2.7L 4cyl truck slide in camper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by angelocardoc, Dec 24, 2013.
  1. Dec 24, 2013 at 5:37 PM
    angelocardoc
    angelocardoc [OP] New Member
    Hi
    I'm thinking of getting a 2nd gen Tacoma and putting a slide in truck camper on it.
    The Tacoma I'm thinking of getting is a 2 wheel drive access cab 6 ft box.
    It has the 2.7L 4 cyl engine.
    The slide in truck camper will weigh about 1,100 lbs.
    My question is, has anyone put a slide in truck camper in a 4 banger Taco?
    Is this a bad idea?
  2. Dec 24, 2013 at 5:44 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think it's a little too heavy especially once it's loaded up with shit. Nice idea, though.
  3. Dec 24, 2013 at 5:47 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    That will be too much for any Tacoma.
  4. Dec 24, 2013 at 6:01 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Those old U-Haul Toyota dually v6 cube trucks could work well and I ALMOST bought one (and still regret it) before buying my Taco.
  5. Dec 24, 2013 at 6:12 PM
    angelocardoc
    Back in the 70's and early 80's they had Toyota RV's
    Todays Taco is way more robust than those.
    They're doing it overseas
    Are they built different over there???
  6. Dec 24, 2013 at 6:13 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ There you go.
  7. Dec 24, 2013 at 6:24 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
  8. Dec 24, 2013 at 6:30 PM
    angelocardoc
    I've had enough of tent camping.
    I'm too old for that shit
  9. Dec 24, 2013 at 7:33 PM
    worthywads
    And those were build for the weight, looks like duelies on the first one with beefy front wheels too.
    Look at the payload for a Tacoma, 5-lug = 1143 lb. Pre-runner = 1271.
    1100 plus your weight exceeds the payload. Throw in some gear and it only gets worse.
  10. Dec 24, 2013 at 10:16 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I've seen a few Tacoma's set up with a slide in camper...but never a 4 cylinder. You'd be working the drivetrain way too hard to keep all that weight moving. Get the V6.
  11. Dec 24, 2013 at 10:25 PM
    nyfishhunter
    nyfishhunter Well-Known Member
    Sean
    White Plains, NY
    2010 DC 4x4 OR Pyrite
    Weathertechs, Pop N Lock, Whitetail Sockmonkey, OEM bed mat, Undercover SE, Wet Okoles, OEM iPod interface, Rear Spring TSB, Illuminated 4x4 switch, DTRL, Timbrens, 5100s (front .85), Eibachs, 1.5 AAL, OEM running boards, FJ TRD center caps, diff breather mod, trimmed front flaps, ImMrYo mirror bracket, Grillcraft, painted white Sport grill black
    Had a 4 banger 1st gen and stayed just under max weight rating. I understand it is harder to do with the composite bed in the 2nd gens. [​IMG]
  12. Dec 24, 2013 at 10:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not exactly.
    Those RVs were duallies, the truck was rated 1-ton. WAY over today's rating.
    Most likely, yes.
  13. Dec 24, 2013 at 10:40 PM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    Go check out expedition portal forum or wander the west for this question. TW is great but maybe not the best source of info for campers. Plenty of 2nd gens running around with campers like you want. The 4cylinder may get tiresome.
  14. Dec 25, 2013 at 10:31 AM
    Dangermouse
    Dangermouse Well-Known Member
    RG
    Texas
    2013 Reg Cab 4x4
  15. Dec 25, 2013 at 12:57 PM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Its been done, and once I have $$ I'll be doing the same. For the 4 banger I personally would opt for the FWC finch shell model because of the weight. But if you have one already, I'd drop as much weight as I could by removing stuff I didn't use or rebuilding the inside to be lighter. You won't win any races, but the 4 banger will ramble on just fine. Add an aftermarket suspension and/or airbags and the truck will handle the load a lot better. There are tie down brackets designed for our composite beds to hold the slide-in campers. You'll have to keep a close eye on your overall weight, and be mindful in the mountains, but the slower you go the more you see haha.
