2.7L Access Cab thread
Discussion in '4 Cylinder' started by 2004TacomaSR5, Mar 29, 2012.
  1. Aug 6, 2015 at 4:49 AM
    #841
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Hey a quick update you guys, @Greenbean & @JBecker on my clutch pedal squeak!
    So yesterday after work i took the truck to the dealership to get them to look at that annoying squeak in my clutch pedal. Got there about 4:20 for my 4:30 appointment and it took them about an hour to figure out what i needed replaced. So the service guy comes back to me in the waiting room and says this would be all covered under the 3 year 36,000 miles which you are over and the cost for all the parts was around $600 with 3 hours of labor, and i was like hold on a minute. I purchased this truck on February 1st 2015 and it was Certified Pre-Owned and it came with a 1 Year or 12,000 miles bumper to bumper warranty (I currently owned the truck for a little over 6 months and roughly had 5500 miles on it). So he argued with me a little about that and then i said I'm not paying anything for you guys to fix this truck! So then he went back and called Toyota Extra Care and finally about an hour after that he came back to the waiting room and told me that they were going to cover it under my warranty and there will be a $50 deductible. So a $50 deductible isn't too bad for around $600 worth of parts. So he said they are going to order the parts and when they come in they will call me and i can schedule a appointment to get it fixed!
    So just to let u guys know that if you are under 3 years or 36,000 miles they will probably fix the clutch squeak, not sure if they go up to the 2015 year or not tho.
    A little information for everyone!!!!
    JBecker likes this.
  2. Aug 6, 2015 at 5:41 AM
    #842
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Haha well I guess that's nice to know it's covered under warranty but how does that help everyone know what the problem is? You didn't inquire about what the parts they are replacing are? I have a very pronounced squeak from my clutch when pushing it in and its coming from the slave cylinder. I don't know if that's where everyone else's noise is coming from but have someone else sit in your truck and push the pedal in a few times while you lay under the truck and see what you find. A slave cylinder is not $600 worth of parts so I'm curious if that's Toyota just replacing every clutch part they can or if that's just their fucked up marked up pricing on things
  3. Aug 6, 2015 at 5:48 AM
    #843
    moe2o4
    Corey
    Pittsburgh PA
    They are going to replace the clutch master cylinder, all the line and the slave cylinder & the clutch pedal assembly & in that price is the 3 hours of included labor. When i get them to do it I will get a breakdown of how much the parts cost from the sheet!!!!
  4. Aug 6, 2015 at 7:02 AM
    #844
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Oh ok yeah that helps a lil more. Haha sounds to me like they didn't try and find the specific problem. It's not the master cylinder creating the squeak nor is it the brake lines. The problem will be in the slave cylinder and/or the clutch pedal assembly. The clutch pedal could be diagnosed with some wd40, the slave cylinder not so much.
  5. Aug 6, 2015 at 7:10 AM
    #845
    moe2o4
    Corey
    Pittsburgh PA
    Ya, i think the squeaking is coming from the clutch master, cause if you go down under the dash and twist the rod on the master it goes away for a little while and comes back lol.
  6. Aug 6, 2015 at 10:10 AM
    #846
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Ok ....... My bad ..... I guess you didn't catch that I said "master cylinder or brake lines". I was talking with a co worker about his brakes this morning and had brake master cylinder stuck in my mind. Haha so yes it could be the CLUTCH master cylinder. In my case it's not.
  7. Aug 8, 2015 at 3:57 PM
    #847
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Learned something the other day.
    Turns out my 2015 Access Cab Utility Package truck IS pre-wired for a back up camera!!! :jellydance:
    I removed my panel to see once and for all and found this...
    So what camera am I looking for, Just any 2012+ back up camera.
    I know some can purchase a cheaper camera by going through the company
    that actually makes the cameras for Toyota.
    I really and stoked about this one. Especially after just getting my tint done.
  8. Aug 8, 2015 at 4:24 PM
    #848
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    Camera source has a plug n play. Its nice I have on an alpine x008u. Looks good.
    Greenbean likes this.
  9. Aug 8, 2015 at 4:27 PM
    #849
    B ill y
    Billy
    Toyota wanted 500 I think it was 200 at camera source. Looks stock. Or maybe it is what they use.
  10. Aug 8, 2015 at 4:32 PM
    #850
    Greenbean
    Zack
    Western NC
    10-4, Yeah I can't do 500...
    But 300 or less is doable.
  11. Aug 8, 2015 at 4:33 PM
    #851
    Greenbean
    Zack
    Western NC
    Thanks,
    They have just the camera for about 220.00 :thumbsup:
    So was there a difference in cameras? Or is the camera itself the same just the display different as in the mirror versus the radio unit?
    B ill y[QUOTED] likes this.
  12. Aug 9, 2015 at 8:21 AM
    #852
    Bigjoe7757
    Bigjoe7757 Well-Known Member
    SE P.A.
    2015 access cab 4x4
    This is great Can I get a part number please
  13. Aug 9, 2015 at 8:49 AM
    #853
    B ill y
    Billy
    Go to camera source.com and put in your info there is a couple
    Bigjoe7757[QUOTED] likes this.
  14. Aug 9, 2015 at 11:39 AM
    #854
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Yeah I'm gonna get that camera. Just checked mine and it's pre wired.
    And regarding the clutch squeak, I doubt changing parts is gonna help since my 15 is already doing it. How different can the parts mine has be to what they will install for you?But let me know if it does solve the squeak.
  15. Aug 9, 2015 at 2:06 PM
    #855
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I pulled the dust boot back from the piston on the slave cylinder and sprayed it with wd40 lithium grease and my squeak went away, for the moment
    moe2o4 likes this.
  16. Aug 11, 2015 at 4:04 PM
    #856
    moe2o4
    Corey
    Pittsburgh PA
    Just dropped the truck off after work today at the dealership, they said they will have it done tomorrow with all the new parts on it and hopefully no squeaking!!!!
  17. Aug 11, 2015 at 4:18 PM
    #857
    Greenbean
    Zack
    Western NC
    Cool beans,
    moe2o4 likes this.
  18. Aug 11, 2015 at 5:06 PM
    #858
    moe2o4
    Corey
    Pittsburgh PA
    I'll let ya know how it goes tomorrow and post a pic of what they replaced on the truck!
  19. Aug 11, 2015 at 9:07 PM
    #859
    Greenbean
    Zack
    Western NC
    Thanks, I'm curious.
    ? For ya, do you have a little free play in the pedal? Enough that when you go to depress the pedal you hear the click or pop as the slack is taken up and then you have the resistance of the master cylinder?
  20. Aug 12, 2015 at 7:33 PM
    #860
    moe2o4
    Corey
    Pittsburgh PA
    Picked the truck up tonight after they changed all the stuff for me. Seems like the clutch is grabbing higher than it did before, strange. But here is a pic of what they replaced on my receipt. And no there is no freeplay in the pedal at all. 20150812_222946.jpg
