2.7L 4 Cylinder Oil Filter Removal without Spilling
Discussion in '4 Cylinder' started by jowybyo, Nov 22, 2016.
  1. Nov 22, 2016 at 1:41 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    doesn't the Fumoto valve take along time to drain the oil pan as opposed to using the plug. I have read where the valve trickles out the oil slowly?
  2. Nov 22, 2016 at 1:42 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not at all.
    I have the Fumoto, it's every bit as fast.
    Mush Mouse and vrod671 like this.
  3. Nov 22, 2016 at 1:44 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That's true but I'm thinking a slower drain may take MORE shit out of the engine but I'm probably wrong.
  4. Nov 22, 2016 at 1:46 PM
    Mush Mouse
    mush
    2013 SR5
    maybe, I was going to get one but I want to get it over with quickly don't want to wait until the pan is dry, I can do the plug pretty good but still get some oil on my hands
  5. Nov 22, 2016 at 1:46 PM
    Markcal
    Markcal Well-Known Member
    I only difference in the way I look, to the way you look in that photo, is that I never miss getting it in my eyeball sockets too.
    vrod671[QUOTED] likes this.
  6. Nov 22, 2016 at 1:47 PM
    T4RFTMFW
    I have a Fumoto and am doing an oil change in less than 15 minutes start to finish.
    It's not slow.
  7. Nov 22, 2016 at 1:47 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Flipping a switch is quick enough for me
  8. Nov 22, 2016 at 1:47 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Cut the bottom off a plastic milk jug and screw the plastic lid on tight.
    Get your oil filter tool and loosen the filter just a bit. Enough so you can do it the rest of the way by hand but not enough to let any oil spill out.
    Put the milk carton up over the filter. Since you already broke it loose you can put your hand up around the milk carton and spin the filter off with your fingers. Let it and all the oil fall into the milk carton.
    Milk carton has a handy handle so now you can carry it off to dispose.
  9. Nov 22, 2016 at 1:48 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    Genius!
    Markcal likes this.
  10. Nov 22, 2016 at 1:52 PM
    Mush Mouse
    mush
    2013 SR5
    do you jack up the front end? cause if not you must be a contortionist
  11. Nov 22, 2016 at 1:55 PM
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    I think it'll work.
  12. Nov 22, 2016 at 1:55 PM
    Mush Mouse
    mush
    2013 SR5
  13. Nov 22, 2016 at 1:55 PM
    andrew61987
    Nope, I just toss some cardboard under so I can slide easily, grab the bottom of the truck, and pull myself under.
    Mush Mouse[QUOTED] likes this.
  14. Nov 22, 2016 at 1:56 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    No, I just turn the wheel to the left and go in between the frame and upper control arm. I have to use my left hand and have to remove my watch so I can get in there. I will be getting oil down my whole arm.
  15. Nov 22, 2016 at 1:57 PM
    #35
    Mush Mouse
    mush
    2013 SR5
    hmmmmm
  16. Nov 22, 2016 at 2:05 PM
    #36
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Good info here, but you will also find good info in other threads if you do a search.
    My approach: wedge a 6" x 10" piece of cardboard behind the oil filter and loosen the filter enough to trickle oil, letting the cardboard deflect the oil to a drain pan. After a few minutes, remove the filter, keeping the open end up. No messes, no problems... yeah the oil filter is in a stupid place but that's true of many vehicles.
    Before I got smart, I hated burning my arm on the hot exhaust more than I hated dribbling dirty oil! Now I wait 15 minutes for the header to cool before sticking my gorilla arms in there.
  17. Nov 23, 2016 at 2:45 PM
    #37
    jowybyo
    jowybyo [OP] Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You guys came up with some good ideas. I like the soda bottle and milk jug ideas the best.
  18. Nov 23, 2016 at 7:58 PM
    #38
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I just take mine to the dealership and eat as many cookies as I can while they change my oil.
    Back a couple years ago when I changed my own oil I would stop by a furniture store and get a mattress box they put out by the dumpster. They are nice to slide up under the truck as another guy mentioned. The nail to punch a hole in the filter works great also. Use to do that myself.
    Mush Mouse likes this.
  19. Nov 26, 2016 at 7:10 AM
    #39
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Cardboard underneath the truck. Puncture a hole in the filter to drain with a funnel w/ a long flexible tube pointed toward the drain pan.
  20. Nov 27, 2016 at 8:34 PM
    #40
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I use old zip lock bags. I can slip it over the filter and turn it with the zip lock bag on. The zip lock part is rigid enough so the bag doesn't wrap itself up on the filter mount. When it looks like the filter is going to drop off I catch it in the bag and zip it up and put it in my haz-mat recycling box - eventually the oil does eat through the bag. Bags and cheap enough that I don't mind throwing them away.
    andrew61987 likes this.
