2.7L 3rz Question
Discussion in '4 Cylinder' started by Scosh, Feb 2, 2010.
  1. Feb 2, 2010 at 4:29 AM
    Scosh
    Scosh [OP] Well-Known Member
    Scotty
    New Iberia
    02 Prerunner SR5
    Bilstein 5100's all around, Limo Tinted windows, Moto Metal 951 wrapped in Revo 2's 265/70/16, clear corners, dual Magnaflow muffler, Turn signal mod, more to come...
    I have an 02 Prerunner with a 2.7L 3rz. From reading around, I read that it is safe to constantly hit the rev limiter because it is so underpowered. Is this true? I haven't tried it myself, but I would like to when I am offroading.:)
  2. Feb 2, 2010 at 4:34 AM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
  3. Feb 2, 2010 at 8:21 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    being underpowered has nothing to do with it. A rev limiter is in place to prevent damage. I definitely dont suggest running at redline for a lengthy amount of time.
  4. Feb 2, 2010 at 1:57 PM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
    Oh, I was just wondering. I didn't plan on doing any of that.
  5. Feb 2, 2010 at 5:32 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    The strength of the 3RZ, and the fact that the rev limit is rather low mean that being on the limiter will not harm the engine. But wear is cummulative, and over time will accelerate the wearing out of the engine.
  6. Feb 3, 2010 at 1:30 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    As others have said, I don't recommend spending much time at/near the redline but occasional bumps off the limiter aren't going to hurt anything. That's what the limiter is for - to prevent damage. Besides, the real usable power tapers off before 5.5k rpm anyway. I've heard stories about people abusing the 2.7L that made me cringe, seriously. Some race shops are building 1200hp drag motors with them. No I don't believe everything I read, but considering there are *so* many accounts of the toughness of these engines, mine will probably outlast the rest of the truck. 4-banger all the way. :)
  7. Feb 3, 2010 at 7:10 PM
    dually
    dually Low and slow
    for the record, 2.4 is more stout than the 2.7. Rod failures on the 2.7 when under boost.
  8. Feb 4, 2010 at 12:30 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    is that with stock rods? or aftermarket?
  9. Feb 4, 2010 at 12:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Depends on the amount of boost. I ran 6 psi in mine for over 85k miles, with no issues.
  10. Feb 4, 2010 at 12:34 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah its like hondas..they can run a good bit of boost on a stock engine..
  11. Feb 4, 2010 at 3:43 PM
    dually
    dually Low and slow
    Yeah true, cruzinlife over on CT blew two 3rz's both with rod failures. He had a killer setup too, no knock. I think he only pushed 9-12lbs... shit happens though!
  12. Feb 4, 2010 at 4:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 2.7 does have forged rods. Crank too. Just not the pistons.
  13. Feb 4, 2010 at 5:13 PM
    dually
    dually Low and slow
  14. Feb 5, 2010 at 12:29 PM
    DGXR
    Friend
    Sacramento, CA
    OK that makes sense, the 1200hp drag motors were using the stock crank, block and head. Everything else was replaced with hi-po stuff (valves, rods, pistons, cams, etc). Even the crank was shaved down for lower weight, and balanced.
  15. Jul 9, 2010 at 6:39 PM
    toyotadan
    toyotadan Member
    washington
    98 4x4
    you don't want to hit the limiter as it will cause premature wear
  16. Jul 11, 2010 at 8:59 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    try 18 psi and up I have had my 9psi s/c for 1 1/2 years and no issues
