2.7L Access Cab thread
Discussion in '4 Cylinder' started by 2004TacomaSR5, Mar 29, 2012.
  1. Jul 29, 2014 at 6:17 AM
    #501
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Ya I'm shocked they didn't explode especially with all the shale and roots and nails from dickbag pallet burners, that and it looked stupid with sliders and stock tires lol
  2. Jul 30, 2014 at 8:06 AM
    #502
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Hahaha well props to those tires then.
  3. Aug 2, 2014 at 10:06 PM
    #503
    edgerat
    edgerat Well-Known Member
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Anybody have issues with their truck running a little rough or almost a "missing" feeling when driving with the A/C on? I just want to make sure it is just because it is gutless and not because there is something wrong :) Truck has 405mi on it as of tonight. Did fill up with 92oct today just to see if that had anything to do with it, it did not, almost seems to be worse. My UG shows about a .50g/h worse usage with the A/C on blast. If I could get YotaDan or FNwheels to email me back I would have my lift and wheels on their way to me. Already got my Duratracs but, thinking of sending them back to get something with a tougher sidewall......
    Isaac
    105CC3F6-161C-4DB1-9E1A-562200851999_zps_b33e8f02daf5fc3413431b140d680371fc3f76c5.jpg
  4. Aug 3, 2014 at 7:48 PM
    #504
    NoSilverBullet
    NoSilverBullet N60 member
    Northern Canada
    2012 AC 2.7 MT 4wd
    Old Man Emu suspension: 884x coils, Dakar leaf pack, Nitrocharger Sport shocks. Cruisin Offroad bolt-on sliders. Relentless Fabrication aluminum front and mid skid plates + steel transfer case skid. SnugTop Hi-Liner "Sportsman" canopy. Hella Rallye 4000i Xenon (flood beam).
    I rarely use the AC, but when I do, I can't say I've noticed a loss of power or a rough idle.
    Also, what lift are you getting?
  5. Aug 3, 2014 at 11:05 PM
    #505
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Going back and forth between stage 3 Icon or 885s with a 1/4" on drivers, wheelers AAL and Billies on all four. We spend a lot of time in the mountains on the weekend driving the forest service roads so I want to smooth out the washboard and occasional pot hole. High 80s with high humidity isn't doing my wardrobe any favors :)
  6. Aug 3, 2014 at 11:26 PM
    #506
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I can feel my a/c pump engage, it only last a second. No noticeable effect on performance.
  7. Aug 4, 2014 at 4:34 AM
    #507
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Double check that setup man. I am not entirely sure that the 885s will work with our light 4cyl. I believe it is designed for the v6
    again I could be wrong but I remember seeing that somewhere..
  8. Aug 4, 2014 at 10:06 AM
    #508
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Thanks for that info! I will double-check that with Wheeler's. Trying to do it right the first time.
  9. Aug 4, 2014 at 10:35 AM
    #509
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    885s are close to 650# springs. They will be stiff with stock body parts on. For reference, I have 650s and a steel bumper, winch, lights, skid plates, extra wire ........ And it's still a lil stiff. I don't know about the wheelers aal but the icon progressive aal pack is widely viewed as the go to aal pack if you don't want to step up to an All pro pack. 5100s are a great shock but not even in the same ballpark as icon, king, or Fox shocks.
  10. Aug 4, 2014 at 8:52 PM
    #510
    NoSilverBullet
    Northern Canada
    2012 AC 2.7 MT 4wd
    OME 885 and 884 coils have the same spring rate of 590 pounds. The only difference is the 884 is 10mm (roughly 3/8 inch) shorter. (ref: http://cruiseroutfitters.com/tech_OME_coils.html)
    That being said, I agree 884s are generally a better option for a 4 cyl. If you call Wheeler, they'll probably recommend the same with their AAL.
  11. Aug 5, 2014 at 8:08 AM
    #511
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Oh ok gotcha. Yeah I got a buddy with a stock v6 double cab with 885s and it rides great.
  12. Aug 5, 2014 at 12:00 PM
    #512
    Yota Toy
    Yota Toy Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    Those rims look great on your truck!!!
  13. Aug 5, 2014 at 3:47 PM
    #513
    jwinky
    jwinky Well-Known Member
    oklahoma
    2006 Access cab 4x4 5 speed
    5100's with OME 885 coils, Wheeler's 2" AAL
  14. Aug 5, 2014 at 6:00 PM
    #514
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Thanks for the heads-up on the coil options Dangerdave! I ordered my stuff today.
    Bilstein 5100s on all four
    Wheeler's AAL 3-leaf pack (should I delete the overload, not hauling or towing anything)
    OME 884 with 1/4" spacer to delete TacoLean
    Camburg UCAs (not sure if I am going to need these or not with the amount of lift)
    Also ordered my 17x8.5" FN Five Stars in matte bronze to faux-match the Pyrite Mica and already have my 265/70/17 Duratracs, I don't plan on wheeling so I am hopeful the sidewalls are safe... :) Little stuff, got my tint on the front windows done today, WeatherTech digifits will be here tomorrow, already have my UG and URD short-shift installed the last week, just need to order my Marathon seat covers and I should be done with everything for a little while at least. Putco LEDs should be here tomorrow as well. Truck just broke 600mi today!
    Isaac
  15. Aug 5, 2014 at 6:21 PM
    #515
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    You won't need the ucas unless you go to a 3" lift but you will want them either way. Camburg ucas have added caster which you need when lifting the truck. Get the ball joint ones because you won't need the added strength or travel. You don't need unbialls unless you want to be "baller" and spend the $700.
  16. Aug 6, 2014 at 4:49 PM
    #516
    TYetti
    Mat
    Some pics from my 6 day wheeling trip
  17. Aug 9, 2014 at 5:32 PM
    #517
    edgerat
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    10527279_10201163541889354_9035584025891_48500ae837187553ea1e45b9727c3e7ea4e0a5e0.jpg
    Got the wheels and tires on today. Really really happy with the way it turned out. Now just to get the suspension sorted. :)
    Isaac
  18. Aug 10, 2014 at 8:31 AM
    #518
    Dangerdave
    David
    Wilmington, NC
    20 F150
    My little four banger 5sp
  19. Aug 20, 2014 at 7:55 AM
    #519
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    2012 2.7 manual, SR5, only "major" (ha) mod is 265/75 16 Firestone Destination AT tires. No lift or spacers or anything like that.
  20. Aug 20, 2014 at 10:10 AM
    #520
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Awesome water pic! I used to like my truck a lot more when it was stock. Haha I need a new truck
