2.7 won't start
Discussion in 'Technical Chat' started by Thatguy1974, Apr 17, 2020.
  1. Apr 17, 2020 at 3:18 PM
    Thatguy1974
    Thatguy1974 [OP] New Member
    Garrett
    02 Tacoma 2.7 prerunner
    None
    Hello everyone, new guy here. I have a 02 2.7L prerunner automatic. The issue I am having is during start up it will fire and instantly die. The only way to get it to run into give it gas and only it for roughly 30 sec. I've replace the iac valve, both o2 sensors, plugs and clean everything else . What should I be looking at? Mass airflow sensor? Throttle position sensor? Any help would expect appreciated.
  2. Apr 19, 2020 at 8:25 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Can you check your fuel pressure? I assume you can borrow a test kit from most auto part stores.
    I've seen vehicles where the pump builds up enough pressure to start but cannot keep the fuel pressure high enough to run.
  3. Apr 20, 2020 at 5:14 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just how did you get to this point everything fine then it just would not keep running??
    Have you pulled any codes??
    The ECM is most likely not seeing a signal telling it the engine is running so shuts off.
    If no codes most likely fuel related .
