2.7 to 3.4 swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jeremy175, Aug 17, 2014.
  1. Sep 27, 2021 at 2:44 AM
    Chris0044
    Chris0044 Member
    Ch
    Was thinking the same thing and personally would like to go 3.4 on the reg cab
  2. Sep 29, 2021 at 6:56 AM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    https://www.tacomaworld.com/threads/5vz-3-4-v6-swapping-guide-for-first-gen-tacomas.520148/
    You will need to move the motor mounts, acquire an engine, transmission, transfercase, new drive shafts, new trans mount, new wiring harness, interior harness, ecu, etc.
    Chris0044[QUOTED] likes this.
  3. Sep 29, 2021 at 11:34 AM
    Team_Jake
    Team_Jake Well-Known Member
    '99 4Runner Limited '01 Tacoma Xtracab
    If the goal is more power, keep the 3RZ. Far better aftermarket support on the 3RZ engines than the 5VZ when it comes to power gains.
    Chris0044 likes this.
  4. Sep 29, 2021 at 9:37 PM
    Running Board Man
    Running Board Man Well-Known Member
    I would rather a turbo 3rz, I've owned both while stock
    I don't know what would be unreliable about adding turbo granted you put a standalone and spend the money for a tune and injectors
    The 3rz is a stout motor that can take boost
  5. Oct 1, 2021 at 6:51 AM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    I've read that you can run 4-5 psi on stock internals/head/non intercooled/tuned. Anything over 7psi requires head studs/MLS gasket/Tuning. Apparently the stock crank is good over 1000hp.
  6. Oct 1, 2021 at 10:00 AM
    Team_Jake
    With stock internals, the 3RZ can crank out ~250hp, basically the same power a supercharged 5VZ will produce.
  7. Oct 2, 2021 at 12:29 AM
    Chris0044
    Chris0044 Member
    Ch
    To be honest I am looking for power and would like to keep the 3rz to avoid the work and invest what I was gonna spend on the swap . Spend it on building a healthy 3rz . I am interested in TQ as well, I don’t do crazy off road or rock crawl lol but would like to have that bottom end power .
    Running Board Man likes this.
