2.7L 2TR-FE Inference Engine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Luke Girard, Apr 30, 2015.
  1. Apr 30, 2015 at 10:47 AM
    Luke Girard
    Luke Girard [OP] New Member
    Hey Guys,
    I'm trying to determine if the 2.7L 2TR-FE engine in my 2005 Tacoma is an interference engine. Does anyone on here know?
  2. Apr 30, 2015 at 11:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Pretty sure it is. But because it has a timing chain you shouldnt have any issues.
    Why the question?
  3. Apr 30, 2015 at 11:43 AM
    Luke Girard
    I accidentally turned the crankshaft counterclockwise maybe a quarter turn. Trying to figure out if thats a bad thing.
  4. Apr 30, 2015 at 11:48 AM
    nd4spdbh
    SoCal
    did you have the cam chain off?
  5. Apr 30, 2015 at 11:51 AM
    Luke Girard
    No. I was taking the crankshaft pulley off when this happened.
  6. Apr 30, 2015 at 11:57 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As long as the timing chain is on there is no harm. Turn it backward or forwards will not hurt it.
  7. Apr 30, 2015 at 12:13 PM
    Luke Girard
    Great, thanks for the input guys! :)
  8. May 1, 2015 at 7:53 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    For the record, it IS possible to do some harm. If you follow the timing chain path, it is designed to pull in one direction. Chain goes from cam on one side, down to an idler, up to other side, and down to crank. After the crank it goes back up and there you find a tensioner. All that tensioner does is keep the chain tight on the "slack side". If you turn backward, that tensioner can give and effectively lets the chain "stretch" and alter the valve timing. Unlikely you would hurt anything while loosening the damper, since you would probably feel the resistance should a piston contact one or more valves.
    But it is advisable to use caution going backward because of the tensioner possibly compressing and shifting timing.
  9. May 2, 2015 at 4:31 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Sorry but that is incorrect. As long as the chain is in place and has not jumped the sprocket no harm can take place.
    Here is some info;
    http://www.4crawler.com/Photos/Misc/ToyotaEngines.txt
    jmaack likes this.
  10. May 2, 2015 at 7:51 PM
    RobertHyatt
    Robert
    Birmingham AL
    The question is, what do you do about the tensioner? I've worked on many a overhead cam motor, and have seen the tensioner give way when you pull the thing backward. To the point it is difficult to verify timing is correct without rotating the engine two complete turns in the normal direction to start the check over. The effect I personally watched was that when turning it backward, the cams don't turn smoothly. That slop in the timing chain as the tensioner compresses and allows slack to form allows the camshaft to turn in a jumpy way caused by valve spring compression and release.
    I won't begin to speculate about the tensioner in the 4 cylinder engine. But in looking at the service manual, it is on the top of a long slipper, on the LHS of the motor. How strong it is I don't know. It might be stout enough that it can't compress. I've worked on some where I had to use a hydraulic press to compress the thing, then insert a steel pin to keep it compressed while re-installing it. But I have also worked on some that were not so stout. And they would compress with reverse rotation of the crank.
    So whether it will happen here or not I certainly can't say not having had this specific motor opened up. But MANY motors can experience this issue. Most service manuals specifically advise against reverse rotation for this very reason, nothing else really minds going backward except for the timing chain / belt tensioner device.
    If I was wrong in this instance, it certainly won't be the first time. But in the general case, there is certainly a risk associated with doing this. My assumption was that it _is_ an interference engine. If that is not the case, then of course there is no problem whether the timing chain compresses the tensioner, jumps one of the drive gears or anything else.
  11. May 3, 2015 at 10:01 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    It is an interference engine.
  12. May 3, 2015 at 4:36 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The chance of skipping a chain by turning the engine backwards is extremely small unless the guides, chain and the tensioner are completely worn out and it probably would skip when you started the engine from cold because the tensioner would be slack any way.
  13. May 3, 2015 at 7:43 PM
    RobertHyatt
    Robert
    Birmingham AL
    Note I didn't suggest skipping a tooth although that is possible. But the tensioner can compress and that introduces slack when turning backward. Depending on where the engine was stopped before this happened, you might turn the crank enough to contact an open valve. Not saying it _would_ happen. But it is simply _possible_. I worked on a neon a few years ago where the engine could be turned backward and wreck the timing as the belt would definitely jump a tooth. I worked on a different neon and it took godzilla to compress the tensioner just to get the belt installed (I had to use a hydraulic press and insert a steel pin through a locking hole to hold the tensioner compressed so that it could be installed.) I suppose it depends on how paranoid the engineer was when weighing the option of how much tension to keep things tight, vs how much wear since more tension applies more pressure to the chain and bearings.
    My answer was a more "generic" answer as opposed to one specifically directed at this specific motor since I have not worked on a 2.7 period. But knowing how they work, I would personally not attempt it just to stay on the ultra-safe side of the equation.
  14. May 5, 2015 at 2:48 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ponder this. A 4 cylinder motor stops in one of two places every time it is turned off when the engine is rotated two of the pistons are going down two are at the bottom coming up no matter what way it is turned one cylinder has two valves slightly open all ready the other one both are closed. If the design was such when the engine stopped on compression the cam due to rotational force would continue to turn slightly putting slack in the chain/belt so if the interference was that critical it would run the risk of bent valves. There is enough slack designed into the system to account for the possibility other wise there would be plenty of bent valves. If one turns an engine and it is out of time they would have to turn it with a bar to do any damage or at least turn it pretty hard it would come to a halt as soon as a piston struck a valve. Now when you have an engine turning several hundred RPM the story changes rapidly when a belt or chain comes unguled.
  15. Aug 16, 2015 at 12:43 AM
    bicks
    bicks Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    I have a 2tr-fe, I parked nose up on a steep hill wresting it in 1st gear as the e brake has stretched, can this rotate the engine backward and cause damage?
  16. Aug 16, 2015 at 4:40 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  17. Aug 16, 2015 at 5:14 AM
    bicks
    bicks Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    Thank you, could you please tell me more, such as if the car were to roll backward in first gear with the engine off, would that cause the same possible problems discussed above.
    Sorry if it's a silly question
  18. Aug 16, 2015 at 2:05 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Because any slack in the chain is no where even close to being out of time.
  19. Aug 17, 2015 at 2:13 PM
    bicks
    bicks Member
    john
    Sydney Australia
    Hilux 2.7 2wd
    soon
    OK so even if the engine does turn backward it will just take up the slack in the chain, anyway sees to be running fine, it never made any noise and is quiet on start up.
    Thanks.
  20. Aug 17, 2015 at 5:31 PM
    RobertHyatt
    Robert
    Birmingham AL
    The problem is, while it is "taking up slack" the cam is not turning yet the crank is. Whether there is enough room there to let a valve contact a piston, and whether one would turn so energetically that a valve stem actually bends is unknown. However, many engines do contain warnings in the service manuals that explicitly state "do not rotate the crank backward"...
    For me, better safe than sorry...
