2.7L 35 inch tires regear. HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tattedmom26, Apr 17, 2017.
  1. Apr 19, 2017 at 11:18 PM
    #101
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I think you got pretty good advice in this thread, along with the usual TW love.
    I think you know you will eventually need 4.88's, for now I would just drive it in D, the transmission will shift as it sees fit. Not much you can really do to help the trans except a regear. On hills I would lock it in a good gear for pulling to avoid constant shifts.
    I wouldn't worry about the engine, I run mine pegged all the time. 2.7 dgaf.
  2. Apr 19, 2017 at 11:30 PM
    #102
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    I think its pretty bad-ass that your running 35s on a 4cyl; Definitely save money for re-gearing_ Although I think if you're going to be running in 3rd gear on the highway I would recommend a transmission cooler if your truck didn't come with one. It'll help keep the transmission temps in check and prolong the life of the fluid/transmission. They are pretty cheap and pretty easy to install;
    I just installed one on an 98 Dodge 1500 that a friend of mine had me help him replace a transmission because he was towing a boat and had a camper in the bed; ended up burning up with transmission. I cut the return line from the radiator to the transmission then used a hose barb and attached the cooler to it from there and routed from the cooler back to the return line going back to the transmission.
    So you got HOT ATF fluid coming from the transmission; going into the radiator to help cool it then out the radiator and into the transmission cooler then from the cooler back into the transmission; Been working great and so far no troubles with his heavy hauling; all temps kept in check and only cost about 60 bucks.
    It's cheap insurance.
  3. Apr 20, 2017 at 6:56 AM
    #103
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    35s for everyone!!!!!
  4. Apr 20, 2017 at 7:02 AM
    #104
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    With 35s on my truck and stock gears I cannot use 5th gear. I live in 4th on the highway and on almost every slight incline I downshift to 3rd (75mph @ 4500rpm).
    I'm regearing over the next few weeks, I'll let you know how it goes.
    Hartford likes this.
  5. Apr 20, 2017 at 7:03 AM
    #105
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    :woot:
  6. Apr 20, 2017 at 7:07 AM
    #106
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    The A340 is the same transmission used in the 1st gen v6 Taco and also in the Supra. Guys have put 1000hp to this transmission with little to no modification to the transmission. It's not bulletproff (nothing really is), but it's pretty stout. I doubt a small S/C is going to kill it.
    n0rth likes this.
  7. Apr 20, 2017 at 7:17 AM
    #107
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    Regear first!!!!!!!!!!!!!!!!!!!!!!!!!!!
    n0rth and MY50cal like this.
  8. Apr 20, 2017 at 5:47 PM
    #108
    TYetti
    Mat
    My tires came in before my lockers and gears did. I suffered through a week with 4.10s and 35s lol
  9. Apr 20, 2017 at 5:50 PM
    #109
    TheCookieMonster
    North East
    re- regear first!!!!!!!!!!!!
  10. Apr 20, 2017 at 7:23 PM
    #110
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    V8 swap
    BlackGT99 likes this.
  11. Apr 30, 2017 at 6:05 AM
    #111
    Gcsteve
    Gcsteve Well-Known Member
    long island
    2015 Red sold, 2017 Inferno Sport Traded for a Honda w/ payload #1500
    The manual 3rd gear is more similar to the auto 2nd gear. I constantly am experimenting with my auto and running the auto in 3rd at 60-70 it revs higher but seems happy. The D is an overdrive gear and I cruise with that at something like 1500 RPM but if I need to speed up I will drop it to 3rd and if I stomp the gas all the way down it goes to second all the way to 4500-5000rpm. The only problem with running in 3rd is using a little more fuel. I just installed the LCE header and AFE air filter and it helps a little and it also gets about 1MPG better after install. My 5 lug has 3:53 diff so even my little 235s made it feel slower. I probably will regear to 4:10 soon. So for now you could if you are on flat ground let it lug along D if your not in a rush. But running in 3rd is fine too.
  12. Apr 30, 2017 at 6:44 AM
    #112
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    2.7 with 40"s here. What are you all complaining about ? :D :D
  13. Apr 30, 2017 at 10:45 AM
    #113
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    @Caltech90 Sorry I missed this, but I was turkey hunting...almost every day. But, yes it stands for Turkey Killer. I don't have it anymore because I moved to SC.
    Caltech90[QUOTED] likes this.
  14. May 2, 2017 at 1:28 AM
    #114
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    We share the same addiction. I wish I could go everyday, it's been a tough season in south Ga for me. I have killed two birds, but the last two weeks they have been quiet other than the courtesy roost gobble.
  15. May 2, 2017 at 4:40 AM
    #115
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Trying adding some boost with regearing lol
  16. May 2, 2017 at 4:50 AM
    #116
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Too late to say 5.29s?
  17. May 2, 2017 at 4:59 AM
    #117
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ignore hx989, he's a dick. No literally, ignore him! If you click his name, a little window will pop up. You'll see a link to "ignore". All it does it just hide his posts. I've got a few people on my ignore list, and it's great. Out of sight out of mind.
  18. May 2, 2017 at 12:12 PM
    #118
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    That's good info :D
    EatSleepTacos[QUOTED] likes this.
  19. Jun 11, 2018 at 3:02 PM
    #119
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Bump...I have been sitting on the money for a re-gear for awhile. I have a 2.7 5 spd with 255/85r16s and a ton of armor. I wheel the snot out of my rig and I am 100% going to re-gear for more on trail performance. I have to slip the clutch too much on obstacles. The questions is for me -> should I go 35s + 4.88s? Probably yes...
    EatSleepTacos likes this.
  20. Jun 11, 2018 at 3:14 PM
    #120
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The answer is always yes if trying to decide if you should go with 35s.
    ecgreen[QUOTED] likes this.
