2.7 to 3.5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VisionOfGod, Sep 10, 2022.
  1. Sep 10, 2022 at 5:57 PM
    #41
    Toco62
    Toco62 Well-Known Member
    Keep the 4 cylinder and dependability , or sell it for the 6 ,figure out the cost then double it and I bet you will still have issues with it.
    Or LS swap it . go big or leave it.
  2. Sep 12, 2022 at 4:16 PM
    #42
    16taco2.7
    16taco2.7 Member
    Rich
    Guam
    2016 4x4 2.7
    -Allpro Long travel LCA/UCA -stock leaf pack with fox 2.0 and U-bolt flip. -LCE fixed fan and billet mount -Front and rear bumpers garage built. -URD CAT delete pipe -Elka 2.5 coilovers w/external reservoir and adj bypass -URD supercharger kit (personally tuned after cracking piston) -custom soft mounted supercharger oil cooler bottom half to frame -Rotrex 85mm pulley(down from 90mm stage two) -STETION quick latch hood pins -CaliRaised bed stiffeners -flowmaster 60series 18” muffler bed dump -URD short shifter kit -265/75/r16 cooper stmaxx -timbren bump stops front -LCE long tube headers -LCE main studs -LCE head studs -LCE street valve kit -LCE balance shaft delete -LCE hyper pistons (compression drop from 10.1 to 9.4) -K&N drop in filter -hewitt tech air injection delete -AEM afr sensor/gauge -glowshift digital boost gauge -NRG wheel/QR/hub adapter -quick release fire extinguisher bedside mounted -custom mounted oil catch can and hose routing -Allprooffroad aluminum skid plate raw -clutchmax 6puck ceramic stage 3 clutch. Stock flywheel
    I just installed this weekend. Bout 20 hours, but working solo. I fucking love it man. I already did break in period, and I’m not even on the preferred 93 octane yet.. it’s pretty fricking cool
    straitbad01, Taco47, Boco10 and 4 others like this.
  3. Sep 12, 2022 at 4:18 PM
    #43
    16taco2.7
    16taco2.7 Member
    Rich
    Guam
    2016 4x4 2.7
    Did stage two set up. Not too sure pulley size changed… but it required the cat delete and the piggyback ecu definitely tuned to it
    VisionOfGod[OP] likes this.
  4. Sep 12, 2022 at 4:22 PM
    #44
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    Just swap in a 5L Ford F150
    18CHUÑO likes this.
  5. Sep 12, 2022 at 4:29 PM
    #45
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Lame just to a lambo aventador V12
    18CHUÑO, Chew and AxisCab[QUOTED] like this.
  6. Sep 12, 2022 at 5:02 PM
    #46
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I would buy a 4 cylinder Ranger before a 4 cylinder Taco.
  7. Sep 12, 2022 at 6:36 PM
    #47
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Please tell us this is a joke; you have to know "94 octane" fuel won't do diddly for extra power.
    Stocklocker[QUOTED] likes this.
  8. Sep 12, 2022 at 6:37 PM
    #48
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    It gives you 7 more power-ups than 87.
    18CHUÑO likes this.
  9. Sep 12, 2022 at 6:40 PM
    #49
    Horseshoez
    Dale
    Maryland
    Sorry, not sure what that means. The fact is, higher octane fuel will not improve power for an engine not designed for the higher octane fuel.
  10. Sep 12, 2022 at 6:43 PM
    #50
    Stocklocker
    17TRDORDCSBAT
    Octane is the square root of horsepower. When you increase octane by 4 points, you get 16 more horsepower.
    AxisCab, verlaryder and 18CHUÑO like this.
  11. Sep 12, 2022 at 7:09 PM
    #51
    sketchman
    sketchman Member
    19’ Tacoma 2.7 4WD
    SOS lowered, Intake
    Did you twist the dizzy too? If not, that extra octane is giving you the square root of fuckall.
  12. Sep 12, 2022 at 7:20 PM
    #52
    Stocklocker
    17TRDORDCSBAT
    I dump two bottles in every tank, for twice the HP, twice the acceleration, and more MPGs as well!!!
    18CHUÑO, Chew and sketchman[QUOTED] like this.
  13. Sep 12, 2022 at 9:25 PM
    #53
    18CHUÑO
    18CHUÑO Well-Known Member
    Antoine
    2016 Tacoma SR5 i4 AC 4x4 Super White
    Ofc its a joke
    Stocklocker likes this.
  14. Sep 12, 2022 at 9:25 PM
    #54
    18CHUÑO
    Antoine
    Funny joke
  15. Sep 12, 2022 at 10:02 PM
    #55
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    5.9 6BT swap before any v6
  16. Sep 12, 2022 at 11:01 PM
    #56
    Stocklocker
    17TRDORDCSBAT
    Toyko Joe likes this.
  17. Sep 12, 2022 at 11:38 PM
    #57
    myn75
    Nor Cal
    Kinda reminds me of a Cessna 310 Continental O-470 7.7 liter engine, i think they produce about the same HP as well. designed for long hours of continuous output and still remain serviceable
  18. Sep 13, 2022 at 5:22 AM
    #58
    Horseshoez
    Dale
    Maryland
    If you're joking, good joke; if not, ummm, no, epic fail.
  19. Sep 13, 2022 at 5:38 AM
    #59
    Stocklocker
    17TRDORDCSBAT
    If you run 94 octane, and 5w30, you will feel the difference. The power boost from the octane, coupled with better lubrication and higher compression from the 5W30 will blow your doors off. Add nitrogen to your tires, and every day is track day.
    Brownmatthall likes this.
  20. Sep 13, 2022 at 7:09 AM
    #60
    Horseshoez
    Dale
    Maryland
    Okay, I get it, you're totally joking. :)