    Here's a few links:
    http://www.expeditionportal.com/for...-a-2013-Tacoma-regular-cab-Looking-for-advice
    http://www.truckcampermagazine.com/camper-reviews/first-look-2012-four-wheel-camper-sc
    Google: Tacoma FWC Finch or the like and you'll see a number of threads
  16. Jan 13, 2014 at 6:19 PM
    Bknox
    Bknox New Member
    NE
    08 Base/Mods I-4
    Hitch, Tinted windows, Weathertech floor liners, Amber anytime fogs, Intermittent wipers, Xtra D rings, Plasti-dipped wheels/badges, Tonneau cover, Pop-n-Lock, Fat Bobs AAL Leveling kit, DuraTracs, Slide-In camper, Tacoma seat covers, Black tail lights, Rear LED strip, TO BE CONTINUED.....
    Here Is my 1983 Sunlite pop-top.
  17. Jan 15, 2014 at 7:00 AM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    Very nice,wish I could find one!
  18. Jan 15, 2014 at 10:39 AM
    BruceDog
    BruceDog Well-Known Member
    CT
    2014 DCSB SR5 4x4
    Leather
    I put an old six-pac slide in camper in my 94 pickup 4cyl and it just about crushed the truck. Looked like I was about to pop a wheelie. That said, the truck carried it all over Colorado and Utah, albeit a bit slowly, and I only paid $600 for it. But it was really no fun to drive and it reduced my gas mileage by more than half. With the extra money spent on gas you could just stay at a motel, or, if out in the wild, in a tent or under a nice fiberglass topper.
    It sounds like your going to put a lot of money into this set up with a new truck and the cost of the camper. I'd wouldn't do it. Not sure what your current vehicle situation is, but now that I have a v6 tacoma, I'd rather get a 10-16 foot travel trailer. Way more room in the trialers than the slide-ins.
    If you don't currently have a vehicle, then you could also look at vans, which are quite nice to camp out of.
  19. Jan 15, 2014 at 3:59 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Yah, I went with the travel trailer, a short little guy, Kodiak 166E hybrid. 14 ft actual length, 18'9" if you include hitch and rear tire in the total length. The foldouts fore and aft are queen beds so it folds out to the equivalent of a 24' trailer. Of course the foldouts are canvas tops, but there's these things http://www.popupgizmos.com/bunkcoverpage.htm that are nice from what I hear.
    It's nice to de-trailer once you find a good spot, and yeah the room inside is nice. Also storage inside the trailer so it's not in the bed of the truck. An 8-foot wide trailer is better than a 6-foot wide popup. Plus an enclosed shower and toilet, giant refrigerator/freezer, two 20lb propane tanks, two batteries.
    It's actually not bad offroad, see my lamentations here http://www.tacomaworld.com/forum/arizona/306460-trailer-camping-spots-az-winter-4wd.html
    I'll add to that I put the Timbren bumpstops on the rear so the rear end doesn't sag so bad with the straight hitch. They're alright for a cheap fix, airbags probably better, but being a cheapskate I went with the Timbrens.
    So, in summary I like the trailer vs. slide in. The problem with a trailer is if you go down too bad of a road you gotta be able to find a spot to TURN AROUND! That can be a pain, and has been. The WDH was a large part of the problem trying to turn around, it doesn't take well to torqueing the trailer to weird angles, it got tore up pretty good.
    But I can see this trailer being a capable offroader with the one crucial mod, 15" wheels.
  20. Jan 15, 2014 at 6:58 PM
    Smiley
    Smiley Active Member
    CoLoRaDo
    12 RegCab SB 4x4
    Dual Optima battery set-up, K&N intake, Yellow wire mod, Leer/cab high shell, Roof Rack, BedRug, Rock Sliders/built and installed, Front Bumper w/winch in progress
    Anybody know if regearing the truck would work for what he wants?
    The trucks rated payload capacity 1400Lbs or so. So wouldn't it handle the weight ok? even with a reasonable amount of gear?
    My dog drops my capacity down to 1260 Lbs. LoL He's a fin Yeti
