2.7l 5 speed Transmission Temp PID
Discussion in '2nd Gen. Tacomas (2005-2015)' started by M37r1c, Sep 9, 2024.
  1. Sep 9, 2024 at 8:28 AM
    M37r1c
    M37r1c [OP] Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    Hey all,
    I've done a ton of searching and I'm trying to find out if anyone has PIDs for the 2.7l 5 speed for the trans temp using the torque app. I've searched everywhere and used different equations but they all seem to be for the auto and don't work. I tend to tow our popup camper all over and would like to be able to use my phone to monitor how the transmission is doing. Have pretty much everything besides that. Anyone know what works?
  2. Sep 9, 2024 at 9:28 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    If your talking a manual then I'm not sure how much it would matter regardless. No pump or real way to cool down the gear oil without some extensive modification.
  3. Sep 9, 2024 at 9:42 AM
    Why I oughta...
    Why I oughta... Well-Known Member
    2014 Base AC 4x4 2.7 5speed
    If thats the manual transmission I'm not sure it even has a temp sensor. I have found there is a lot of knowledgeable people on this site so somebody will know.
  4. Sep 9, 2024 at 10:12 AM
    kidthatsirish
    To the best of my knowledge it does not
  5. Sep 9, 2024 at 10:29 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There is no temp sensor on a manual transmission and thus no trans temp PID.
    There's very low risk of overheating a manual transmission as long as you keep it full of fluid and change the fluid when needed.
    If your towing heavy don't tow in overdrive.
  6. Sep 9, 2024 at 10:53 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    It's because there is no temp sensor for the manual trans.
  7. Sep 9, 2024 at 11:12 AM
    M37r1c
    Rob
    Well thats good to know. Popup only weighs 1800 lbs so its not a heavy tow and it doesn't struggle at all to tow it. Just figure it would be nice to have the info if its available. Thanks all for the info.
  8. Sep 9, 2024 at 6:13 PM
    kidthatsirish
    Yeah that's not a lot of weight. I wouldn't worry about it one bit.
