2.7 will not start. But turn over for days.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aw3263, Nov 18, 2019.
  1. Nov 18, 2019 at 2:47 PM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    Led headlight bulbs.
    So the other day I went to start my truck and it fired up and died and would not start again. It will turn over but would not fire. So I started troubleshooting and I noticed my 20 amp efi fuse was blown and kept blowing every time I turned the key. So I traced wires did not find a short. IUnplugged the 02 sensors and still will not fire. Took a multi meter checked all the cool pack and did a spark test and still nothing. Even replaced the fuel filter and spark plugs. It’s getting fuel kamiya will not start. Even gave it a shot of ether and still nothing.... any ideas would greatly be appreciated.
  2. Nov 18, 2019 at 3:08 PM
    Hagstromez
    Hagstromez Member
    Bradley
    Denali, Alaska
    2004 Tacoma 3.4 4x4 5spd super white ex cab
    New frame compliments of Toyota 12/18 ARB bumper 3/19 Complete OME suspension 3/19
    What have you done to the truck recently?
  3. Nov 18, 2019 at 3:10 PM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    I installed a new radio in it but I already pulled it out to check for horrid wires and found nothing.
  4. Nov 18, 2019 at 3:11 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    are you getting fuel? had a buddy a few months ago whos fuel pump just up and died with no warning
  5. Nov 18, 2019 at 3:14 PM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    Yes I can smell the gas from trying to start it and I replaced the fuel filter.
  6. Nov 18, 2019 at 3:28 PM
    Hagstromez
    Hagstromez Member
    Bradley
    Denali, Alaska
    I think your best bet is to recheck that wiring.
  7. Nov 18, 2019 at 4:02 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So is the efi fuse still blowing?
  8. Nov 18, 2019 at 4:06 PM
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    If EFI wire is blowing, you’ve got a short somewhere. Means you’re drawing more current than the rating of the EFI fuse. Definitely check your wiring. If this happened right after installing the radio, that would be my first suspect.
  9. Nov 18, 2019 at 4:11 PM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    Well the efi fuse is not blowing now. Already went through the wiring on the radio. Nothing there. Lol this damn thing is being a pain.
  10. Nov 18, 2019 at 4:17 PM
    Emmetjmcc4
    Emmetjmcc4 Well-Known Member
    Emmet
    Michigan
    2002 Tacoma 4x4 270k, 1995 Tacoma 4x4 353k RIP
    American Racing 15x8 -19 off. Cooper Discoverer stt pro 31x10.5r15 Allpro baja tube bumper Fox racing 2.0 all around
    I had the same issue at one point with my 2.7 where I stalled the truck out right after starting it up and it would start after that. I'd leave the truck sit for a couple hoirs and shed fire right up like nothing happened
