PM
    Nate31
    Nate31 [OP] Member
    2.7 Tacoma
    I have 245/75/16 E rated winters on now. I’m just wondering if there will be much of a difference if I put 265/70/16 E rated because I do a fair bit of driving on dirt roads with lots of sharp rocks.
  7. Apr 11, 2019 at 4:14 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    I have the Falkens in 265/75r16
    You'll feel it a bit on the low end but overall it didn't affect my driving very much
  8. Apr 11, 2019 at 4:17 PM
    Johnders
    Yes E
  9. Apr 11, 2019 at 4:35 PM
    Nate31
    Nate31 [OP] Member
    2.7 Tacoma
    Okay thanks
  10. Apr 11, 2019 at 4:47 PM
    Mxmili
    Mxmili Well-Known Member
    Max
    Philadelphia
    2011 base 4x4 2.7l
    Bilstein 5100s at 0 Ome 883
    I run 265/70/16 P load, and as far as the upsize it didn’t make much of a difference at all. Not sure about the extra weight of the E-load. I have to downshift to get any power out of it anyway.
